Cinebench 11.5 - vsi procesorji, vse grafične
3
barocco ::
Sm dal nazaj na stock CPU..
RangerVIII|6700k|Corsair16GB|
Msi1070|pm961|BX5001TB|RM650x|H100iv2|
vaščan ::
i5 2500k 4.5ghz 8gb ram 1866mhz ati 6970 crosfire windows 7 64bit.
  • zavaroval slike: kuglvinkl ()
GenZNPC ::
Čas je, da se tudi ta lestvica malo osveži:
AMD A10-6800K @ 4,77ghz,
AMD 8670D igpu @ 1169,
2x 4GB (2133) @ 2208mhz (10-12-12-31)
skibidi
fr4nc ::
8.20 | AMD FX-8320 @4740MHz, AMD HD 7850 (stock), Windows 7 64-bit, 8GB | fr4nc |
Lep pozdrav
galu ::
Osveženo, ampak samo fr4nc-ov rezultat. Dajte prosim napišite rezultate v stilu:
| rezultat | procesor @frekvenca, grafična kartica @frekvenca, OS, RAM
Tako to gre.
particle ::
9.02 | i7 3770K@4500MHz, GTX660ti (stock), Windows 8 Pro 64bit
GenZNPC ::
Jaz sem pa moral sistem stabilizirat, ker mi je danes dopoldan zamrznil :D
Novi rezultati:
 Richland
Richland
Nova lestvica:
CPU Score @ Cinebench 11.5 ( CPU stock )
1. | 25.29 | 2x Xeon E5-2687W z HT, GeForce 9500GT, Windows 7 (64bit), 8GB
2. | 7.47 | Intel i7 3770k z HT, GeForce GTX 660Ti, Windows 7 (64bit), 8GB
3. | 6.00 | Intel i5 3570k brez HT, GeForce GTX 560Ti, Windows 7 (64bit), 8GB
4. | 5.69 | Intel i5 3570k brez HT, AMD HD 7950 OC, Windows 7 (64bit), 16GB
5. | 5.29 | Intel i5 3450 brez HT, AMD HD 7850, Windows 7 (64bit), 12GB
6. | 5.59 | AMD FX-8120, GeForce GTX 660Ti, Windows 7 64-bit
7. | 4.85 | Intel i7 920 z HT, AMD HD 4950, Windows 7 64-bit, 6gb
8. | 4.09 | 2× Xeon 5320 brez HT, AMD HD 6800, Windows 8 64-bit, 4gb
9. | 3.55 | AMD A8-3870, AMD HD 6670, Windows 7 (64bit), 8GB
10. | 3.26 | AMD Phenom II 955BE , AMD HD 5780 (stock), Windows 7 64-bit, 8gb
11. | 3.25 | Intel C2E Q6850 brez HT, AMD HD 4870 X2 (stock), Windows 7 64-bit, 4gb
12. | 2.01 | 2× Xeon 5120 brez HT, AMD HD 6850, Windows 8 64-bit, 4gb
13. | 1.80 | Intel C2D E8500 brez HT, AMD HD 4870 (stock), Windows 7 64-bit, 4gb
14. | 1.35 | Intel C2D P8400 brez HT, GeForce 9700M GT (stock), Windows 7 64-bit, 4gb
15. | 0.28 | Intel Celeron 2,8 brez HT, Generic, Windows 7 32-bit
16. ...
GPU Score @ Cinebench 11.5 ( GPU stock )
1. | 99.8 | AMD HD 6970 crossfire, Intel i5 2500k @4500MHz brez HT, Windows 7 64-bit, 8GB
2. | 86.5 | AMD HD 7950 (stock), Intel i5 2500K @ 4500MHz brez HT, Windows 7 64-bit, 8GB
3. | 80.3 | AMD HD 7850 (stock), FX-8320 @4500MHz, Windows 7 64-bit, 8GB
4. | 77.5 | AMD HD 7950, Intel i5 3570k (stock) brez HT, Windows 7 (64bit), 16GB
5. | 68.5 | AMD HD 7850, Intel i5 3450 (stock) brez HT, Windows 7 (64bit), 12GB
6. | 56.8 | GeForce GTX 660Ti, Intel i7 3770k @4400Mhz z HT, Windows 7 (64bit)
7. | 56.8 | GeForce GTX 560Ti, AMD FX-8350 @4500MHz 4C/8T, Windows 7 (64bit)
8. | 53.7 | AMD HD 5780 (stock), AMD Phenom II 955BE (stock), Windows 7 64-bit, 8GB
9. | 52.0 | AMD HD 4950, Intel i7 920 z HT,, Windows 7 64-bit, 6GB
10. | 47.5 | AMD HD 6670, AMD A8-3870 (stock), Windows 7 64-bit, 8GB
12. | 45.8 | AMD HD 4870 (stock),Intel C2D E8500 (stock) brez HT, Windows 7 64-bit, 4gb
13. | 44.4 | GeForce GTX 660Ti, AMD FX-8120, Windows 7 64-bit
14. | 42.2 | AMD HD 4870 X2 (stock), Intel C2E Q6850 (stock) brez HT, Windows 7 64-bit, 4gb
15. | 28.0 | AMD HD 6850, 2× Xeon E5320 (stock) brez HT, Windows 8 64-bit, 4gb
16. | 27.8 | GeForce GTX 260 (stock), Intel C2Q Q8200 (stock) brez HT, Windows 7 64-bit, ?GB
17. | 27.4 | AMD HD 6850, 2× Xeon 5120 (stock) brez HT, Windows 8 64-bit, 4gb
18. | 15.3 | GeForce 9700M GT (stock), Intel C2D P8400 (stock) brez HT, Windows 7 64-bit, 4GB
19. ...
CPU Score @ Cinebench 11.5 ( OC )
1. | 13.00 | Intel i7 3960X @4500Mhz z HT, GeForce GTX 680 SLI, Windows 7 (64bit), 32GB | eDDi |
2. | 9.02 | Intel i7 3770k @4500Mhz z HT, GeForce GTX 660Ti, Windows 8 (64bit), | Peshkeer |
3. | 8.72 | AMD FX-8350 @5200MHz 4C/8T, GeForce GTX 560Ti, Windows 7 64-bit, 8GB | BigSexy |
4. | 8.62 | Intel i5 3570k @5200Mhz brez HT, GeForce GTX 560Ti, Windows 7 (64bit), 8GB | glaš |
5. | 8.50 | Intel i5 3570K @5100MHz brez HT, AMD HD 5800 (stock), Windows 7 64-bit, 8GB | Dr M |
6. | 8.20 | AMD FX-8320 @4740MHz, AMD HD 7850 (stock), Windows 7 64-bit, 8GB | fr4nc |
7. | 7.53 | AMD Phenom II X6 1075T @4214MHz , XXX XXXX XXXXXXX, Windows 7 64bit, 4GB | Dr M |
8. | 7.52 | AMD FX-8120 @4700MHz, AMD HD 7850 (stock), Windows 7 64-bit, 8GB | fr4nc |
9. | 7.20 | Intel i5 2500k @4500MHz, AMD HD 6970 crossfire, Windows 7 64-bit, 8GB | vaščan |
10. | 7.17 | Intel i5 3570K @4500MHz, AMD HD 7850 (stock), Windows 7 64-bit, 8GB | fr4nc |
11. | 7.02 | Intel i5 2500K @4500MHz brez HT, AMD HD 7950 (stock), Windows 7 64-bit, ?GB | freesty |
12. | 5.59 | AMD FX-8120 @3500MHz, GeForce GTX 660Ti, Windows 7 64-bit | barocco |
13. | 4.06 | Intel C2Q Q9550 @3400MHz brez HT, AMD HD 4600 (stock), Windows 7 64-bit, 4gb | axee |
14. | 4.02 | AMD A10-6800K @4725Mhz, AMD HD 8670D @1169, Windows 7 64-bit, 8gb | m0LN4r |
15. | 3.35 | Intel C2Q Q8200 @3000MHz brez HT, GeForce GTX 260 (stock), Windows 7 64-bit, 4gb | kuglvinkl
16. | 2.30 | Intel Xeon 5120 @2100Mhz brez HT, AMD HD 6850 (850/1200), Windows 7 64-bit, 4gb | einstein :P |
17. ...
GPU Score @ Cinebench 11.5 ( OC )
2. | 50.3 | AMD HD 8670D @1169, AMD A10-6800K @4725Mhz, Windows 7 64-bit, 8gb | m0LN4r |
1. | 32.6 | AMD HD 6850 (850/1200), Intel Xeon 5120 @ 1860Mhz brez HT, Windows 7 64-bit, 8GB | einstein :P
3. ...
Upam, da tisti, ko imate mate stabilen sistem. Jaz sem tudi mislil da je stabilen, dokler nisem pri occtju v ozadju še zalaufal unigine z minimalnimi detajli, da je še grafo grelo v cpuju. Temperatura je zrastla iz 68C na 75C.
skibidi
particle ::
Sem probal še na 4,6GHz, ni ravno "stable" ker se temperature povzpejo na 80, vendar je še vedno rezultat! Na 4,7 mu je pa +0.125V premalo, pa ne bom višal zaradi temeratur. Delidat se mi pa tud ne gre :)
9.22 | i7 3770K@4600MHz, GTX660ti (stock), 8GB, Windows 8 Pro 64bit
wate ::
@Peshkeer: za tok kratek bench greš lahko tud do 100C.
10.01 | Intel i7 3770K @4949Mhz z HT, Geforce 650 GTX, 16GB 2400 MHz, Windows 7 64-bit
Temperatura max 94C, hlajenje Zalman LQ 310 - priporočam.
drugače pa 9.12 z 24/7 @4500MHz.
GenZNPC ::
Jaz sem mislil, da je moj amd stabilen pa mi occt po 3,5 urah najde napako. Predvidevam, da vam že v prvih parih minutah al?
skibidi
wate ::
Kok je sistem stabilen sploh ne gledam, verjetno ni. Važno da zmore bench in da je score čim višji.
Za vsakodnevno uporabo je pa seveda stabilnost prvi pogoj.
BlackMaX ::
Ali ima kdo slučajno GTX 780 ti, da vidimo score?
Assass1n ::
Nimam, drugace pa tukaj stabilnost sistema nima veze, score in to je to, kva se pol matrajo iz dušikom pa ledom :)
GenZNPC ::
Tako čist mimogrede par let novejši program/bench z izpiljenim render enginom (iz R14) in bolj kompleksno sceno:
Cinebench R15 CPU/GPU
skibidi
1 2
3
H1Z1
Oddelek: Igre
335670 (3002) oo7
Slo-Tech 3D Team: Blender Cycles 2.61 Benchmark
Oddelek: Navijanje
112424 (2254) 2loud4u
