SOF2 kode
SOF2 kode
Mr. ::
Ali kdo ve kam se vpiše kode za igro SOF2 ?
speed machine ::
Če me spomin ne vara v konzolo. Probi tipko nad tab v igri, pa če ne prime še kak alt zraven. Sam nisem pa 100%, ker je že dolg od tega kar sem špilu.
Dj-Prah ::
shift+tildo (tipka pred 1):\
Intel Celeron 1000Mhz@1400Mhz-Vulcano 9,Hercules 3D Prophet 8500LE 128MB DDR TV/DVI,512MB SDRAM,Asus CUSL2-C Black Pearl
PiKi ::
Depending on your game version, there are multiple ways to activate cheat mode:
Method 1: Press ~ to display the console window. Type "setrandom sv_cheats 1" and press [Enter] to enable cheat mode.
Method 2: Display the console window and type "sv_cheats 1" (case-sensitive) and press [Enter]. You can also type "devmap [map name]" to load a specific map and have the cheats enabled once it has completed loading. Note: "sv_cheats 1" is write protected in the regular single player game. You need to load a map first by using the map or devmap command. For example, start the game, press ~, then type "map pra1" or "devmap pra1" at the console window and press [Enter]. When the map loads, enter "sv_cheats 1" and press [Enter] to enable cheat mode.
Method 3: Start the game with the "[drive and folder path]\SOF2\SoF2.EXE +set sv_cheats 1" command to enable cheat mode. Note: The next step involves editing a game file; create a backup copy of the file before proceeding. Use a text editor to edit the "myconfig.cfg" file in the "base" folder in the game folder. Search for the "toggleconsole" entry in the file. Bind any desired key to that command. For example:
bind X "toggleconsole"
Return to Castle Wolfenstein - kako dalje ?
Oddelek: Igre
313687 (2042) MaticKregar
Quake 3 TA
Oddelek: Igre
292197 (1692) no at
Wolfenstein - RTC (Return to Castle)
Oddelek: Igre
243172 (1787) Hooligan#1
SOF2 in GTA3 cheats
Oddelek: Igre
254254 (3569) Dj-Prah
Return To Castle Wolfenstein (strani: 1 2 )
Oddelek: Igre
586848 (5716) LunKi
