Forum » Igre » Return to Castle Wolfenstein - kako dalje ?
Dusan_HD ::
Hi. Return to Castle Wolfenstein je trenutno moj problem.
V misiji 2 : Dark Secret, part 4: the defiled church. to je v tisti propadajoci cerkvi. ne morem dalje od tistega gromozanskega izmecka. s cim se ga ubije ?
prosim
raY_
prosim
raY_
daSKAn ::
Ja to bi blo nekako tako! Jest sm pr tisti grozoti uporabu taktiko "The Chicken"!
Mal sm ga strelu ko se mi je priblizou sm laufu nazaj s tam kjer sm prsu ker tam ni mogu it! Pa sm mu uletavu in sitnaru k podrepna muha in vrag je podlegel
spucek ::
Bogi Ray_!Ti še veš ne kaj te čaka
.Če ne prej se boš pa spet pr zadnjem šefu oglasil
Previdnost je mati modrosti.
Ziga Dolhar ::
Ehh, men je največji problem delala ona stopnja skoraj pred koncem, ko te nekje ob enih razvalinah napadeta dva übersoldata... ampak zadnji šef, jok... z vsakim posamičnim übersoldatom sem imel več problemov kot z finalno zalego!
Ziga Dolhar ::
Ja, sam ko sem hotel it iskat municijo, me je pa drugi übersoldat začel v hrbet nažigat :))))
vuego ::
Tista dva ubersoldata nista težka... Samo nabiraš kroge (laufaš okol) in šicaš. Mene nista zadela niti enkrat...
Boro ::
A MOGOČE KER VE, KAKO AKTIVIRAŠ KODE V TEJ IGRI ( DA SI NESMRTEN IN TAK NAPREJ NAPREJ HAHAHAHA)????
freejack ::
Return to Castle Wolfenstein Map Names
Enable codes with shortcut modification: + set sv_cheats 1
Go to console (~ key)
Use the command: /spdevmap "mapname" (without quotes)
(When you jump to a map you must use cheats to give yourself weapons because you start the map with none.)
Mapnames
escape1
escape2
tram
village1
village2
crypt1
crypt2
church
boss1
forest
rocket
dam
chateau
dark
dig
castle
end
beach
village
boss2
rocket
baseout
assault
factory
trainyard
norway
xlabs
wine
wine2
wine3
Cheats
Create a shortcut on your desk top. Right click it and select properties, then change the "target" line by adding the following:
+ set sv_cheats 1
Click OK, then start the game using the desktop shortcut.
When in the Game press the tilde key (~) and you can enter the following cheats:
/god god mode
/notarget enemies will not fire at you
/noclip walk thru walls
/give all all weapons
/give armor Give Armor
/give health Give Health
/give stamina Give Stamina
/nofatigue Unlimited Stamina
/cg_uselessnostalgia 1 Original Wolfenstein Interface
/kill Suicide
You must start a game and save it than restart it before they will work, OR load a saved game and you'll be able to use them.
Console Commands
Press '~' key to bring down the console.
Type /cmdlist to show all commands.
/name to change your player name. You can change the color of individual characters using the ^# (where # is 1-9) command as follows:
1 Red
2 Green
3 Yellow
4 Blue
5 Light Blue
6 Pink
7 White
8 Black
9 Red
/reconnect
Reconnect to last server.
/kill
Suicide.
/quit
Exit.
/serverinfo
Shows current server settings.
/toggle r_fullscreen
Will toggle between windowed and full screen mode. You must restart the game each time it's changed.
/toggle cg_drawcompass
Toggles the compass on or off.
/toggle cg_draw2d
Toggle HUD on-off.
/toggle cg_drawfps
Show or hide FPS.
/cg_FOV
Change Field of View. Experiment with as desired.
/toggle cg_drawtimer
Show time left.
/toggle cg_gibs
Toggle gibs.
/toggle cg_drawteamoverlay
Toggle team overlays.
Server Admin Commands
/map restart
Reset map.
/sv_maxclients ##
Set the max number of players that can connect.
/timelimit ##
Set time limit to ## minutes.
/kick player_name
Kicks the player from the server.
/g_friendlyFire #
Sets friendly fire to either off 0 or on 1.
/g_forcebalance
Force even teams.
/g_warmup ##
Set warm up time to ## secs.
/g_gravity ###
Sets gravity to ###. Lower = less gravity.
/g_speed ###
Sets movement to ###. Lower = slower.
Mapnames
escape1
escape2
tram
village1
village2
crypt1
crypt2
church
boss1
forest
rocket
dam
chateau
dark
dig
castle
end
beach
village
boss2
rocket
baseout
assault
factory
trainyard
norway
xlabs
wine
wine2
wine3
Cheats
+ set sv_cheats 1
/god god mode
/kill Suicide
Console Commands
1 Red
2 Green
3 Yellow
4 Blue
5 Light Blue
6 Pink
7 White
8 Black
9 Red
/reconnect
/kill
Suicide.
/quit
Exit.
/serverinfo
/toggle cg_draw2d
Toggle HUD on-off.
/toggle cg_drawfps
Show or hide FPS.
/cg_FOV
Show time left.
/toggle cg_gibs
Toggle gibs.
/map restart
Reset map.
/sv_maxclients ##
/timelimit ##
/kick player_name
/g_friendlyFire #
/g_forcebalance
Force even teams.
/g_warmup ##
/g_gravity ###
/g_speed ###
freejack ::
Men še na najtežji stopnji niso kos, kaj da bi se s čim drugim ubadal, je pa res, da moreš bit previden, če ne lahko kr hitro končaš igro.Uff kk je lepo, ko se potihoma priplaziš švabu za hrbet, vzameš nož in ga štihneš. Hitro, učinkovito, neslišno. My kinda game.
mlakar ::
A mi lahko en pove kva nardit pri Mission 3: Weapons of vengeane Part 1: Forest compound. Kva nej nardem, zmer k not pridm začne alarm tult? Pa sm že use probu pa se zmer tist pof**** alarm sprož ???
BaRtMaN ::
God damn it folk! Na gamefaqs.com so rešitve in to stran si vtisnite v spomin, da ne sprašujete vedno kako naprej!
Boro ::
Sam nažigaš naj z vsem možnim in razpolagajočim orožjem!! Kaj boš pa pol šele delal pri Uber Soldatih, pa na koncu pri Heinrichu????
Jaz sem ga že obrnil - brez kode!!
spucek ::
Pa ne smete obupat!Sj men je tut ratalo šele v tretjem poskusu!
freejack ::
Hja, ljudje so očitno narejeni za iger kova Resnega Samota, kjer streljaš do onemoglosti, pol pa še 2x tolk.Če piše, da se alarm ne sme oglasit, pol se to tut zihr da narest. Ne brezlavo letat sem in tja in upam, da boš vse pobil preden boš zaslišal alarm. Lepo se ustavi, opazuj ljudi, kje hodijo, kam gledajo, čakaj na trenutek in ga izkoristi. Jst v celi igri nisem zakrivil niti enega alarma zaradi površnosti, le v primerih, da res ni šlo drugače. Razen tega da besno letiš proti naciju in mu nasuješ cel zaboj metkov, se mu raje priplazi za hrbet in mu pokaži kaj zmore nož. Tudi to ima svoj čar. Wolfenstein mi je všeč ravno zaradi tega, da moraš celo razmišljati kako in kaj, saj z brezglavim streljanjem aka Samo Resnik ne boš prišel daleč.
spucek ::
Ja to je blo ful kul,da je blo treba se kdaj pa kdaj ustavit in razmislit kaj in kako.A stil komadosov pa le ne sme bit!
Dusan_HD ::
Ojej!
6,5 let staro mojo temo ste načeli. Pa kaj vam je??
A si moram igrico nazaj zinštalirat?
raY_
ahac ::
Če takrat nisi znal naprej potem zdaj inštaliraj in končaj.
MaticKregar ::
A kdo ve kako bi usposobil to igro na windows 8? Dobim open gl error, ko zvišam resolucijo na 1600, če pa dam na 1200 pa se mi vse raztegne čez cel ekran. Compatibilty sem tudi probal, prav tako nek neuraden patch, s katerim naj bi delalo na novejših winsih...
- spremenil: MaticKregar ()
| » | Quake 3 TAOddelek: Igre | 2197 (1692) | no at |
| » | Wolfenstein - RTC (Return to Castle)Oddelek: Igre | 3172 (1787) | Hooligan#1 |
| » | Problem z zagonom iger RTCW in MOHAAOddelek: Igre | 3120 (2804) | Flay |
| » | SOF2 in GTA3 cheatsOddelek: Igre | 4254 (3569) | Dj-Prah |
| » | Return To Castle Wolfenstein (strani: 1 2 )Oddelek: Igre | 6848 (5716) | LunKi |
