Forum » Programiranje » [Android]ListView tezava
KernelPanic ::
Spostovani!
A mi lahko kdo pomaga, ker na telefonu niti na simulatorju ne morem prikazati ListActivity! Pocasi obupujem, Tukaj sta xml datoteki:
<?xml version="1.0" encoding="utf-8"?>
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
android:orientation="vertical"
android:layout_width="fill_parent"
android:layout_height="fill_parent">
<ListView android:id="@android:id/list"
android:background="#00FF00"
android:layout_weight="1"
android:drawSelectorOnTop="false"
</LinearLayout>ter <?xml version="1.0" encoding="utf-8"?>
<LinearLayout
android:orientation="horizontal"
android:padding="10dp">
<ImageView android:id="@+id/item_mainscreen_image"
android:layout_width="wrap_content"
android:gravity="center_vertical"
android:layout_alignParentTop="true"
android:layout_alignParentBottom="true"
android:layout_marginRight="15dp"
android:layout_marginTop="5dp"
android:layout_marginBottom="5dp"
<TextView android:id="@+id/item_mainscreen_text"
android:textStyle="bold"
android:textSize="22dp"
android:textColor="#000000"
</LinearLayout>Tukaj je koda: /*
* To change this template, choose Tools | Templates
* and open the template in the editor.
package com.test;
import android.app.AlertDialog;
import android.app.Dialog;
import android.app.ListActivity;
import android.content.DialogInterface;
import android.os.Bundle;
import android.util.Log;
import android.view.View;
import android.widget.ListView;
import android.widget.Toast;
* @author user
public class CActivityMainScreen extends ListActivity
private static final String m_strLogTag="CActivityMainScreen";
private static final CItemMainScreen[] items=new CItemMainScreen[3];
private static final int DIALOG_PRODUCT_SEARCH=1;
private static final int DIALOG_SHOPPING_CART=2;
private static final int DIALOG_ABOUT_APPLICATION=3;
private static final CharSequence[] itemsProductSearch={
"Item0",
"Item1",
"Item2"
private void initItems()
CActivityMainScreen.items[0]=new CItemMainScreen("",
"Izbira1");
CActivityMainScreen.items[1]=new CItemMainScreen("",
"Izbira2");
CActivityMainScreen.items[2]=new CItemMainScreen("",
"Izbira3");
} // initItems
@Override
public void onCreate(Bundle icicle)
try
super.onCreate(icicle);
ListView mainScreenListView=this.getListView();
this.initItems();
mainScreenListView.setAdapter(new CItemMainScreenAdapter(this,
R.layout.citemmainscreen,
items));
catch(Exception ex)
String strClassName=ex.getClass().getName().toString();
String strMessage=ex.getMessage().toString();
Log.wtf(CActivityMainScreen.m_strLogTag,
strClassName+":"+
strMessage);
finally
} // try-catch-finally
} // onCreate
@Override
public void onListItemClick(ListView parent,
View v,
int position,
long id)
} // onListItemClick
@Override
protected Dialog onCreateDialog(int id)
switch(id)
case CActivityMainScreen.DIALOG_PRODUCT_SEARCH:
AlertDialog.Builder adb=this.buildAlertDialog("Izberite nacin iskanja",
itemsProductSearch);
AlertDialog ad=adb.create();
break;
case CActivityMainScreen.DIALOG_SHOPPING_CART:
break;
case CActivityMainScreen.DIALOG_ABOUT_APPLICATION:
break;
default:
return null;
} // switch
return null;
} // onCreateDialog
private AlertDialog.Builder buildAlertDialog(final String title,
final CharSequence[] items)
try
AlertDialog.Builder adb=new AlertDialog.Builder(this);
adb.setTitle(title);
adb.setSingleChoiceItems(itemsProductSearch,
-1,
new DialogInterface.OnClickListener()
public void onClick(DialogInterface dialog,
int item)
Toast.makeText(getApplicationContext(),
itemsProductSearch[item],
Toast.LENGTH_SHORT).show();
return adb;
catch(Exception ex)
strClassName+":"+
strMessage);
return null;
} // buildAlertDialog
}. Kaj je narobe, prosim vas za pomoc, ker obupujem!!!!!! Vredno ogleda ...
| » | Android - ZačetnikOddelek: Programiranje | 2219 (1544) | hurlimannxt |
| » | android črtaOddelek: Programiranje | 2970 (2241) | g333kk |
| » | [android] vstavljanje slikeOddelek: Programiranje | 1660 (1557) | messi |
| » | [android] crashOddelek: Programiranje | 1817 (1626) | messi |
| » | [Android]Cudno obnasanje aplikacije in emulatorjaOddelek: Programiranje | 1666 (1495) | KernelPanic |
