DNS nima podatka - od kje dobim IP?
twom ::
Naprava dobi IP naslov od DHCP serverja.
Naprava ni v workgroupi, zato DNS server nima hostname-a v svoji bazi.
Z mojega računalnika lahko pingam in dostopam do naprave preko hostname-a, dočim ostali računalniki pa ne.
Kako lahko ugotovim, kje se mi resolva hostname?
V C:/Windows/System32/Drivers/etc (hosts, lmhosts.sam) ni nič.
Lep pozdrav,
Peter
P.S. googla ne znam vprašati tako, da bi dobil odgovore na moj problem ...
ipconfig /all
Boš dobil vse potrebne podatke.
twom ::
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation.  All rights reserved.
C:\>ipconfig /all
Windows IP Configuration
   Host Name . . . . . . . . . . . . : USER
   Primary Dns Suffix  . . . . . . . : XXXX.global.vpn
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
   DNS Suffix Search List. . . . . . : XXXX.global.vpn
                                       YYYY.global.vpn
                                       global.vpn
Ethernet adapter Local Area Connection* 19:
   Media State . . . . . . . . . . . : Media disconnected
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : Juniper Network Connect Virtual Adapter
   Physical Address. . . . . . . . . : 00-FF-30-59-8A-06
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
Ethernet adapter NIC:
   Connection-specific DNS Suffix  . : XXXX.global.vpn
   Description . . . . . . . . . . . : Intel(R) 82567LM Gigabit Network Connection
   Physical Address. . . . . . . . . : 00-24-E8-D3-70-EC
   IPv4 Address. . . . . . . . . . . : 192.168.180.53(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : 8. maj 2012 7:10:19
   Lease Expires . . . . . . . . . . : 12. maj 2012 7:10:05
   Default Gateway . . . . . . . . . : 192.168.180.1
   DHCP Server . . . . . . . . . . . : 192.168.180.20
   DNS Servers . . . . . . . . . . . : 192.168.180.20
   Primary WINS Server . . . . . . . : 192.168.180.20
   Secondary WINS Server . . . . . . : 192.168.180.8
                                       192.168.180.24
   NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter VMware Network Adapter VMnet1:
   Description . . . . . . . . . . . : VMware Virtual Ethernet Adapter for VMnet1
   Physical Address. . . . . . . . . : 00-50-56-C0-00-01
   DHCP Enabled. . . . . . . . . . . : No
   IPv4 Address. . . . . . . . . . . : 192.168.157.1(Preferred)
Ethernet adapter VMware Network Adapter VMnet8:
   Description . . . . . . . . . . . : VMware Virtual Ethernet Adapter for VMnet8
   Physical Address. . . . . . . . . : 00-50-56-C0-00-08
   IPv4 Address. . . . . . . . . . . : 192.168.18.1(Preferred)
Ethernet adapter VirtualBox Host-Only Network:
   Description . . . . . . . . . . . : VirtualBox Host-Only Ethernet Adapter
   Physical Address. . . . . . . . . : 08-00-27-00-E8-1F
   IPv4 Address. . . . . . . . . . . : 192.168.56.1(Preferred)
C:\>
To je moj ipconfig /all
Tam imaš entry DHCP/DNS server. Tam ti resolva ... In tisti IP ti je določil tvoj IP.
  • spremenil: Invictus ()
twom ::
DNS (preverjeno) ne vsebuje tega podatka,
prav tako noben drug računalnik ne resolva hostname-a razen mojega...
Kako naprej?
Fish88 ::
Mislim da hostname spremeni v netbios name in pol broadcasta po localni mreži. Probaj ukaz nbtstat v cmdju
twom ::
C:\>nbtstat -c
NIC:
Node IpAddress: [192.168.180.53] Scope Id: []
                  NetBIOS Remote Cache Name Table
        Name              Type       Host Address    Life [sec]
    WEBTEMP_20011  <00>  UNIQUE          192.168.180.98      545
    WEBTEMP_20017  <00>  UNIQUE          192.168.180.85      190
C:\>
Od kje pa NetBIOS popolni svojo tabelo, oziroma kako?
Ob prvem izpisu "nbtstat -c" je bil v tabeli samo WEBTEMP_20017.
Po pinganju 192.168.180.98 pa je "nbtstat -c" izpisal oba.
Fish88 ::
Načinov je več. V tvojem primeru pa kot sem že rekel verjetno spremeni hostname v netbios name in pol broadcasta po lokalni mreži: naj mi odgovori tisti, ki ima tak netbios name. Tako dobi njegov ip.
Probaj še nbtstat -n pa nbtstat -c.
  • spremenilo: Fish88 ()
twom ::
Mislim da razumem... (hostname dobi od ping-a)
DHCP strežnik določi IP
DNS strežnik NE zabeleži hostname-a (morda zaradi neprimernega imena, domene, etc)
Po restartu računalnika je NetBIOS prazen.
"ping hostname" vrne neznano
"ping ip_naslov" vrne zadetek in naredi vpis v NetBIOS, če sta v istem VLAN-u
Za vpis v NetBIOS morata biti računalnik in naprava v istem VLAN-u, drugače se hostname ne prenese.
Od tu naprej lahko delam z IP naslovom ali hostname-om.
Seveda pa moram najprej dobiti IP.
Tu mi lahko pomaga Wireshark, ali pa IT-jevec, ki pogleda po MAC naslovu ...
  • spremenil: twom ()
Fish88 ::
Čudno da moraš najprej pingati ip, da lahko potem pingaš hostname. Jaz lahko takoj po restartu pingam hostname in dobim odgovor.
Drugače pa ja napravi morata biti v istem VLANu. Pa hostname mislem, da nesme biti večji od 15 znakov pa nesme vsebovati pike (.), če hočeš da ga spremeni v Netbios name.
twom ::
Imaš prav,
malo prehitro in površno sem pisal.
Ping deluje na hostname in na ip_address, edino NetBIOS tabelo popolne samo "ping hostname", oziroma "ping ip_address" mi ni osvežil NetBIOS tabele.
VLAN in NetBIOS nimata veze. Sta popolnoma druga porotokola, ki delujeta tudi na drugih OSI nivojih (2 in 3).
Če imaš računalnike v različnih VLANih, morata biti VLANa med seboj povezana preko routerja, kjer je za vsak VLAN določen svoj IP subnet in routing. Če tega ni, se računalniki v različnih VLANih ne vidijo med seboj.
Očitno nimate mreže poštimane, ker so to povsem začetniški problemi. Mogoče imate pa samo router narobe nastavljen.
Sam če imate DNS strežnik v mreži, je uporaba NetBIOSa precej stara zadeva za resolvanje imen. Precej napačna tudi glede na standarde. Deluje pa.
Fish88 ::
@Invictus: Vem da je vsak VLAN v svojem subnetu in, da rabimo router oz. drugo layer 3 napravo, da se računalniki v različnih VLANih vidijo med seboj. Ampak peter tega tukaj ni spraševal. Rekel sem mu samo, da ko ti pingaš nek hostname v lokalni mreži, da je ena izmed možnosti ta, da mu windows spremeni ta hostname v netbios name in pol broadcasta. Broadcast pa pride samo do uporabnikov v istem VLANu ane :)
Sem samo omenil da ima večji problem v mreži kot samo neresovanje nekih hostnameov.
Če ima v mreži DNS strežnik, se le tega uporablja za to. Celo MS NetBIOS drži samo zaradi kompatibilnosti s starimi škatlami.
Ni nujno da se v istem VLANu broadcasti širijo. Lahko jih blokiraš z access listo ;).
Fish88 ::
Poznam access-liste ;) Ampak tole je tukaj že malo offtopic se ti ne zdi? :) Peter je napisal, da DNS nima hostnameov v svoji bazi in sem zato omenil tole z Netbiosom :)
Malo res ...
Ampak če hostnamov nima v DNS bazi, naj jih vpiše noter. Oz. bi mu jih vpisal DHCP strežnik. Ko bo povedal malo več, mu bomo lahko bolj pomagali.
Seveda imajo lahko računalniki statične IP naslove, pol jih pa v DNSju ne bo.
Naj se izjasni kaj sploh ima ...
VMware Player - DNS server zmešan
Oddelek: Programska oprema
226986 (6555) AndrejO
Spor naslovov IP (strani: 1 2 )
6615452 (14228) turob2
Problem z internetom
473818 (3369) RuskiSnajper
Problem router/mordem
Oddelek: Omrežja in internet
153201 (2888) gorenjc
vista in dve mrežni kartici - problem
63055 (2881) sosko1
