(10053) Software caused connection abort
AngelOfDeath ::
Odkar sem začel uporabljat emule mi irc vsakih 10min prekine povezavo s sledečim errorjem: (10053) Software caused connection abort
Edino kar sem na internetu našel je to:
Question/Problem: WSAECONNABORTED (10053) Software caused connection abort.
Answer/Solution: A connection abort was caused internal to your host machine. The software caused a connection abort because there is no space on the socket's queue and the socket cannot receive further connections.
WinSock description: The error can occur when the local network system aborts a connection. This would occur if WinSock aborts an established connection after data retransmission fails (receiver never acknowledges data sent on a datastream socket).
TCP/IP scenario: A connection will timeout if the local system doesn't receive an (ACK)nowledgement for data sent. It would also timeout if a (FIN)ish TCP packet is not ACK'd (and even if the FIN is ACK'd, it will eventually timeout if a FIN is not returned).
Slučajno kdo ve kako to odpravit da bi lahko uporabljal emulo in irc naenkrat ?
Andrej ?
AngelOfDeath ::
Kot kaže sem odkril delni vzrok:
v dodatnih nastavitvah
max. novih povezav / 5s
sem znižal in error se je premaknil za par ur ...
Problem z mIRCem
Oddelek: Programska oprema
121837 (1837) YdoIPonU
IRC problem (firewall blokira po določenem času)
Oddelek: Omrežja in internet
71374 (1286) kklemenss
[10053] Software caused connection abort IRC
81350 (1244) planetparty
mIRC > * [10053] Software caused connection abort ?
81275 (1206) mare87
DCC deluje ne spljoh.
81318 (1193) Simulacrum
