Forum » Loža » test politične usmerjenosti
gendale ::
http://politicaltest.net/
da malo vidimo, kaj je razširjeno na stju
moje
You are a cosmopolitan Social Democrat. 15 percent of the test participators are in the same category and 35 percent are more extremist than you.
moje
http://pastebin.com/QiWny5dV
Bananovec ::
Po eni tretini sem test skenslal, saj sem na vsa vprašanja odgovoril nevtralno.
Regards, Apple
Regards, Apple
djordjevic ::
You are a Liberal. 4 percent of the test participators are in the same category and 64 percent are more extremist than you.
IceIceBaby ::
Blinder ::
haha fašist da sem
You are a Leftist-Fascist. 4 percent of the test participators are in the same category and 88 percent are more extremist than you.
Bananovec ::
You are a bourgeois patriot. 5 percent of the test participators are in the same category and 99 percent are more extremist than you.
Ne me hecat, patriot pa že nisem.
Regards, Apple
Regards, Apple
garamond ::
You are a cosmopolitan Social Democrat. 15 percent of the test participators are in the same category and 88 percent are more extremist than you.
djordjevic ::
Test je itak namenjen Američanom...
Tale se mi zdi precej bolj nevtralen od tistega, ki smo ga reševali pred časom, in kot tak primeren tudi za nas.
garamond ::
djordjevic je izjavil:
No, jaz ga verjetno nisem reševal (se ne spomnim). Sicer pa me je zmotilo le kakšno redko vprašanje.
marijancek ::
Qcube ::
garamond ::
Marat ::
PaX_MaN ::
marijancek ::
IceIceBaby je izjavil:
Kakšna pa je razlika med liberal in neoliberal?
kakor jaz razumem je neoliberalizem bolj usmerjen v svetovno konkurenco.
Bananovec ::
Test je kvazimazi za tuji trg.
Regards, Apple
Regards, Apple
cekr ::
Arto ::
nevone ::
You are a neoliberal Democrat. 6 percent of the test participators are in the same category and 64 percent are more extremist than you.
o+ nevone
o+ nevone
Yohan del Sud ::
Sicer koga briga, ampak tle je še moj rezultat:
Je pomojem treba štet, da gliha v kup štriha, zato imamo tudi podobne rezultate, ker slotechovci imamo bržkone podobna prepričanja ...
www.strancar.com
Grumf ::
Odvisno kaj imaš za podobno, meni nič kaj na desno ne vleče...
http://www.politicaltest.net/test/resul...
Human beings, who are almost unique in having the ability to learn from the
experience of others, are also remarkable for their apparent disinclination
to do so.
to do so.
- spremenil: Grumf ()
ZaphodBB ::
nUUb ::
You are a liberal patriot. 2 percent of the test participators are in the same category and 88 percent are more extremist than you.
i7 2600k@4.8GHz - nV 760 - 850 EVO 250GB - 4TB FreeNAS
ASUS 1920x1080@144Hz
zee ::
You are a liberal Cosmopolitan. 4 percent of the test participators are in the same category and 47 percent are more extremist than you.
zee
- spremenilo: zee ()
Pariah ::
You are a patriotic Social Democrat. 3 percent of the test participators are in the same category and 64 percent are more extremist than you. WTF?
|P8Z77-V PRO|,|i5 2500K|,|ASUS GTX780 DirectCUIIOC|,|2x4GB Corsair LP|,|H100|,
|Samsung 840/WD1002FAEX|,|Corsair TX850W|,|Fractal Design Arc|,|Win7 U 64bit|
- spremenil: Pariah ()
oldguy ::
XsenO ::
You are a social democratic Cosmopolitan. 13 percent of the test participators are in the same category and 57 percent are more extremist than you.
1 + 1 = 1
@nny ::
Levo, levo, ki te ljubim levo!
Čak, kdo me je že zmerjal z desničarko?
You are a cosmopolitan Social Democrat . 15 percent of the test participators are in the same category and 35 percent are more extremist than you.
- spremenila: @nny ()
koyotee ::
www.politicaltest.net/test/result/85639/
You are liberal cosmopolitan. 4 percent of the test participators are in the same category and 51% are more extremist than you.
Rear DVD collector!
JTD power!
JTD power!
Karaya 52 ::
Pred casom sem odprl kroniko moje vasi, na prvi strani je Titova slika, na drugi njemu posvecena pesem, potem pa gre tako dalje v isti maniri, dokler ne prides do zgodbe nekega vaskega posebneza, komunista (tako se je oznacil), ki ga je kler leta 37 preganjal zaradi naprednih idej. Tako da vidis, naprednez = komunist.
Takle mamo, precej smesna poimenovanja, vsak se ima za naprednega. V Delovi anketi, pred volitvami, je med naprednimi bila stranka TRS in Zares. Na drugi strani nicle v minusu pa SDS in DLGV, pod grafom pa je pisalo "fosilne stranke". Slo je za politiko do virov energije.
francek1 ::
You are a liberal patriot. 2 percent of the test participators are in the same category and 41 percent are more extremist than you.
s1m0n ::
Berserker ::
| » | Citati, ki vam kaj pomenijo (strani: 1 2 3 4 5 )Oddelek: Sedem umetnosti | 59753 (10323) | yansek |
| » | Še en osebnostni test?Oddelek: Loža | 6012 (4820) | piromanček |
| » | Draw A Pig Personality TestOddelek: Loža | 1686 (1353) | Avenger |
| » | Nov IQ Test na emode.comOddelek: Loža | 3407 (373) | VuLc4n0 |
| » | Personality test... (strani: 1 2 )Oddelek: Loža | 7744 (6620) | XShaeboX |
