test politične usmerjenosti
2
gendale ::
http://politicaltest.net/
da malo vidimo, kaj je razširjeno na stju
moje
You are a cosmopolitan Social Democrat. 15 percent of the test participators are in the same category and 35 percent are more extremist than you.
http://pastebin.com/QiWny5dV
Bananovec ::
Po eni tretini sem test skenslal, saj sem na vsa vprašanja odgovoril nevtralno.
Regards, Apple
nomad_soul ::
 me
me
djordjevic ::
You are a Liberal. 4 percent of the test participators are in the same category and 64 percent are more extremist than you.
IceIceBaby ::
You are a Liberal. 4 percent of the test participators are in the same category and 9 percent are more extremist than you.
Blinder ::
haha fašist da sem :))
You are a Leftist-Fascist. 4 percent of the test participators are in the same category and 88 percent are more extremist than you.
Bananovec ::
You are a bourgeois patriot. 5 percent of the test participators are in the same category and 99 percent are more extremist than you.
Ne me hecat, patriot pa že nisem.
Regards, Apple
black ice ::
Nimam ravno zaupanja v te teste. Odvisno je od situacije. (Rešil sem krajšo različico)
garamond ::
Test je itak namenjen Američanom...
You are an authoritarian Socialist. 1 percent of the test participators are in the same category and 93 percent are more extremist than you.
You are a cosmopolitan Social Democrat. 15 percent of the test participators are in the same category and 88 percent are more extremist than you.
djordjevic ::
garamond je izjavil:
Tale se mi zdi precej bolj nevtralen od tistega, ki smo ga reševali pred časom, in kot tak primeren tudi za nas.
garamond ::
djordjevic je izjavil:
No, jaz ga verjetno nisem reševal (se ne spomnim). Sicer pa me je zmotilo le kakšno redko vprašanje.
marijancek ::
Neoliberalec. Me je zadel. Najbolj napredna usmeritev po moje.
You are a neoliberal Democrat. 6 percent of the test participators are in the same category and 57 percent are more extremist than you.
Qcube ::
You are a social democratic Cosmopolitan. 13 percent of the test participators are in the same category and 68 percent are more extremist than you.
garamond ::
Sicer pa je na strani tudi statistika. Recimo za Slo-tech: Za [moške], [od 18 do 28 let], [Slovenija] in [vseh izobrazb] je tako povprečje:
Marat ::
You are a neoliberal Democrat. 6 percent of the test participators are in the same category and 51 percent are more extremist than you.
lol, kr neoliberalac sm >:D
IceIceBaby ::
Kakšna pa je razlika med liberal in neoliberal?
PaX_MaN ::
You are a neoliberal Democrat. 6 percent of the test participators are in the same category and 14 percent are more extremist than you.
marijancek ::
IceIceBaby je izjavil:
kakor jaz razumem je neoliberalizem bolj usmerjen v svetovno konkurenco.
Bananovec ::
Test je kvazimazi za tuji trg.
Regards, Apple
cekr ::
You are a National Liberal Democrat.
Arto ::
You are a cosmopolitan Social Democrat. 15 percent of the test participators are in the same category and 9 percent are more extremist than you.
nevone ::
You are a neoliberal Democrat. 6 percent of the test participators are in the same category and 64 percent are more extremist than you.
o+ nevone
Yohan del Sud ::
Sicer koga briga, ampak tle je še moj rezultat:
 tu
tu
Je pomojem treba štet, da gliha v kup štriha, zato imamo tudi podobne rezultate, ker slotechovci imamo bržkone podobna prepričanja ...
www.strancar.com
Grumf ::
Odvisno kaj imaš za podobno, meni nič kaj na desno ne vleče...
http://www.politicaltest.net/test/resul...
Human beings, who are almost unique in having the ability to learn from the
experience of others, are also remarkable for their apparent disinclination
to do so.
  • spremenil: Grumf ()
ZaphodBB ::
You are a liberal Cosmopolitan. 4 percent of the test participators are in the same category and 57 percent are more extremist than you.
34054 ::
Heh...
nUUb ::
You are a liberal patriot. 2 percent of the test participators are in the same category and 88 percent are more extremist than you.
i7 2600k@4.8GHz - nV 760 - 850 EVO 250GB - 4TB FreeNAS
ASUS 1920x1080@144Hz
zee ::
You are a liberal Cosmopolitan. 4 percent of the test participators are in the same category and 47 percent are more extremist than you.
8-)
zee
  • spremenilo: zee ()
Pariah ::
You are a patriotic Social Democrat. 3 percent of the test participators are in the same category and 64 percent are more extremist than you. WTF?
|P8Z77-V PRO|,|i5 2500K|,|ASUS GTX780 DirectCUIIOC|,|2x4GB Corsair LP|,|H100|,
|Samsung 840/WD1002FAEX|,|Corsair TX850W|,|Fractal Design Arc|,|Win7 U 64bit|
  • spremenil: Pariah ()
Trinitron ::
Me vleče v levo :P
RejZoR ::
Kje je opcija "I don't give a damn" ?
oldguy ::
Vprašanja dosti na nivoju, rezultati pa ne drugačni od pričakovanih.
You are a neoliberal Democrat. 6 percent of the test participators are in the same category and 25 percent are more extremist than you.
 slika
slika
sirotka ::
Hm, levičar da sem :)
energetik ::
Heh,
Nism vedu. :)
Karaya 52 ::
You are a democratic National Liberal.
Pogresam knof "emigrate" na koncu strani. >:D
chief ::
(krajsa verzija)
pa sem cist zmeden...ker nevem kaj to pomeni..
XsenO ::
You are a social democratic Cosmopolitan. 13 percent of the test participators are in the same category and 57 percent are more extremist than you.
1 + 1 = 1
@nny ::
Levo, levo, ki te ljubim levo! :) Čak, kdo me je že zmerjal z desničarko? :))
You are a cosmopolitan Social Democrat . 15 percent of the test participators are in the same category and 35 percent are more extremist than you.
  • spremenila: @nny ()
koyotee ::
www.politicaltest.net/test/result/85639/
You are liberal cosmopolitan. 4 percent of the test participators are in the same category and 51% are more extremist than you.
Rear DVD collector!
JTD power!
Marat ::
kakšna je pa razlika med visionary in reactionary? A to je kao napreden - konservativen?
Karaya 52 ::
Pred casom sem odprl kroniko moje vasi, na prvi strani je Titova slika, na drugi njemu posvecena pesem, potem pa gre tako dalje v isti maniri, dokler ne prides do zgodbe nekega vaskega posebneza, komunista (tako se je oznacil), ki ga je kler leta 37 preganjal zaradi naprednih idej. Tako da vidis, naprednez = komunist. :)) Takle mamo, precej smesna poimenovanja, vsak se ima za naprednega. V Delovi anketi, pred volitvami, je med naprednimi bila stranka TRS in Zares. Na drugi strani nicle v minusu pa SDS in DLGV, pod grafom pa je pisalo "fosilne stranke". Slo je za politiko do virov energije. :D
francek1 ::
You are a liberal patriot. 2 percent of the test participators are in the same category and 41 percent are more extremist than you.
s1m0n ::
You are a neoliberal Democrat. 6 percent of the test participators are in the same category and 77 percent are more extremist than you.
Še je kdo podobno kot jaz :)
Berserker ::
You are a patriotic and authoritarian Socialist.
Mi lahko kdo razloži, kaj točno to pomeni in kaj je fora z sekularnostjo...
GoodSatanist ::
jype je izjavil:
THIS!:D
Veste fantje in dekleta. JAZ sem pa JAZ. Konec debate.
Trinitron ::
To se pa zgodi, če daš na vsa vprašanja najbolj primitiven odgovor: :P
GoodSatanist ::
2
Citati, ki vam kaj pomenijo (strani: 1 2 3 4 5 )
Oddelek: Sedem umetnosti
22659804 (10374) yansek
Še en osebnostni test?
416016 (4824) piromanček
Draw A Pig Personality Test
71688 (1355) Avenger
Nov IQ Test na emode.com
333407 (373) VuLc4n0
Personality test... (strani: 1 2 )
547753 (6629) XShaeboX
