youtube - počasno delovanje
rogi2010 ::
Zadeva je naslednja. Že od nekdaj gledam na youtube sc2 posnetke iger s komentarji (husky, hd ...). Zadeva je v tudi v HD, kar je normalno delovalo na moji 10/10 t-2 optiki. Zadnje čase je nemogoče pogledati karkoli tudi na nižjih resolucijah. Po malo guglanja opazim da je problem, glede na to iz katerega youtube serverja dobim zadevo. Igral sem se s spremembami dnsjev (t-2, gugl, opendns, arnes) ampak zadeva ne pomaga preveč.
Tracing route to youtube-ui.l.google.com [173.194.70.91]
over a maximum of 30 hops:
1 3 ms 3 ms 3 ms 89-212-0-1.gw.t-2.net [89.212.0.1]
2 1 ms 1 ms 1 ms 84-255-210-177.core.t-2.net [84.255.210.177]
3 1 ms 1 ms 1 ms 84-255-250-5.core.t-2.net [84.255.250.5]
4 7 ms 6 ms 6 ms win-b2-link.telia.net [213.248.104.157]
5 7 ms 7 ms 7 ms win-bb2-link.telia.net [213.155.133.74]
6 20 ms 20 ms 62 ms ffm-bb2-link.telia.net [80.91.246.142]
7 20 ms 20 ms 34 ms ffm-b7-link.telia.net [80.91.254.101]
8 70 ms 32 ms 26 ms google-118152-ffm-b7.c.telia.net [213.248.102.234]
9 23 ms 25 ms 27 ms 72.14.238.96
10 21 ms 34 ms 20 ms 72.14.236.68
11 21 ms 20 ms 20 ms 209.85.254.112
12 * * * Request timed out.
13 20 ms 20 ms 20 ms fa-in-f91.1e100.net [173.194.70.91]
Tracing route to youtube-ui.l.google.com [209.85.148.91]
1 1 ms 1 ms 1 ms 89-212-0-1.gw.t-2.net [89.212.0.1]
2 1 ms 2 ms 1 ms 84-255-210-177.core.t-2.net [84.255.210.177]
3 30 ms 1 ms 1 ms 84-255-250-5.core.t-2.net [84.255.250.5]
4 6 ms 6 ms 6 ms win-b2-link.telia.net [213.248.104.157]
5 73 ms 7 ms 7 ms win-bb2-link.telia.net [80.91.246.198]
6 20 ms 20 ms 20 ms ffm-bb2-link.telia.net [213.155.131.212]
7 20 ms 20 ms 20 ms ffm-b7-link.telia.net [80.91.251.234]
8 20 ms 42 ms 24 ms google-ic-120086-ffm-b7.c.telia.net [80.239.193.138]
9 21 ms 21 ms 20 ms 72.14.238.230
10 24 ms 20 ms 32 ms 209.85.254.57
11 20 ms 20 ms 20 ms fra07s07-in-f91.1e100.net [209.85.148.91]
Primeri traceov katerih dobim z različnimi dnsji.
Prilagam še sliko task managerja kjer se lepo vidi mrežni promet:
1: husky replay
2: file.siol.net file download
3. rihanna we found love - 1080p
4. rihanna we found love - 720p
Kako bi ugotovil "slabe" youtube strežnike in jih izločil, oziroma kaj sploh lahko naredim?
P.S
Ne potrebujem odgovorov v smislu slab router, torenti, browser, problem v računalniku ker:
- je bila zadeva testirana na 3 računalnikih (2 stacionarna + prenosnik)
- različni brskalniki
- eden od računalnikov je bil vklopljen direktno v rebootan modem od optike
- linija je pri meni 98% prazna
rogi2010 ::
Probal sem še siol adsl, zadeva lavfa tekoče na 1080p, ko gledam mrežo je obremenjena 10% kar je normalno za 10mbit povezavo kot je tukaj.
Gledal sem
Tracing route to youtube-ui.l.google.com [173.194.70.93]
1 20 ms * 20 ms BSN-access.dsl.siol.net [213.250.19.90]
2 22 ms 22 ms 21 ms 95.176.253.83
3 29 ms 28 ms 31 ms 95.176.253.13
4 43 ms 42 ms 42 ms de-cix10.net.google.com [80.81.192.108]
5 42 ms 44 ms 43 ms 209.85.255.172
6 49 ms 52 ms 45 ms 72.14.239.62
7 43 ms 43 ms 43 ms 209.85.254.116
8 * * * Request timed out.
9 43 ms 43 ms 50 ms fa-in-f93.1e100.net [173.194.70.93]
Pesimist ::
doben te ne brani da probas siolove in telemachove DNSje. Prvi ima direktno povezavo do nemskih google streznikov, drugi pa ima celo svoje.
Problem je le da mora imenovan starcraft file biti tudi na teh streznikih, da imas ti speed gain. Ce si prvi ki si ga ogledo, bos ga pac ti prvi na server nalozo. Nevem ce tocno tak deluje, mogoce je potrebno like 1000 klikov, da pride na hiter streznik.
Dragi ::
Popizdevam tudi sam zaradi tega.
To se dogaja nekje kaki teden-dva. Prej tega ni delalo nikoli.
Siol adsl, 10/1 mbit
Recimo 360p streama lepo, tud dost hitr dokonca naloži, 480p glih tok da za sprot dela, sem pa tja mal zašteka. 720p al pa bog ne daj 1080p je pa itak nočna mora. Pritisnem play, hitr pavzo in grem delat drugo dokler ne naloži.
Linija pa 2% zasedena (se pravi mi streama z 2mbit oz 20% celotne povezave).;((
rogi2010 ::
Siol dnsji ne delajo na t-2. Telemach sem mislim da tudi probal pa ni bilo razlike. Rabim izvedet iz katerega ip-ja mi vleče zadevo da pogledam routing, mal sem gledal netstat pa ni ravno pregledno.
rogi2010 ::
Telemach zgleda nisem problem ker sem pravkar ugotovil da ne delajo. Trierini delujejo in me zgleda prerouta nekam drugam, ker ko zalavfaš film na youtube javi da je prišlo do napake in naj poskusim pozneje. Internet drugače deluje.
Pesimist ::
Sem rpavkar na trieri probal ta youtube link 1080p in leti fajn iz njihovega servera.
194.152.31.210
Siol se pa kr zatika kljub nemski direktni povezavi.
T2 bi ja tudi nej imel google streznike al so jih prodali ze?
  • spremenilo: Pesimist ()
Optimizacija linije do igralnih strežnikov - what can you do?
Oddelek: Omrežja in internet
305787 (4755) Pesimist
Najboljši routi na optiki
123323 (2882) Bakunin
Youtube zelo počasen (strani: 1 2 )
8813078 (10121) HeMan
Telemach: Počasno delovanje interneta
133227 (2936) floyd1
Čudna reč z razrešitvijo naslova
72136 (2007) mr1two
