Forum » Strojna oprema » AMD Radeon HD 7900
AMD Radeon HD 7900
miraldi ::
Kok procentov je potem 7870 boljša od 7850? A je 7850 še zmeraj boljši nakup glede na p/p
freesty ::
stock 7850:
FPS: 30.1
Scores: 759
Min FPS: 13,1
Max FPS 69,8
OC 7950:
FPS:
51.7
Scores:
1302
Min FPS:
22.3
Max FPS:
127.4
Pri teh nastavitvah:
Render: direct3d11
Mode 1920×1080 8×AA fullscreen
Shaders : High
Textures: High
Filter: trilinear
Anistropy: 16×
Occlusion: Enabled
Refraction: Enabled
Volumetric: Enabled
Tessellation : Extreme
in se OC 7870
FPS:55.3
Scores: 1393
Min FPS: 9.2
Max FPS: 145.9
Mode: 1920x1080 fullscreen
Shaders: high
Textures: high
Filter: trilinear
Anisotropy: 16x
Occlusion: enabled
Refraction: enabled
Volumetric: enabled
Tessellation: extreme
Da bi lahk primerjal more FireX88 pognat na istih nastavitvah+ ProMoted more navit grafo. Oz FireX88 pognat se pri stock.
FPS: 30.1
Scores: 759
Min FPS: 13,1
Max FPS 69,8
OC 7950:
FPS:
51.7
Scores:
1302
Min FPS:
22.3
Max FPS:
127.4
Render: direct3d11
Shaders : High
Textures: High
Filter: trilinear
Anistropy: 16×
Occlusion: Enabled
Refraction: Enabled
Volumetric: Enabled
in se OC 7870
FPS:55.3
Scores: 1393
Min FPS: 9.2
Max FPS: 145.9
Shaders: high
Textures: high
Filter: trilinear
Anisotropy: 16x
Occlusion: enabled
Refraction: enabled
Volumetric: enabled
http://www.youtube.com/watch?v=5hfYJsQAhl0
fireX88 ::
ti bom dal jst dečko, fantič! spregledal sem. evo ti teste!
FPS:
36.0
Scores:
908
Min FPS:
22.1
Max FPS:
78.7
Settings
Render: direct3d11
Mode: 1920x1080 8xAA fullscreen
Shaders: high
Textures: high
Filter: trilinear
Anisotropy: 16x
Occlusion: enabled
Refraction: enabled
Volumetric: enabled
oc:
FPS: 41.2
Scores: 1037
Min FPS: 20.5
Max FPS: 95.3
Settings:
Shaders: high
Textures: high
Filter: trilinear
Anisotropy: 16x
Occlusion: enabled
Refraction: enabled
Volumetric: enabled
FPS:
36.0
Scores:
908
Min FPS:
22.1
Max FPS:
78.7
Settings
Render: direct3d11
Shaders: high
Textures: high
Filter: trilinear
Anisotropy: 16x
Occlusion: enabled
Refraction: enabled
Volumetric: enabled
oc:
FPS: 41.2
Scores: 1037
Min FPS: 20.5
Max FPS: 95.3
Settings:
Shaders: high
Textures: high
Filter: trilinear
Anisotropy: 16x
Occlusion: enabled
Refraction: enabled
Volumetric: enabled
stock ::
miraldi ::
Potem sem pa kar pravilno sklepav
Kaj pa te 7850 katere so že tovarniško navite Gigabyte, MSI,Powercolor, ASUS.
Gledam cene so tam do 20Eur dražje od navadne Sapphire, zdaj me zanima a je dobro uzet tovarniško navito in koliko se potem, to sploh pozna v praksi, a lahko zaradi tega navitja ima krajšo življensko dobo? Sam je nemislim navijati.
fireX88 ::
lahk jo samo naviješ. če jo misliš uzami kako ki ima dobero hlajenje!
stock ::
Ja če uzameš kakšno OC varianto potem bo spet tolko dražja da bi se bolj splačalo uzet najcenejšo 7870.
Sicer pa boš moral res vršt še kak € vkolikor bi rad tišjo kartico naprimer, načeloma imajo te OC tudi boljša hlajenja, ki so potem tišja v idle. So pa OC variante minimalno hitrejše.
fireX88 ::
uzami od sapphire (dinokomp jo ima za 244) pa bo tudi za navijat, pa tudi njcenejša je tam!
kolk vem ma sapphire tudi dobra hlajenja!
miraldi ::
Od Sapphire je v funtechu 226Eur od Gigabyte pa 251Eur. Dinokomp glede te grafične sploh ni najcenejši.
fireX88 ::
uzami sapphire, najviješ lahko sam!
Pro_moted ::
Cene skačejo gor, dol, cel čas ! Jaz sem Powercolorjevo kupil za 230 evrov. Zadnje kaj sem gledal je 251.
AMD FX8120;GB 990FXA-UD3
eieieie1 ::
Tudi cene novih ivy bridge procesorjev so pri dinokompu dost višje kot pri ostalih O.o
- spremenil: eieieie1 ()
Pro_moted ::
Nevem zakaj tok skačejo cene. A sizadovoljen z nakupom?
Ja, zaenkrat sem zadovoljen.Poganja vse kar želim.Za to ceno je odlična grafa.
Skyman ::
fireX88 ::
jst pa šele več dni :)
4870 se ni tako enostavno navila samo v catalyist control centru kot se 7870
Xserces ::
firex v CCC lahko sliderje potegnes do konca ce nimas unlockanga biosa...
yayo ::
Čisto iz firbca, sprašujem lastnike 7000 serije: Katera igra vam najbolj segreje gpu? Noben Heaven 11 test, Crysis 2 ali BF3 mi ne našpona temperature kot The Witcher 2 (DX9)
fireX88 ::
meni pride ko je navita preko 60° v BF-ju, kaj več pa nisem še probal!
EDIT: kaj več pa tudi nisem probal..
Xserces kako to misliš. Trenutno mam slajder do kocan na ramu(1450MHz), GPU je pa recimo na 4/5 slajderaj(1175 od 1400MHz)..
- spremenil: fireX88 ()
Xserces ::
nevem kako je z 7xxx v CCC ampak 5xxx je bilo navijanje porazno ker so imeli zaklenjen bios... max je blo 800 al neki tazga ... 725->800 MHz (grafa lahko laufa na 1000MHz)...
mr1two ::
Hm, zanimivo. Na Asuskah in ali z asus biosom flashane druge karte so šle bp čez to mejo.
Podoben primer je bil tudi z večino 4770-> ram si lahko nastavu na max 840 al neki tam okrog, core pa tudi na okrog 800. Z asusovim biosem se da tudi malo dvignit napetosti in mimogrede prideš na frekvence 970 core in ram na 1040 ali več(ker je pač ddr5, deklariran kot 1000mhz).
Z malo telovadbe se da narest čuda
fireX88 ::
joooj no komaj cakam 7890
jst mislim da je nebo, ker je premjhna razlika med 7870 in 7950!
miraldi ::
Men se vseeno zdi 7870 proti 7850 predraga glede na teste ni spet tok boljša da bi zanjo odštev 90eur več. Če bi imela ceno 290eur pa mogoče.
Pro_moted ::
Na hoh.de imajo Saphire 7870 za 294euro , overclockano pa za 309 .
fight4 ::
284€
http://www.mindfactory.de/product_info....
+30 evrov poštnine pa izačunaj...
Ne pošiljajo v SLO
miraldi ::
To je pol brezveze. Tud če bi pošiljal bi pršparov 5-10eur. A kaj pa ko/če moraš garancijo uveljavljat se morš z nemci zajebavat pa jim pošiljat
| » | Grafična kartica (strani: 1 2 )Oddelek: Kaj kupiti | 15627 (13738) | Brias |
| » | Najboljša grafična kartica pod 200EUR.Oddelek: Kaj kupiti | 6371 (5721) | Brias |
