Forum » Programiranje » [c#] Vprasanje glede eventov
KernelPanic ::
Spostovani soforumasi!
Imam dll in gui aplikacijo, ki preko dll komunicira z napravo. Sedaj bi rad dll nadgradil z sledeco funkcionalnostjo: Namrec, dll pobira podatke iz naprave, in ko je nov podatek na voljo, bi rad sprozil event newDataArrived, ki bi ga nato ujel v gui aplikaciji. Kako naj to storim? newDataArrived mora v gui prenesti tudi podatke, ki sem jih prejel iz naprave.
S spostovanjem in vnaprej se zahvaljujem za pomoc,
M.
M.
Looooooka ::
v dllju mas verjetno class, ki ma potrebno kodo za to komuniciranje z napravo...v "gui" aplikaciji pa instanco tega classa?
se prav moras v classu samo dodat event in ga dvigat ko dobis podatke...v "gui" aplikaciji se pa pac subscribas na ta event in nekaj nardis ko se dvigne.
kje tocno je problem?
KernelPanic ::
Ja luka, tocno to rabim, ampak ne vem, kako to narest, mas kaki link do "barebone" primera?
KernelPanic ::
No pa probam, tukaj je koda, najprej dll:
namespace AccuLoadIIICommDll
public class DeviceFunction
public delegate void newTransactionArrived(object sender,
Transaction e);
public event newTransactionArrived transactionArrived;
protected virtual void OnTransactionArrived(Transaction t)
if (transactionArrived != null)
transactionArrived(this,
t);
}..., tukaj je GUI del za lovljenje eventa: this.m_CoreFunctions[0].transactionArrived +=
new System.EventHandler(DeviceFunction.newTransactionArrived(FormMain_transactionArrived()));in ko dam prevajat, mi vrne sledeci error:Error 1 Non-invocable member 'AccuLoadIIICommDll.DeviceFunction.newTransactionArrived' cannot be used like a method. D:\Projects\AccuLoadIIISolution\AccuLoadIIIMonitor\FormMain.cs 78 56 AccuLoadIIIMonitorZakaj???
detroit ::
Sorry nism bral:D če rabiš custom evente poglej kak delegate & events tutorial
, če je offtopic me deletej:)
Skero
vojko20 ::
probal brez "DeviceFunction.newTransactionArrived("
torej:
this.m_CoreFunctions[0].transactionArrived += new System.EventHandler(FormMain_transactionArrived);
drugače pa, če delaš v Visual Studiu samo napiši
this.m_CoreFunctions[0].transactionArrived += [prtisni tab][tab]
in ti bo sam zgeneriral kodo
torej:
Looooooka ::
problem je verjetno v tem, da si event definiral z dvema parametroma...prvi je object drugi pa pac nek objekt tipa transaction.
tko da tud tole verjetno ne bo delovalo:
bos moral dat verjetno += new AccuLoadIIICommDll.DeviceFunction.newTransactionArrived( ...
plus...se en manjsi popravek:
protected virtual void OnTransactionArrived(Transaction t) {
transactionArrived(this,t);
dobra praksa je da prej nardis znotraj funkcije eno referenco na tale handler:
AccuLoadIIICommDll.DeviceFunction.newTransactionArrived check = transactionArrived;
if(check!=null)
check(this,t)
se posebej ce obstaja moznost, da ti kksn drug thread al pa kdorkoli vmes odstrani tist subscription na event.
potem dobis tak lep NullRefrenceException... :)
if(check!=null)
check(this,t)
| » | c# - mssql kombinacija / problem pri zapisu row-a v bazoOddelek: Programiranje | 2129 (1938) | darkolord |
| » | [c#] Vprasanje glede BackGroundWorker classa in spreminanja gui elementaOddelek: Programiranje | 1082 (1008) | Ericssony |
| » | [c#] Vprašanje glede release verzije aplikacijeOddelek: Programiranje | 1958 (1782) | Ericssony |
| » | Tezava pri instanciranju class-aOddelek: Programiranje | 1755 (1626) | KernelPanic |
| » | [.NET ASP] Napaka : Specified cast is not validOddelek: Programiranje | 1512 (1465) | pinc |
