Forum » Zvok in slika » Kateri televizor?
Kateri televizor?
rini ::
Moj Smart na Samsungu letnika 2014 dela tekoče od prvega dne, ko sem ga postavil na steno. Nikoli ni zacikal ali se obnavljal.
Dami ::
Sej vem, da si naj vsak sam nastavi tvje kak mu najbolj ustreza, sam a obstajajo mogoče že kake priporočene nastavitve za sony 65xd9305?
andrej69 ::
Tomson ::
Poizkusi še TUKAJ ...
Dami ::
Bom sprobal, hvala obema.
andrej69 ::
It is exactly as cheap but still half as expensive as high-end 75-inch TVs from other major brands. Hisense says that the TV supports 4K and HDR (high dynamic range).
Hisense unveils 75M7900
Hisense's TV will be available in select parts of Europe in time for Euro 2016, which has Hisense as one of the official sponsors. It will cost the same as many 55-60" TVs from more established brands and almost makes 75" feel accessible.
Hisense says that the TV has a 4K panel and a limited form of local dimming that enables it to reproduce HDR (high dynamic range). However, be aware that it does not have the hardware to do proper HDR and that it has not been "UHD Premium" certified. The TV supports 3D (active) and is just 13 millimeters thick, says Hisense.
The TV's operating system is powered by a quad-core processor. From the user interface you have access to apps such as Netflix, Amazon Video, and YouTube. The TV supports both HEVC and VP9 decoding meaning that you can stream 4K content, too. There are two HDMI 2.0 ports (with HDCP 2.2) and two regular HDMI ports as well as three USB inputs.
The Hisense 75M7900 is rolling out in Europe now. The suggested retail price in Euro was not announced but it will retail for ?2500 in the UK
fpbs ::
Čakam na ugodno ceno 75" TV, zato dobrodošla konkurenca, glede nižanja cen.
http://www.flatpanelshd.com/news.php?su...
TV se proizvaja na češkem:
http://hisense.cz/televizory/he75k700ux...
andrej69 ::
Odličen televizor.Za takšno ceno,se ga isplača vsekakor vzet.
Ted ::
Ni Hisense kitajec? Je kdo sprobal kak njihov model televizorja in ga primerjal z znanimi proizvajalci? Cene so res konkurenčne...
Mah...
andrej69 ::
Hisense je Kitajska firma,je pa partnerka Nemške firme Loewe.Skupaj razvijajo tv tehnologijo.
Hisense za Evropski trg,izdeluje televizorje z elektroniko ,ki jo je proizvedel Loewe. Tako eni kot drugi,nastopajo na Evropskem in Kitajskem tržišču.Kar se tiče kvalitete slike,elektronike,itd..prekaša marsikateri televizor priznanih firm.
- spremenil: andrej69 ()
andrej69 ::
lah33zis ::
Zdravo ! Meni je žal, da še kar sitnarim, ampak se še ne morem odločiti in še vedno upam na kak predlog za 55" TV v rangu 850€. Če izvzamem Ultra HD (za katerega ugotavljam, da morda ni tako nujna reč na novem TV-ju, saj bo najbrž še dolgo, preden bo format prišel v splošno rabo), v čem se razlikujeta
http://www.techradar.com/reviews/audio-...
in
https://www.onlinestore.it/detail/index... ?
Ima morda kdo povezavo do kakšnega testa za tega Philipsa, saj ga nikjer ne najdem?
in
andrej69 ::
in
Kar se tiče Philips televizorja je4k,dočim je Sony fulhd televizor.Če pa hočeš podrobne podatke,pa povej.
Tukaj pa imaš test Philipsa.
http://hdtvpolska.com/topic/37116-test-...
fpbs ::
Kolikor je meni poznano, gre tukaj za podobno zgodbo kot s Filipsom. Loewe je bil pred kakimi tremi leti pred bankrotom, zato so ga prevzeli kitajci- Hisense, ki jim je pa bil glavni cilj prodor na evropsko tržišče. Vsa tehnologija od Loewe je bila za Hisense nekoristna, razen nekaj softwera.
lah33zis ::
in
Zanima me, katere 55" modele, če sploh katere, se splača kupit za cca 850€. Na prejšnji strani predlagali PUS6051, 55" verzija tega pa je kar dražja. Ker opažam, da so FullHD televizorji cenejši in da Ultra HD ni neka nujna zadeva, me je zanimalo, če se da dobit TV z isto kvalitetno sliko in androidom ter vsem poleg, le da nima Ultra HD, za nižjo ceno. V oči mi je padel tale Sony, vendar se ne omejujem samo na tega. Torej, v čem je en tak Sony (ali kak podoben TV) slabši od zgornjega Philipsa? Zakaj bi se/se ne bi splačalo dat več za Philipsa? Hvala.
andrej69 ::
in
Takole ti bom dejal.Če kupuješ tv za eno ali dve leti,je Sony vsekakor dober nakup.Če pa kupuješ televizor za daljše obdoje potem pa vsekakor Philips.Je pa Philips, kar se tiče specifikacij, seveda že korak ali dva naprej, napram Sonyu.
lah33zis ::
in
Hvala. Philips it is.
Jasna5 ::
Pozdravljeni,
Ze 6 let je minilo odkar sem nazadnje kupovala nov TV. Leta 2010 smo kupili Philipsov full hd 100hz LCD. Po 6 letih pa se je zacel kvarit, in sicer ekran rata crn, vcasih ze takoj ko se TV prizge, vcasih pa potem med gledanje in ta crna slika sploh ne zgine. Torej, odlocili smo se za novega, budget je 500EUR, mora bit pa 40 inchni, smart TV.
Na mimovrste sem nasla tegale: https://www.mimovrste.com/ultra-hd-tv-s...
Zanima me vase mnenje. Hvala za pomoc.
- spremenila: Jasna5 ()
Tomson ::
Pri Samsung seriji 5 in 6 je precej loterije s paneli, če pa že, predlagam serijo JU6400, sicer nekoliko nad budgetom. Sam bi pri tem cenovnem okviru in velikostjo izbiral med Panasonic 40CS630 in Sony W705C, oba okoli 450€ in oba odlična TVja za svojo ceno ...
Jasna5 ::
Kje bi se pa dalo ta dva pogledat/kupit?
Tomson ::
- spremenilo: Tomson ()
mat xxl ::
Andrej69 glede Philipsa oziroma chinFilipsa ti povem takole, eno so briliantne specifikacije, drugo pa delovanje, ki pri Filipsu, žal ne gre brez vsaj tedenskega obešanja in podobnih nebuloz. Philips modeli do pred 4 leti so še bili, današnji so pa le za one naj naj naj bolj razumevajoče in potrpežljive z res jeklenimi živci. Edino, kar jih še drži gor je osvetlitev ozadja.... Z letniki 2016 sicer nimam izkušenj z ostalimi TOP modeli pa ja in lahko samo rečem, konkurenca ponuja TV je morda z slabšimi specifikacijami in brez Ambrilighta , samo se pa večinoma ne obešajo ......ali pa vsaj ne tako redno, kot Filipsi....
- spremenil: mat xxl ()
Tomson ::
Konkurenca pa res ne ponuja TVjev s slabšimi specifikacijami, gledano generalno in ambilight se da, kot zunanja rešitev, na popolnoma enakem nivoju oz. boljšem kot v npr. cenejših Philips modelih, dodati za 150€ prav pri vsakem TVju...
andrej69 ::
Ne vem kaj misliš povedat.Ravno z Philipsi, 3 leta ali več je bilo največ težav.Lanski modeli, so bili že kar v redu.Letošnji pa delujejo, brez kakršnih težav.Je pa tako,z vsakim televizorjem moraš danes imet srečo.
Ne glede na firmo,ne glede na rang televizorja.Jaz osebno imam lanski model,pa nikakršnih težav.Tudi moji družinki prijatelji, imajo večino Philips televizorje,pa ni nekakšnih negativnih komentarjev.Kot sem že dejal,največ težav je tako bilo, z android sistemom,wifi občasne težav,softwerom.To je bilo zlanskim letom,v večini odpravljeno.Toda kar se slike tiče in okvar, Philips nima ravno težav.Lahko pa pogledaš tudi na kakšen drug forum, drugih firm,pa boš videl podobne zgodbe.
OK.d ::
Bolj ti tumbamo, da ima philips težave s softwearjem ti pa vehementno trdiš, da to sploh ni težava in da je zanemarljiv problem.
In poleg tega še to priporočaš
LPOK.d
andrej69 ::
andrej69 ::
In poleg tega še to priporočaš![]()
Toda zopet nimajo vsi težav,da smo si na jasnem.Letošnji modeli pa sploh ne.Pa še vedno je boljši, recimo od večine Samsungov Serije 5 in 6,Sonyev r serije,Lg serije 5 itd..Seveda pa tudi višji rang,teh televizorjev ni imun na težave.Kot sem dejal,danes moraš imet že malo sreče z televizorji.
buttcrack ::
Eno vprašanje za lastnike Sony W80xC... Sliko sem nastavil glede na http://www.rtings.com/tv/reviews/sony/w... ampak se pojavlja, da je v nekaterih delih filma/serije slika zelo temna (zame preveč) in potem izgleda kot da bi malo žmigalo, ko se spreminjajo kadri. A je to običajno preden resetiram nastavitve?
Pol me pa še zanima kako preko androida izbrišem file z diska, da mi niso v napoto preden spet priklopim disk na komp. Zaenkrat preko nobene aplikacije ne morem označit filea, da bi potem lahko kjer koli stisnil DELETE.
andrej69 ::
Probaj te nastavitve.Kar pase tiče brisanja preko Androida,pa probaj z tem programom.Potegni si dol ta program.
SHREDroid
buttcrack ::
preizkusim te nastavitve, hvala, aplikacije pa ne morem naložit, ker naj ne bi bila kompatibilna.
J.McLane ::
Jaz sem si pomagal z ES File Explorer, ampak je zelo štorasta zadeva preko dalinca, pa še ob prižigu TV-ja mi je stalno težil, da je zaznal USB disk. Jaz sem ga inštaliral samo toliko, da sem prenesel advancedsettings za Kodi, ker mapa ni bila vidna preko Team viewerja.
Edit: Za sprobat bi bil še:
Open Explorer Beta
AnExplorer File Manager
Open Explorer Beta
- spremenil: J.McLane ()
buttcrack ::
na dalincu ne najdem gumba s katerim bi lahko označil file in potem nekje pritisnil delete. Možno, da se sploh ne da, kaj pa vem.
m4j3r ::
Katerega od teh bi priporočili:
... oziroma kaj v tem cenovnem rangu/velikosti
Bo pa priključen na PC, tako da bo delno uporabljen tudi kot monitor...
RedRanger ::
Zdravo!
Kopujem tv, pa se nemorem odločiti, obadva za okoli 750€.
Sony kdl50808c in Philips 49PUS7170/12.
Sony naj bi biv super hd tv. Plus je tudi vecji, philips ima pa 4k, in itak tega se nekaj casa nebo,vsec mi je ker ima ambilight.
Ali je razlika v sliki ce gledamo recimo film v hd resoluciji.
Kaj bi priporocali?
Kaj bi priporocali?
andrej69 ::
Mislim,da bo še najboljši Lg, model 770.Če pa boš igral igre,pa bi ti priporočil kaj boljšega.
andrej69 ::
Zdravo!
Kaj bi priporocali?
Tukaj si poglej razlike.Pri sliki,levo je upcaling 1080p na 4k televizorju,levo pa normalen hd televizor z 1080p resolucijo.
m4j3r ::
Zakaj? Zaradi odzivnosti?
Sicer odigram kakšno igro, vendar tako redko, da to nikakor nebo prioriteta.
andrej69 ::
Da.Sicer pa ni panike,če ne boš kaj dosti igral iger.Lahko potem vzameš tudi Philipsa.Kajti,če bi igral igre,je Lg nekaj boljši napram Philipsa.Sicer pa tako eden kot drug, nista preveč dobra za igre.Za monitor,pa povsem uporabna.
m4j3r ::
Aha ok, hvala... se potem vseeno bolj nagibam na lg-ja.
Philips me je mikal zaradi ambilight + androida, vendar...
- če ga uporabljaš kot monitor je ambilight vrjetno bolj moteč kot ne
- o androidu pa tudi ne slišim pretirane hvale. + ker je priključen PC so smart funkcije tukaj sekundarnega pomena
andrej69 ::
Letos se bodo vsi modeli Philips televizorjev 2015,nadgradili na novo verzijo Androida 6.0.,ki deluje brez kakršnih težav.
Ted ::
Poleg Hisensa je zelo ugoden še Telefunken. Linka iz zadnjega promo maila od Amazon-a, 55 col in 4k za 700 eur. Zvok in smart funkcije so v drugem planu, slika pa v prvem. Zadnji jebtlc, naj bi bil identičen ikeininupplevi... Komentarji?
gp/product/B00Y809EC8/ref=pe_155581_130811091_em_1p_4_ti
https://www.amazon.de/gp/product/B0140H...
gp/product/B00YXLS5TK/ref=pe_155581_130811091_em_1p_9_ti
Mah...
- spremenilo: Ted ()
car100 ::
Philips letošnji modeli majo ok odzivni čas primerno tud za igre! Neprivzete android aplikacije se naloži preko aplikacije ES File Explorer -> najdeš aplikacijo iz mreže oz usb ključka in nato daš ( Market) Trgovina Play in namestiš. Aplikacijo nato najdeš pod zbirko vseh aplikacij (hitre bližnjice ne naredi ker ni podprta aplikacija. (Ni nujno da deluje ok ker običajno ni podprta za tv. Brisanje filmov bi mogoče šlo preko ARCHOS video player (pred predvajanjem je opcija izbriši. Kdor rabi za filme predvajat naj naloži VLC ali Kodi.
Kdor ima pomisleke v Philips samo en nasvet. Zaženite tv posodobite programsko opremo in nato ponovno ponastavite na tovarniške privzete nastavitve. Nato posodobit vse aplikacije in bo vse delal! (enako se naredi pri android telefonih). Se pa zgodi da kaka aplikacija še ni dodelana in sesuva tv ampak teh par nujnih aplikacij dela brez težav ga nisem sesu.
andrej69 ::
Vestelov produkt.Mislim,da so ostale firme še vedno nekaj spredaj ,kar se tiče tehnologije.
Blazz ::
philips lanski model serija 7 je bila totalna polomija, smo to že večkrat dali skoz tule, tako da ne začenjajmo še enkrat širiti buč...
OK.d ::
In kaj jim rabi 6.0, ker sploh ni hardwera tapravega notri, za android tv primerna je edino konzola nvidia shield, pa še ta ima poporodne krče zaradi "strokovnjakov" v nvidiji
LPOK.d
andrej69 ::
In kaj jim rabi 6.0, ker sploh ni hardwera tapravega notri, za android tv primerna je edino konzola nvidia shield, pa še ta ima poporodne krče zaradi "strokovnjakov" v nvidiji![]()
Kar se ne sekiraj,vse se bo uredilo.
andrej69 ::
Tako hudo pa spet ni.
