Forum » Zvok in slika » Kateri televizor?
Kateri televizor?
andrej69 ::
Techradar o Filipsih:
Less impressive, however, is the set's use of an IPS panel rather than a more premium VA panel, and a peak brightness output of just 400 nits, which is far short of the 1000 nits required for UHD Premium certification.
In terms of HDR performance, the Philips POS9002 will deliver a peak brightness of 750 nits and a DCI-P3 coverage of 99%. Given these specifications, it will come as no surprise then that the OLED television will be UHD Premium-certified.
Samo 750? Ne 1.000?
Ampak kar sem napisal, se itak ne nanaša na flagshipski 9002, ampak letošnje modele pod njim. Samsung & Co. poskušajo letos z ultra visoko svetilnostjo, tudi 2.000 nits, konkurirati OLEDom, Philips pa mizernih 400. Malo sem razočaran, kot da Philips ne jemlje resno svojih potencialnih kupcev in misli, da je razlog za nakup ambilight.
"Samsung introduced a new TV technology at CES 2017: QLED. It's an evolution of Samsung's Quantum Dot technology, as seen on last year's models, which improves the brightness and vibrancy of colours without crushing black levels. The new TV range boasts between 1,500 to 2,000 nits peak brightness, making them far brighter than any of the OLED TVs are capable of. "
Pocket-lint
Pa saj sem ti že napisal, da ni vse v svetilnosti panela:)Philips se raje ukvarja z drugačnimi parametri, ki so pomebnejši od svetilnosti..Kar se tiče pa 400 nits, pa nima samo Philips take svetilnosti, temveč tudi drugi proizvajalci kar se tiče takšnega ranga televizorjev.Prej ko ni bilo še HDR in teh parametrov ni bilo nikakršne panike.Sedaj, ko pa je Samsung začel z tem marketingom, pa vse splošna panika..Kaj misliš, da drugi proizvajalci ne morejo proizvest televizor s takšno svetilnostjo:)Toda enostavno, drugim proizvajalcem to ni prioriteta..Pa si ti sploh videl kakšen televizor v živo, da si se oprijel te svetilnosti kot pijanec plota.Če bi bile takšne drastične razlike, potem ne bi potrošniki kupovali nič drugega kakor Samsung televizorje:)
- spremenil: andrej69 ()
4knative ::
Z LCDji se lahko gre samo v tekmo z niti, ker ne moreš izklopiti piksla, da bi dosegel neskončni kontrast. leiito, ti spet ne razumeš razlike med OLED in LED LCD tehnologijo. Boljše, da še naprej citiraš ljudi iz resničnostnih šovov.
4knative ::
Niti so slaba stran OLEDov. Filmi se masterizirajo za HDR pri 4000 nitov, kar pomeni da z enim povprečnim b6 s 500 niti manjka kar nekaj detajlov v svetlih scenah. Pri Samsungu se ti pa lahko iz zenice pokadi, če predolgo gledaš v 2000 nitov.
QLED je OLED killer.
andrej69 ::
Tukaj že potrebuješ, masko za varjenje.
Gatsu ::
Samo 750? Ne 1.000?
Pocket-lint
Ja in potem pride prvi test tega famoznega QLEDA in se izkaže, da ne samo da je beseda QLED marketinški bullshit, še celo slabši je v marsičem od 2016 modelov... Da ne omenjam prezasoljene cene.
Kralj TVjev leta 2017 bo Sony A1 OLED mark my words :)
- spremenil: Gatsu ()
leiito ::
Kako se reši pa problem manjka HDMIjev? Nekateri sicer solidni modeli imajo samo 3, pa tudi če so štirje, eden za topset box, eden za soundbar, eden za Apple TV in je že konec, rabiš pa npr. še streaming box in plejer. So zadaj skriti še kaki dodatni HDMI vhodi?
Blazz ::
TP Vision
New Philips P5 Processing Engine offers 50% performance improvement over High-End Perfect Pixel Ultra HD system to set new reference PQ standard.
Flagship sets in the new Philips TV range will enjoy a significant improvement in picture quality in the first half of 2017 thanks to the introduction of the outstanding new P5 processing engine.
P5 promises to bring both a 25% increase in processing features and a 25% increase in processing power to give an overall 50% performance gain when compared with the existing Perfect Pixel Ultra HD engine.Further system integration will see a chipset reduction from the current three chips found in the Perfect Pixel Ultra HD system to just one in the P5. The reduction in chips bringing the faster transfer of data with better timing and improved control over the whole processing sequence. P5 will also offer both new features and improvements to existing processes in four of the five areas controlled by the processing engine including: Source quality, Sharpness, Colour and Contrast - while in the fifth area, the existing Motion Estimation function, Perfect Motion processing and scanning backlight are considered to already offer market leading motion performance......
Pri tolikih izboljšavah to zgoraj samo pove, kako je prejšnji model POS901, poleg tega, da so ga čarali skoraj 2 leti, nedodelan. Škoda, ker P5 Processing Engine ne omogoča še priklop lučk za novoletno jelko.
hhahahahahahaha , So true! Itak pa Andrej naseda tem marketinškim foram (oz. hoče da mi) spet 50% bolje etc etc... kako so to izmerili?..... kr neki...
fpbs ::
Mavrik ::
Zaradi velikosti teme jo zaklepam - v nadaljevanju bomo probali tole razbiti na segmente približno po velikostih da bo imelo mal več smisla (torej za TVje ~40", 55", OLED, ipd.)
