Funny and cool links
175 / 182
NonPlusUltra ::
"For a long time now I haven't existed. I'm utterly calm.
No one distinguishes me from who I am."
Unknown_001 ::
:D ni glih primerno za hipije
Begabt
Mal reklame:D
  • spremenil: opeter ()
Speed Hitting: 100 Hits in 1 Second
bluefish ::
GenZNPC ::
soon the whole world,
will be made in china :)):)):)):))
skibidi
radmannsdorf ::
Anney ::
  • spremenilo: Anney ()
  • spremenil: Gregor P ()
Zanimiva izbira slike izdelka:
Vir: Spletna prodajalna, izdelek Changhong LED40D2200H Tv 40'' Led Full HD Nero
  • spremenil: MrStein ()
Samson ::
WOW to slikco ozadja bi jaz tudi imel na kompu...ampak je ni na netu najdet. Vsaj jaz jo ne najdem tko na hitro. Ce kdo najde se priporocam, hehe.
condom.com not found - load pregnant.bat - done :O)
bluefish ::
  • spremenil: bluefish ()
marS ::
...no more heroes...
https://ecency.com/@seckorama
bluefish ::
bluefish ::
EU- Devil Queen Angela Merkel in Mykonos with TSIPRAS, Greece Summer 2015 - Dance of Destroyment
GenZNPC ::
Tip je carsko opisal izdelek, ko bi le bli vsi tako iskreni:
https://www.amazon.com/review/R39TR6XN9...
1.0 out of 5 stars Hell Hath No Fury Like The Scent Of Baking Cat Poo Brownies, August 16, 2015
By Suren Verified Purchase(What's this?)
This review is from: CatGenie Self Washing Self Flushing Cat Box (Misc.)
If you like smelling delicious baked cat poo, enjoy clogged hoses and drains, and love questionably clean litter all over your entire house -- this is the product for you!!!
The CatGenie is like an infernal onion -- each new layer bringing forth its own unique new kind of hell. It starts out and certainly looks fun, but once you start using it, everything quickly goes down the drain, except when it doesn't go down the drain at all.
The product is honestly only good for certain types of cats that follow very strict poop etiquette. All the rest who enjoy pooping in the middle of the box, have less than ideal nuggets, love to trap tiny litter in their paws, and those that dig furiously will turn your life, your nose, and your house upside down and into sheer misery and terror with this device.
The product, despite its best intentions, has many flaws.
These are the main ones:
* Cat poop in the middle of the box will not be picked up by the Genie Hand. It will either break up, be mashed, or be left to bake.
* The drain system and the actual drain hose are entirely too small. They are only truly capable of handling kitten poop, but other dissatisfying features make the use of this device with kittens a truly bad decision. Think about your cat, especially those of you with big ones. Now look at the size of the fingernail on your pinkie. That's where ALL the cat badness has to go, plus the extra granules that stick to the poo, extra fur, and anything else your cat decides to eat.
* The plastic litter granules, while biodegradable, are far too small -- they will be tracked everywhere by your cat AND BY YOU, from the bathroom to the bedroom to the kitchen and beyond. You will have no idea if they are "sanitary" or not.
* Poop falls through the Genie Hand like nobody's business -- the bumping motion the hand tries to use to save granules that can't wait to clog the machine only works on super solid loafs and instead frequently plants the seeds of an upcoming bake.
* The poop grinder / macerating device can make a terrible brown watery mess if anything else gets in there and you will end up with a clog - and this includes anything besides kibble your cat decides to eat.
* The holes in the bottom of the basin are way too small and are only capable of removing urine. Any poop not removed by the Genie Hand (and this can a lot) including very small pieces the size of a fingernail or a sliver of a fingernail WILL NOT be removed but WILL be baked. They will NEVER be removed or dissolved as the machine simply does not do that. YOU will have to remove them yourself, which defeats the purpose of the machine.
* Once you smell a poo brownie bake, your life will never be the same. Only a demonic machine would inflict such horror on the human race.
* The machine uses cold water, (supposedly, hot water will damage it or screw up the sensor). Ever tried to run your DISHWASHER or do your LAUNDRY using only ice cold water? Unless it's practically clean to start with, you're going to have a bad time. Even your grandmother's grandmother knew that you need HOT WATER if you really want to get something truly clean and dissolve dirt, food, and anything else, like cat poo.
* Cat Activation mode has so many problems. This nice solution saving feature will be your quickest ticket to baked brownie hell which will awaken you in the middle of the night and keep you awake for some time while you curse silently to yourself.
* The "human interface" is beyond idiotic. This is the kind of interface that you will find on 1970s electronics and products designed far outside the USA. It is honestly unacceptable and ridiculous in 2015 for this type of system to even still exist - even in the year 2000!
* The solution and the granules are a scam. Everyone knows it and you do too. The solution runs out quickly, including on Cat Activation mode which although it saves 50% with each run, will make the system run every time your cat pees, poops, or simply steps in and out of the box. So instead of 1 or 2 manual runs a day, you may be left with as many as 4-6 cat activated runs. And the sleep mode for Cat Activation is ridiculous and ludicrous to set up. Your choices are: smell poo at night, smell poo during the day, run six times a day, or not use Cat Activation mode at all.
* The system has essentially a non-existent level of machine intelligence. It has no idea about anything going on other than if a cat is in the machine or if the water is present. It may run and attempt to dry with liquid poo still in the system and a full clog in progress! As it fails to include a liquid detector, it must clean for both pee and poop on every cycle, resulting in half hour plus cycles for a quick pee when a basic 10 minute rinse would have been sufficient.
*You must continue to buy both the solution and the granules and the cost of these will be more expensive than any other litter system out there, including the containers for a Little Maid or a plain old box, litter, and a scoop.
* Cycles are long, loud, and use a lot of water and power. More than you think. The unit will heat up your whole bathroom or laundry room during the drying phase.
* If you choose to hook up the drain hose to your bathroom toilet, be prepared for terrible sights after a cycle.
There are many more problems, but these are the main ones.
I ended up with a pool of brown poop and pee water that ended up all over my bathroom floor. The failed unit had to then go directly into the bathtub to be emptied out and washed before being returned the next day. The entire bathroom had to be bleached. The most unsanitary experience of my life!
Don't buy this. It seems like a good product and in theory its intentions are good, but if the manual gives you the impression that this was designed and built on a budget (as the manual was clearly printed on one) - you are in fact correct.
The entire system needs a major R&D overhaul to be effective for 95% of cats out there as opposed to the maybe 25% it may work well with as it is. Either your cat's behavior will be compatible with the rigid tolerances of this machine or it won't. Chances are it won't, even if your first few days go well.
The first time you find yourself having to watch the cycle to avoid a bake -- take my advice and return the machine. Don't wait for the next problem to occur - a clog is far worse than smelling an open cat sewer bakery for an hour.
I read advice like this before purchasing and I thought I would be different. I KNEW my cat would be fine with this machine. Don't be like me. Don't have false hope and hubris. Wait for a better product or stick with your Litter Maid or Litter Robot or your basic box and scoop and some good quality litter. You will sleep well at night and your cat will also thank you.
skibidi
  • spremenil: GenZNPC ()
bluefish ::
Boris- ::
Pinturicchio ::
Die Woodys returns
Unknown_001 ::
Definitivno FUN and COOL ! Že v teku učenja :D
Begabt
Napajalc ::
011011100111010101100010
Redorange ::
Kako je bolj hitro, podzemna al za tečt?:)
https://twitter.com/ReformedBroker/stat...
Tilen ::
 A1
A1
Anney ::
:D
IQ Veverica ::
 slotech sešn
slotech sešn
slotech sešn
Veveričev kotiček blaznih slotehovih idej:
https://www.facebook.com/So%C4%8Dne-slotehove-izjave-186246118552373/
Redorange ::
radmannsdorf ::
Letališče Sarajevo.
kuall ::
Tragikomedija:
kuall ::
Debelinko govori kot navit, zanimivo, da ne moreš nehat gledat, že 2x gledal.
http://iknowwhatyoudownload.com/en/peer/
malo vohunjenja kaj drugi dol vlečejo >:D
Prodaja Chrysler - Sunbeam ... beri opis :D
Povsem nedolžno se sprehajam po spletu, potem pa naletim na tole :P
delfinus ::
Ta si zasluzi deljenje :).
Napajalc ::
Če bi bil denar enakomerno razdeljen bi imeli 80% bogatih ljudi in 10% "revnih":
Cefizelj' ::
Šala iz filma Šund (Pulp Fiction, Quentin Tarantino, 1994).
Tole pa je eden najboljših pevcev :)) Nekdo ga knokavtira on pa še kar poje :)):)):))
  • spremenil: oo7 ()
:P
It's here! Dachshund tennis: Super Smash!
https://www.facebook.com/olympics/video...
HAHAHAHAHAHAHAA
175 / 182
