Funny and cool links
93 / 182
pivmik ::
Cool.
LP, Gregor GRE^
bradek ::
Staro ampak dobro:
Aircraft engineering support (lessons in communications and support
service)
According to the story, after every Quantas Airlines flight the pilots
complete a a 'gripe sheet' report, which conveys to the ground crew
engineers any mechanical problems on the aircraft during the flight. The
engineer reads the form, corrects the problem, then writes details of
action taken on the lower section of the form for the pilot to review
before the next flight. It is clear from the examples below that ground
crew engineers have a keen sense of humour - these are supposedly real
extracts from gripe forms completed by pilots with the solution
responses by the engineers. Incidentally, Quantas has the best safety
record of all the world's major airlines.
(1 = The problem logged by the pilot.)
(2 = The solution and action taken by the mechanics.)
1. Left inside main tire almost needs replacement.
2. Almost replaced left inside main tire.
1. Test flight OK, except auto-land very rough.
2. Auto-land not installed on this aircraft.
1. Something loose in cockpit.
2. Something tightened in cockpit.
1. Dead bugs on windshield.
2. Live bugs on back-order.
1. Autopilot in altitude-hold mode produces a 200 feet per minute descent.
2. Cannot reproduce problem on ground.
1. Evidence of leak on right main landing gear.
2. Evidence removed.
1. DME volume unbelievably loud.
2. DME volume set to more believable level.
1. Friction locks cause throttle levers to stick.
2. That's what they're there for.
1. IFF inoperative.
2. IFF always inoperative in OFF mode.
1. Suspected crack in windshield.
2. Suspect you're right.
1. Number 3 engine missing.
2. Engine found on right wing after brief search.
1. Aircraft handles funny.
2. Aircraft warned to straighten up, fly right, and be serious.
1. Target radar hums.
2. Reprogrammed target radar with lyrics.
1. Mouse in cockpit.
2. Cat installed.
1. Noise coming from under instrument panel. Sounds like a midget pounding on something with a hammer.
2. Took hammer away from midget.
iskra ::
Bradek: kraljevsko :D
Ajow! 5 metru drow ...
Če bi imel Ronaldinho izvenzakonskega sina, bi se klical Bastardinho.
whatever ::
lol, sploh zadnja je carska
BladE_ ::
LoooL
kr neki uglavnem je pa ql :D :D
Akcija - Reakcija
PrimozR ::
Tic ::
persona civitas ;>
christooss ::
enkrat sem splezal na drevo....in se usral z drevesa.....priletel je direkt na stor in se lepo razmazal
Ta je pa cko res huda :)
Zakaj je nebo modro? Da imamo lahko sladoled Modro Nebo
ripmork ::
LOOOL...naše male skrivnosti!...kere scene...:P
dela ::
Ne vem, če je kdo opazil...
Klik
Tisti, ki ste brali to temo, poglejte prvi post. Meni je prav hecen glede na nadaljevanje v threadu.
R33D3M33R ::
No, lol v eni temi se je pa en en hudo razjezil na siol :D
Trubadur ::
Debil, otrok ta hujše sorte.
Najbolj pa je k reče SUBJEKTIVNO mnenje:D :D
Tut pameten ni preveč
Berite Thomasa!
Darko ::
Tu je zanimiv trik prehajanja trdih predmetov skozi steklo (Trik). Ali kdo ve, kako so takile triki izvedeni?
SebaR ::
Če se gre že o teh stvareh si najdite še posnetek: David Blaine - Mystifier (Street Magic + Magic Man)
BladE_ ::
UN siolov ga OWNA :D :D
Akcija - Reakcija
  • spremenilo: BladE_ ()
b0B3k ::
Morda je že bilo, ampak vseen starwars convention
  • zavaroval slike: Tody ()
christooss ::
Tole je res kul. Nevem za kaj je tole že nagrada. Je pa blo to pred kšne pol leta objavlen :)
Goldee ::
Goldee ::
tomaz321 ::
300km/h po gorenjski avtocesti
No, sej tole ni nič posebnega, je pa iz domačih krajev
ReBi ::
ql
  • spremenil: ReBi ()
gumby ::
zelo kul ja... temu idiotu je treba dati mastno kazen in dozivljensko prepoved voznje:|
dirkalisca so namenjena za 300km/h, ne pa ceste ffs
St@jler ::
pred zid pa šus u glavo ;((
christooss ::
Very very very OLD:\
Thomas ::
Backup22 ::
Siol LOOOOOL
Upam da še tega ni bilo... >:D
Jst ::
Backup22 ::
LOL
  • spremenilo: Backup22 ()
Thomas ::
Tale motorist pa - me je prehitel. Avto (precej težek) se je nenadoma močno zagugal in pičil je mimo, oddaljujoč se skoraj 200 km/h.
Bo treba poklicat NATO avione iz aviana, da ga sestrelijo? :))
Backup22 ::
Uf na SIOL je že tema :) sry
>:D >:D >:D >:D
DOOM_er ::
bedna mtosev :\
Keyser Soze ::
OK. Zdaj pa verjetno že lahko dobiš uradno potrdilo iz kakšne ustanove.:|
R33D3M33R ::
Joj mtosev, jaz res ne vem ... :\
Korejci pa rulajo :D
@Keyser Soze
Ti nerazumeš zajebancije? :\
BladE_ ::
kr nekiiiii LOL :D :D :D
Akcija - Reakcija
gzibret ::
Ni glih funny, vsekakor pa cool!
Ohhh My Head
Vse je za neki dobr!
b0B3k ::
4679 - Lasko Netopir - Slovenia
5409 - Lasko Export Pils - Slovenia
7724 - Lasko Bandidos - Slovenia
sweet ...
strictom ::
Bad_CRC --- I went to the hospital today, and it's called "olmstead medical group" so the whole place had "OMG OMG OMG" all over it.
gzibret ::
Tole ba bolj funny, kot cool!
What European Tribes Think About One Another
Xplicit ::
lol @ smile pivo:
SCORE - 0,84
Per's comments: Golden colour with no head. Offensive sweet corn aroma. Syrupy, metallic, sweet and unclean without a trace of hops. I'm not smiling... :D lol
Nejc Pintar ::
LOL@ What Slovenians means:D
Pri vseh NRE
Lahko je biti prvi, če si edini!
gzibret ::
Ali pa Belgijci - o vseh ostalih nacijah si mislijo "bad beer"
Ziga Dolhar ::
[01:11] <Kviz>  Mih.1876. kdajksotnastalipbrižinskipspomeniki?l?
[01:11] <Kviz>  1st Hint: ******ž** **** *** **** **š** š******   Question Value : 183 Points
[01:12] <Kviz>  Time's up!  The answer was ->  približno 1000 let pred našim štetjem  <-
https://dolhar.si/
SynTax64 ::
Evo ena huda dobra prijatelja ! ! !:D :D
Dobriva prijatelja
R33D3M33R ::
Preveč je jedla. >:D
93 / 182
