Funny and cool links
78 / 182
christooss ::
Zakaj je nebo modro? Da imamo lahko sladoled Modro Nebo
speed machine ::
In nekaj slovenske izdelave. :D
Moj sošolec kot serviser. Boste se vsaj naučili kako zmonitrati mrežne kartice na matično ploščo.
LINK
christooss ::
DMouse ::
How did the ball get in here??
There was a knock at the door. It was a small boy, about six years old. Something of his had found its way into my garage, he said, and he wanted it back.
Upon opening the garage door, I noticed two additions: a ball and a broken window sporting a ball-sized hole. "How do you suppose this ball got in here?" I asked the boy.
Taking one look at the ball, one look at the window, and one look at me, the boy exclaimed, "Wow! I must have thrown it right through that hole!"
neoto ::
glede onega antiradar spreja:
Tilen ::
smeh
upam da ni sporno s strani pravil :)
drugac pa lololol :>
Matev ::
iration ::
Tudi jaz bi imel kakšno pravico rad v življenju. Npr. pravico do tega, da delam
12 ur na dan in sem za to nagrajen s strani delujočega ekonomskega prostora, ne
pa kaznovan s strani Salmoneličevih gremlinov. - NavadniNimda
mare_ ::
hm...
christooss ::
speed machine ::
speed machine ::
christooss ::
Sadida ::
TribesMan ::
TribesMan
peter00 ::
beljakovine v giru :O
da bomo zrasli veliki >:D
BaRtMaN ::
Hollywoodske zvezde v japonskih reklamah. Schwarzenegger je še posebej zabaven.
christooss ::
mchaber ::
I'm Not a Faggot!
Goodspeed ::
Mind reader : link
Tilen ::
lol
Zdaj je ze njih opralo.
Se malo pa bo kak fredyev copat gor al pa kaj.. 8-O
Tilen ::
Jackal ::
"Nespodobno opravilo" na kirurški mizi. >:D
  • zavaroval slike: Jackal ()
christooss ::
Za živčne. Upam da še niste dobl po mejlu:8)
Ziga Dolhar ::
Nekdo je bil zeloooooooooo obupan:
https://dolhar.si/
  • zavaroval slike: Tody ()
alum ::
klik
funny in hkrati cool mi je o ploscicah za ohisje:D
bradek ::
  • spremenil: bradek ()
Goldee ::
Huda! :D pravi biznismen...
http://www.bolha.com/oglas1182770 8-O
steev ::
Ehm, ali vaš sistem premelje to.
moderator: Klik na tole je na lastno odgovornost - po vsej verjetnosti bo prišlo do BSOD-a in nenadejanega restarta računalnika.
  • spremenil: perci ()
bradek ::
^- do not click ;>
Gandalfar ::
kaj je to, neka barvna stran. Kaj bi se mogl zgodit?
bradek ::
Zadeva ti naredi (kot sm uspel vidt) neko ogromno polje (sliki poda parameter width in height 999999999) in ti usuje sistem... sicer nevem zakaj ampak jst sm fasal bluescreen pa reset ;>
Najverjetneje memory problem (FF104&wXP).
bond007 ::
Enako pri meni .. reset. Neverjetno, kak je to sploh možno... pa na polno sm neki vleku dol. Ka če bi glih DVD peku ... bi ga zajebu. Vlko sraje tole. Bom šeenkrat probu z IEjem odpret...
l-note ::
Enako klele.
Matev ::
jaz bi piscu tega posta (ki zašteka če klikneš link) odredil prepoved obiska slo-techa
hunter01 ::
Hudooo >:D To bom vsem po msn-ju poslal kot kao neka huda fora >:D >:D >:D >:D >:D >:D
Aja... reset prez razmisleka (računalnik samovoljno se ve..) 8-)
SebaR ::
Meni se ni usul, preden je malce zmrnil sem kliknil na križec da mi zapre okno. Potem zmrzne čez par sekund pa sistem nazaj z zaprtim oknom :D
Moj PC je prestal test =>
hunter01 ::
to ko si prej prebral vse poste pa si nisi upal do konca počakat. doh >:D
Matev ::
a ni to isto kot če virus pošlješ?
sesuješ nekomu sistem med delom
Gandalfar ::
bradek: zanimivo, ker meni pod linuxom niti miska ne trzne med loadanjem. Pri kaksni drugi fori mi pa tud zacne stekat.
nikonezna ::
blue screan....da ne bi dobu on plavega očesa...še dobro da nisem delal vmes kaj za službo...
brez podpisa
The B ::
Men je tud preživu. Mal je bil neodziven, mal je pisknu, pol sm prtisnu ctrl+alt+delete, pa je začel delat, pol sm zapru task managerja, pa se spet ni odzivu in nato končno ugasnu "kriv" zavihek. Dost kul...
B
The End Is The Beginning Is The End...
http://blaze.sopca.com/
christooss ::
No toje originalna slika iz linka
McMallar ::
Meni ni sistem niti trznil. Vse je delalo OK na Operi 8.
Because OCT31 = DEC25
TribesMan ::
Meni ni zmrznil (firefox)... mogoče pomaga 2GB RAMa?
TribesMan
christooss ::
Men tud ne no:\
BladE_ ::
tole sploh ni funny al pa cool ! ! ! ker men se je to lih med pecenjem zgodil ;(( ! zakaj lih men ???
Akcija - Reakcija
steev ::
LoL: men se je od treh poskusov enkrat sesu. P4 user here :))
Goldee ::
:D men pa se je kr samodejno restartal in potem ka sm znova zagnal xpje se mi je napisalo da je bil nek error od grafe :|
athlon drgac...
gzibret ::
Moj prvi blue screen na winXP do sedaj......
Vse je za neki dobr!
78 / 182
