Forum » Programiranje » Custom AJAX extender control - klicanje s codebehind
Seth ::
Naredil sem custom ajax extender, ki ga pripnem na gumb (server control). Spodnji primer je trivialen, ampak gumb na katerem definiram ta extender zažene alert('OK') v spodnji JS datoteki, kar deluje po pričakovanjih. Zanima me kako pognati ta isti "alert" preko codebehind. V .cs datoteki imam metodo CallMethod(), ki bi po mojem razumevanju nekako morala poklicati funkcijo v .js.
Hvala za kakršno koli idejo!
extendercontrol.cs
in ClientBehavior1.js
extendercontrol.cs
using System;
using System.Collections.Generic;
using System.Configuration;
using System.Linq;
using System.Web;
using System.Web.Security;
using System.Web.UI;
using System.Web.UI.WebControls;
using System.Web.UI.WebControls.WebParts;
using System.Web.UI.HtmlControls;
using System.Xml.Linq;
namespace AExtender
TargetControlType(typeof(Button))
public class ExtenderControl1 : ExtenderControl
protected override IEnumerable<ScriptDescriptor>
GetScriptDescriptors(System.Web.UI.Control targetControl)
ScriptBehaviorDescriptor descriptor = new ScriptBehaviorDescriptor("AExtender.ClientBehavior1", targetControl.ClientID);
yield return descriptor;
// Generate the script reference
protected override IEnumerable<ScriptReference>
GetScriptReferences()
yield return new ScriptReference("AExtender.ClientBehavior1.js", this.GetType().Assembly.FullName);
protected void CallMethod()
// Del kjer naj bi extender pognal preko codebehind z enakim efekotom kot z gumbom
}in ClientBehavior1.js
Type.registerNamespace("AExtender");
AExtender.ClientBehavior1 = function(element) {
AExtender.ClientBehavior1.initializeBase(this, [element]);
var _clickDelegate = null;
AExtender.ClientBehavior1.prototype = {
initialize: function () {
AExtender.ClientBehavior1.callBaseMethod(this, 'initialize');
var e = this.get_element();
e.onclick = function () { return false };
this._clickDelegate = Function.createDelegate(this, this._onClickDelegate);
$addHandler(e, "click", this._clickDelegate);
_onClickDelegate: function (sender, ea) {
alert('OK');
dispose: function () {
AExtender.ClientBehavior1.callBaseMethod(this, 'dispose');
AExtender.ClientBehavior1.registerClass('AExtender.ClientBehavior1', Sys.UI.Behavior);
if (typeof(Sys) !== 'undefined') Sys.Application.notifyScriptLoaded(); Seth
| » | ASP.NET + C# vprašanjeOddelek: Programiranje | 3290 (2304) | Morenov |
| » | ASPX preusmeritvena zankaOddelek: Programiranje | 2458 (2363) | Senzacionale |
| » | [c#]4 v vrsto - padanje krogovOddelek: Programiranje | 2380 (2212) | VASkO |
| » | [ ASP.NET ] Vprašanje glede podajanja parametrovOddelek: Programiranje | 1875 (1606) | salesky |
| » | [.NET ASP] Napaka : Specified cast is not validOddelek: Programiranje | 1511 (1464) | pinc |
