VB - database
VB - database
korenje3 ::
Zakaj tale reč ne dela?
        Dim newCustomersRow As DataRow = DataSet1.Tables("DataTable1").NewRow()
        newCustomersRow("CustomerID") = "ALFKI"
        newCustomersRow("CompanyName") = "Alfreds Futterkiste"
        DataSet1.Tables("Customers").Rows.Add(newCustomersRow)
        MsgBox(newCustomersRow("CustomerID"))
Sem naredil Dataset1 in DataTable1 z vb2010, ampak mi prebere...
korenje3 ::
v bistvu samo malo da manipuliram v kodi s tem, pa mi neha delat...
recimo tole mi normalno dela...
MsgBox(DataTable1.TableName)
takole pa ne več...
DataTable1.Rows.Add({"a"})
enako za zgoraj...
[VB] datagridview
Oddelek: Programiranje
352334 (1717) korenje3
c# - mssql kombinacija / problem pri zapisu row-a v bazo
122153 (1962) darkolord
vb mysql dataset update
81653 (1533) korenje3
DataView, DataTable, DataSet
91482 (1233) detroit
[C#] DATA GRID VIEW
132317 (2197) Kekec
