Forum » Operacijski sistemi » Debian - Daemon script
_Dejan_ ::
Pozdravljeni,
Imam Debian GNU Linux 6.0(Kernel 2.6.36.3) in majhen problem pri ustvarjanju daemon skripte katera ob zagonu požene custom mono aplikacijo.
Aplikacijo normalno začenem če uporabim komando:
Aplikacija se normalno zažene če uporabim komando:
ali
Za osnovo sem vzel skeleton skripto ki se nahaja v /etc/init.d/ folderju in jo preuredil, vendar ne deluje.
Skripta se nahaja v /etc/init.d/ in ima ime WatchDog (brez končnice)
Koda v skripti:
Skripto sem skopiral iz FTP-ja z uporabo wget nato nastavil pravice:
Ko sem pognal:
sem dobil:
če pokličem start ali stop gre samo v new line proces pa se ne zažene:
Mogoče kdo ve kaj delam narobe?
Hvala za kakršnokoli pomoč.
/usr/bin/mono /usr/userapps/WatchDog/WatchDog.exe
start-stop-daemon --start --quiet --pidfile /var/run/WatchDog.pid --exec /usr/bin/mono -- /usr/userapps/WatchDog/WatchDog.exe > /dev/null
ali
Koda v skripti:
#! /bin/sh
### BEGIN INIT INFO
# Provides: WatchDog
# Required-Start: $remote_fs $syslog
# Required-Stop: $remote_fs $syslog
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: WatchDog initscript
# Description: This file should be used to construct scripts to be
# placed in /etc/init.d.
### END INIT INFO
# Author: Developer <info@email.si>
# Please remove the "Author" lines above and replace them
# with your own name if you copy and modify this script.
# Do NOT "set -e"
# PATH should only include /usr/* if it runs after the mountnfs.sh script
PATH=/sbin:/usr/sbin:/bin:/usr/bin
DESC="Watch Dog service"
NAME=WatchDog
MONO=/usr/bin/mono
DAEMON=/usr/userapps/WatchDog/$NAME.exe
DAEMON_ARGS=""
PIDFILE=/var/run/$NAME.pid
SCRIPTNAME=/etc/init.d/$NAME
# Exit if the package is not installed
[ -x "$DAEMON" ] || exit 0
# Read configuration variable file if it is present
[ -r /etc/default/$NAME ] && . /etc/default/$NAME
# Load the VERBOSE setting and other rcS variables
. /lib/init/vars.sh
# Define LSB log_* functions.
# Depend on lsb-base (>= 3.2-14) to ensure that this file is present
# and status_of_proc is working.
. /lib/lsb/init-functions
# Function that starts the daemon/service
do_start()
echo "PID: " $PIDFILE " MONO: " $MONO " DAEMON: " $DAEMON
# Return
# 0 if daemon has been started
# 1 if daemon was already running
# 2 if daemon could not be started
start-stop-daemon --start --quiet --pidfile $PIDFILE --exec $MONO -- $DAEMON > /dev/null \
|| return 1
start-stop-daemon --start --quiet --pidfile $PIDFILE --exec $MONO -- $DAEMON \
|| return 2
# Add code here, if necessary, that waits for the process to be ready
# to handle requests from services started subsequently which depend
# on this one. As a last resort, sleep for some time.
# Function that stops the daemon/service
do_stop()
# Return
# 0 if daemon has been stopped
# 1 if daemon was already stopped
# 2 if daemon could not be stopped
# other if a failure occurred
start-stop-daemon --stop --quiet --retry=TERM/30/KILL/5 --pidfile $PIDFILE --name $NAME
RETVAL="$?"
[ "$RETVAL" = 2 ] && return 2
# Wait for children to finish too if this is a daemon that forks
# and if the daemon is only ever run from this initscript.
# If the above conditions are not satisfied then add some other code
# that waits for the process to drop all resources that could be
# needed by services started subsequently. A last resort is to
# sleep for some time.
start-stop-daemon --stop --quiet --oknodo --retry=0/30/KILL/5 --exec $MONO -- $DAEMON
[ "$?" = 2 ] && return 2
# Many daemons don't delete their pidfiles when they exit.
rm -f $PIDFILE
return "$RETVAL"
# Function that sends a SIGHUP to the daemon/service
do_reload() {
# If the daemon can reload its configuration without
# restarting (for example, when it is sent a SIGHUP),
# then implement that here.
start-stop-daemon --stop --signal 1 --quiet --pidfile $PIDFILE --name $NAME
return 0
case "$1" in
start)
[ "$VERBOSE" != no ] && log_daemon_msg "Starting $DESC" "$NAME"
do_start
case "$?" in
0|1) [ "$VERBOSE" != no ] && log_end_msg 0 ;;
2) [ "$VERBOSE" != no ] && log_end_msg 1 ;;
esac
stop)
[ "$VERBOSE" != no ] && log_daemon_msg "Stopping $DESC" "$NAME"
do_stop
case "$?" in
esac
status)
status_of_proc "$DAEMON" "$NAME" && exit 0 || exit $?
#reload|force-reload)
# If do_reload() is not implemented then leave this commented out
# and leave 'force-reload' as an alias for 'restart'.
#log_daemon_msg "Reloading $DESC" "$NAME"
#do_reload
#log_end_msg $?
restart|force-reload)
# If the "reload" option is implemented then remove the
# 'force-reload' alias
log_daemon_msg "Restarting $DESC" "$NAME"
do_stop
case "$?" in
0|1)
do_start
case "$?" in
0) log_end_msg 0 ;;
1) log_end_msg 1 ;; # Old process is still running
*) log_end_msg 1 ;; # Failed to start
esac
# Failed to stop
log_end_msg 1
esac
#echo "Usage: $SCRIPTNAME {start|stop|restart|reload|force-reload}" >&2
echo "Usage: $SCRIPTNAME {start|stop|status|restart|force-reload}" >&2
exit 3
esac
chmod 755 WatchDog
Ko sem pognal:
update-rc.d WatchDog defaults
sem dobil:
update-rc.d: using dependency based boot sequencing
service WatchDog start
ASUS P5E3, INTEL Q6600(3000Mhz 333x9), ATI HD 2600XT,
A-Data 4x2GB PC3-10700H(9-9-9-24-2T),LSI 9260-8i,
4x OCZ Vertex Turbo 30GB(RAID10), 3x1TB (RAID1+Spare)
| » | problem pri sprembi root gesla v MySQL v UbuntuOddelek: Pomoč in nasveti | 1724 (1304) | killa bee |
| » | systemctl zagon programaOddelek: Pomoč in nasveti | 1576 (1537) | korenje3 |
| » | [Ubuntu server] mail poslan iz serverja zazna kot vsiljeno pošto (strani: 1 2 )Oddelek: Omrežja in internet | 11020 (9990) | shorvat |
| » | [JAVA] zaustavitev niti (threadov)Oddelek: Programiranje | 3679 (3679) | morbo |
| » | Zaščita za otrokeOddelek: Programska oprema | 1344 (1114) | Groove |
