Battlefield 3
Battlefield 3
Freaxx ::
Hvala ti, pol bom pa za 30 eurov nabavu pa bo ze moglo delat ane :)
deadbeef ::
http://www.pcgamer.com/2011/09/23/battl...
DICE community manager Daniel Matros has been answering questions about Battlefield 3 on Twitter. Battlefield fan @bkohn1 asked him whether a rig matching the Battlefield 3 recommended system requirements would run the game on ultra settings. Matros replied to say that "recommended is usually medium."
So will a top of the range Nvidia GTX580 do the trick? Apparently not. Matros revealed that we'll need two 580s in SLI to make the most of the Frostbite 2 engine. The minimum system specifications may not be too punishing, but for those who want to see Battlefield 3 at its very best, a hefty upgrade may needed. Battlefield 3 may well be worth the expense. Would you be tempted to upgrade?
Še GTX 590 bo premal za na Ultra.
Freaxx ::
Sej, samo minimum pa bo zgledal kar vredi tako da bo ultra samo za tiste k res hočjo to. Low nastavitve bojo kmau ratale medium xD Sicer pa je za vse to beta
  • spremenil: Freaxx ()
norgur8 ::
https://twitter.com/#!/repi/status/117250670511407105
^ Recommended settings are for High, tako da ni take panike kot bi bila sicer.
Freaxx ::
Ja to se tudi men zdi, to je bolj nekakšen potrošniški prijem, da mogoče katera firma malo zasluži preden beta oz. igra sama sploh ven pride.
Polarni_Medo ::
Ali bo imela ta igra najbolso grafiko na trzišču iger? Katera igra pa sedaj velja za najbol grafično dodelano?
Freaxx ::
ja engine bo res NEKAJ, za popolen izkoristek nevem kak crossfireX sistem pa to, tako da ja ta je ena najbolših se mi zdi.
Rippy ::
Polarni_Medo je izjavil:
Ja naj bi imela najboljšo grafiko ob izidu. Glede drugega vprašanja je pa teško odgovorit...Crysis (2007) ali pa Crysis 2(2011). Osebno mislim, da je najbolj impresivna še vedno Crysis (v določenih trenutkih).
norgur8 ::
Rippy je izjavil:
V smislu fotorealizma je Crysis vsekakor zmagovalec, sicer pa menim, da je The Witcher 2 najbolj grafično dodelana igra do tega trenutka.
Dua'L ::
Tisti, ko niste kupili moh si boste lahko 27 ogledali live stream beto: http://bf3stream.com/
GTX680
Intel i7 2600
8gb DDR3
edi123 ::
jaz sem kupo tu http://www.gamekeystore.net/newstore/ba... mislim da med najcenejšimi čene najcenejši BF3 na netu. dobiš poskenirano škatlo na mail to je to.
Freaxx ::
Ja ce ti bojo pravo poslali in bo celo vredi delalo, svaka čast.
edi123 ::
sem že 2x kupo in je delalo brez problema
chucki ::
http://twitter.com/#!/EA_Australia/status/118217369570131968
Dua'L ::
Downloads:
Win7/Vista 32bit.: http://us.download.nvidia.com/Windows/2...
Win7/Vista 64bit.: http://us.download.nvidia.com/Windows/2...
Release Notes.: http://us.download.nvidia.com/Windows/2...
New in Release 285.38
Increases performance in Battlefield 3 by up to 38%i.
Improves overall stability and image quality in Battlefield 3.
Added or updated SLI profiles for Battlefield 3, Dead Island, Diablo III, Dragon Age 2, Need for Speed: The Run, and Saints Row: The Third.
Fixed a performance regression in 285.27 beta running Crysis 2 (DirectX 9).
Other Details:
Supports GeForce 6, 7, 8, 9, 100, 200, 300, 400, and 500-series desktop GPUs as well as ION desktop GPUs.
Installs PhysX System Software to version 9.11.06.21.
Installs HD Audio driver to version 1.2.24.0.
Supports OpenGL 4.2 for GeForce 400 series and 500 series GPUs and OpenGL 3.3 for GeForce 8-series and later GPUs.
Supports multiple languages and APIs for GPU computing: CUDA C, CUDA C++, CUDA Fortran, OpenCL, DirectCompute, and Microsoft C++ AMP.
Supports single GPU and NVIDIA SLI technology on DirectX 9, DirectX 10, DirectX 11, and OpenGL, including 3-way SLI, Quad SLI, and SLI support on SLI-certified Intel and AMD motherboards.
Supports GPU overclocking and temperature monitoring by installing NVIDIA System Tools software.
Users without US English operating systems can select their language and download the International driver here.
i - Performance measured vs. GeForce 285.27 driver on GeForce GTX 570 at 2650x1600 (DX11).
GTX680
Intel i7 2600
8gb DDR3
  • spremenil: Dua'L ()
chucki ::
Danke... :D
globoko grlo ::
+finke&španke
McGregorSL ::
A crossfire podpira že na default ali ga sploh ne podpira?
Evo, pravkar "took the plunge" in naročil pri buygamecdkeys.
Če še kdo želi...Na facebooku dobite njihovo kodo za 5% popust (FBFANBGCKFH5711) in torej končno ceno 25.4$. So pa legalni, ker sem temeljito preveril. 8-)
Jerry000 ::
edi123 je izjavil:
mhm, zarad takih pa dobivajo keš one fake strani ker take ribe kot si ti hit nasedejo;)
Dua'L ::
GTX680
Intel i7 2600
8gb DDR3
  • zavaroval slike: ahac ()
Spock83 ::
Wiiiiii :)
chucki ::
Hiter atiju povedat, da je kupil dobro grafično... :D
Spock83 ::
Jaz sem sam s svojim denarjem kupil. ;)
Freaxx ::
jez pa bom lepo an beto pocaku, pol pa hit narocit ce bo vredi delalo :)
gigibox ::
ali pa gtx 570 navit na 580... pol na na ultra
Dua'L ::
GTX680
Intel i7 2600
8gb DDR3
Jerry000 ::
ijooo hud trailer z komadom:D. Jay Z zakon
edi123 ::
Jerry000 je izjavil:
edi123 je izjavil:
ne bluzi neke...
Jerry000 ::
edi123 je izjavil:
edi123 je izjavil:
ne bluzi neke...
Ne bluzm, sam pravm kr je res:)
Freaxx ::
ja ce ti dajo original, pol niso fake ane? Sam če majo tolko prometa ko folk pise ja pol nekaj ze morjo dobr delat...?
Jerry000 ::
Freaxx je izjavil:
Seveda dobr delajo, tut lopovi dobr delajo:). Če ti dajo pa original pol si lhka vesel, če pa ne so pa oni dnar dobil in gredo naprej, od tega pa služijo:)
BALAST ::
How to access the beta
EA will send out emails with beta codes and a link to where you can redeem the code and download the beta.
The emails will be sent out to those who pre-orderd on Origin (to your Origin email account). Emails will also be sent out to Medal Of Honor users to their EA master account emails.
Steam owners of Medal of Honor will receive the beta code in their MoH Steam page, under "CD Keys".
Emails will be sent out later today/tonight.
Xbox 360 and PlayStation 3 owners will get mails sent to the email address they used for their pre-order. MoH owners will receive the email to the address they used to sign up for the early beta (redeemed your Online Pass).
The beta is estimated at 2.6 GB.
Beta start times
For those with early access, the beta starts on September 27 at these times:
5 AM US Pacific
8 AM US Eastern
2 PM Central Europe (14:00)
10 PM AEST (Australia)
9 PM JST (Japan)
Dua'L ::
GTX680
Intel i7 2600
8gb DDR3
jizzer ::
Torej če hočeš BETO špilat moreš met pre-order ali pa kupljen MOH na steamu? Mi userji brez tega pa smo tut brez bete al kaj?
Mcsin ::
jizzer je izjavil:
Tisti ki imajo pre-order lahko igrajo že 27tega torej jutri, open-beta za vse pa se začne 29ga.
Jerry000 ::
preorder velja samo za origin ali tudi če daš preorder ju3 na zavvi?
Mcsin ::
Kolikor je meni znano je samo za preorderje, ki so bili kupljeni do 25. septembra na Originu.
RejZoR ::
Po dolgem času bom naredil izjemo in si bom vseeno omislil Battlefield 3 ter ko izide Modern Warfare 3 še tisto. 2 streljačini po dolgem času iz teh dveh serij, ki sta mi noro zanimivi. Sicer sta dost dragi sam jebi ga. Zakaj pa ne.
Spock83 ::
Ql bomo kdaj kakšno skupaj nažgal.
Dua'L ::
GTX680
Intel i7 2600
8gb DDR3
Samo ta letala so pa res popolno neuporabno sranje in edini njihov namen je marketing..
g. Oden ::
DarwiN je izjavil:
S tem se pa žal moram strinjat.
Dua'L ::
Ko bi vsaj imela letala rakete gor.. ima samo mitralez.
GTX680
Intel i7 2600
8gb DDR3
BALAST ::
Če iščeš pravo letalsko simulacijo, BF3 ni pravi naslov. :D
Nevem zakaj bi koga motilo če so letala v igri tudi za pilotirat?
arjan_t ::
Dua'L je izjavil:
mislim da jih moraš "unlockat"
Spock83 ::
Dua'L je izjavil:
Še bolje, da je samo top gor. Bodo lahko epski dog fighti :D
OmegaBlue ::
Nja jaz tud nisem preveč navdušen nad njimi. Bomo vidil kako se gameplay obnese, da ne bomo samo na filmčkih sodil.
gigibox ::
ah...na koncu bo pa razočarala kot crysis 2
glistovje ::
jebš letala, vazn da je combat na tleh poštiman :) bolje da bi dali kake cross-ke kot pri war rocku
17 / 149
