Forum » Programiranje » sql max count
sql max count
boss-tech ::
Spodaj najdem prenočišče z največ gosti. v select sem dal count (število gostov) + naziv prenočišča.
Kako lahko zgoraj pri max dobim še naziv? Ker spodnja koda mi vrže error (Error code -1, SQL state 42Y35: Column reference 'NAZIV' is invalid. When the SELECT list contains at least one aggregate then all entries must be valid aggregate expressions.
Line 2, column 1)
Line 2, column 1)
#prenocisce z najvec gosti select max(cnt),naziv from ( select count(naziv)as cnt, naziv from prenocisca inner join sobe on sobe.pre_id_prenocisce = prenocisca.id_prenocisce inner join gosti on gosti.sob_id_soba = sobe.id_soba group by naziv )f
WarpedGone ::
select naziv
from
select count(naziv) as cnt,
naziv
from prenocisca,
sobe,
gosti
where sobe.pre_id_prenocisce = prenocisca.id_prenocisce
and gosti.sob_id_soba = sobe.id_soba
group by naziv
order by 1 desc
)f
where rownum < 2
select naziv
from
naziv
from prenocisca,
sobe,
gosti
group by naziv
order by 1 desc
)f
where rownum < 2
Zbogom in hvala za vse ribe
boss-tech ::
Order by ne pusti... ko ga odstranim pa dobim: Column 'ROWNUM' is either not in any table in the FROM list or appears within a join specification and is outside the scope of the join specification or appears in a HAVING clause and is not in the GROUP BY list. If this is a CREATE or ALTER TABLE statement then 'ROWNUM' is not a column in the target table.
WarpedGone ::
Potem pač Order by prestavi nivo višje.
Očitno tvoja baza ne pozna ROWNUM funkcije.
dice7 ::
poskusi s tem
SELECT COUNT(p.naziv), p.naziv FROM prenocisca p INNER JOIN sobe s ON s.pre_id_prenocisce = p.id_prenocisce INNER JOIN gosti g ON g.sob_id_soba = s.id_soba GROUP BY p.naziv ORDER BY COUNT(p.naziv) DESC LIMIT 1;
- spremenil: dice7 ()
| » | Sql poizvedbaOddelek: Programiranje | 1813 (1317) | zgubar |
| » | Podatkovne baze - SQL enostavne poizvedbeOddelek: Programiranje | 2526 (2119) | galu |
| » | SQL poizvedbaOddelek: Programiranje | 4181 (3526) | awy |
| » | sql select stavekOddelek: Programiranje | 1903 (1805) | zavajon |
| » | MYSQL vprašanjeOddelek: Programiranje | 2171 (1786) | MrBrdo |
