Forum » Zvok in slika » Program za preimenovanje slik
vratar ::
Zanima me, če obstaja kak enostaven program za preimenovanje slik? Sedaj so slike označene z DSC00123 jaz pa bi to rad naredu svoj opis slike.
milc ::
Jaz mam sicer sprogramiran program, ki mi naredi še direktorij glede na datum slikanja.
Lahko si pomagaš s tem: http://www.microsoft.com/windowsxp/usin...
Moj programček, star, zelo star (skopiraj v file recimo move2dirs.pl) daj v isti direktorij, kjer imaš slike, instaliraj perl (recimo http://www.activestate.com/)
#!/usr/bin/perl
# Move the files into directories based on modification date of the file
use strict;
use warnings;
use File::stat;
use File::Copy;
my $dir = '.';
print "Start:\n";
opendir(DIR, $dir) or die $!;
my $i=0;
my @FILES;
while (my $file = readdir(DIR)) {
# Use a regular expression to ignore files beginning with a period
next if ($file =~ m/^\./);
next unless (-f "$dir/$file");
next if ($file =~m/move2dirs/); # ignore the perl script - this file
$FILES[$i++] = "$file";
print "$i > $file\n";
closedir(DIR);
my $filename;
my $sb;
my $targetdir;
my ($dev,$ino,$mode,$nlink,$uid,$gid,$rdev,$size,
$atime,$mtime,$ctime,$blksize,$blocks);
my ($sec,$min,$hour,$mday,$mon,$year,$wday,$yday,$isdst);
foreach $filename (sort @FILES)
# print "$filename ..";
# ($dev,$ino,$mode,$nlink,$uid,$gid,$rdev,$size,
# $atime,$mtime,$ctime,$blksize,$blocks)
# = stat($filename);
$sb = stat("$dir/$filename");
printf "File is %s, size is %s, perm %04o, mtime %s ...",
$filename, $sb->size, $sb->mode & 07777,
scalar localtime $sb->mtime;
# 0 1 2 3 4 5 6 7 8
($sec,$min,$hour,$mday,$mon,$year,$wday,$yday,$isdst) =
localtime($sb->mtime);
$year+=1900;
$mon++; $mon = sprintf( "%02d", $mon);
$mday = sprintf( "%02d", $mday);
$targetdir = $year . "_" . $mon . "_" . $mday;
print "Modified: $targetdir\n";
mkdir "$dir/$targetdir" if(!-d "$dir/$targetdir"); # Create a dir using the name of the target dir
move("$dir/$filename", "$dir/$targetdir/$filename") or die "move failed: $!"; # Moving file
| » | upload zip datotek (slike)Oddelek: Izdelava spletišč | 1539 (1325) | Veron |
| » | php $_FILE in praviceOddelek: Izdelava spletišč | 1048 (975) | psychoP |
| » | PHP problem z direktorijamiOddelek: Izdelava spletišč | 1109 (1005) | rokpok |
| » | preimenovanje 700 slik naenkratOddelek: Programska oprema | 2278 (2027) | Mercier |
| » | Program ki extract-a filename in ga prilepi v tabelo...Oddelek: Programska oprema | 1427 (1379) | 2tiLen |
