Forum » Strojna oprema » AMD Bulldozer
AMD Bulldozer
SuperVeloce ::
Za multitasking (in recimo brskalnike, kateri odprejo novo nit/proces za vsak zavihek) bo super, vsekakor težka konkurenca ostalim ulv.
Isotropic ::
The low CPU performance, in more detail the low performance per core, slows down the graphics card in many games. We want to illustrate this with an example:
AMD's new APU leaves a mixed impression in our first test. In consideration of current software, it does not appear to be sensible to incorporate four relatively slow cores. This is not only true in applications. The weak CPU part also slows down the relatively powerful graphics unit. Faster Kabini APUs with up to 2.0 GHz clock rate could perform better here.
A samo to si prebral?
Tc tc tc tc tc.
Na, da ne boš samo negativizem iskal :D
The performance is remarkable compared to Intel's Atom and current ARM SoCs. In addition, the performance reserves are absolutely sufficient for office and multimedia. Furthermore, the power consumption is low enough that also small devices can drain the waste heat without problems.
Tc tc tc tc tc.
- spremenil: D3m ()
Dober je tale APU. Boljši, od mojega E-450. Malo me moti glede gonilnikov 12.102.1.1000, ki so jih uporabili.
- spremenil: D3m ()
Isotropic ::
jah, samo vidis pa tut, da je na taskih, ki ne rabijo veliko jeder, komaj kaj boljsi od e-450.
Frekvenca ga daje. Sicer super stvar a raje bi videl, če bi bil na istih frekvencah, kot E-450.
Isotropic ::
bolj preveliko stevilo jeder.
tut za v telefone je bolje imeti 2 hitri jedri kot 4 pocasna.
nope.. V telefonu je ravno 4 počasna in varčna jedra bolje met kot pa 2 hitri.
x45 ::
Richland , cene frekvence in nekateri scori , Basemark CL in 3 D mark :)
http://www.computerbase.de/news/2013-05...
AMD x4 965 BE, 8 gb ddr3 1600, SSD Samsung, 960 GT
Xeon x3430, 8 GB DDR3, Matrox grafa
- spremenilo: x45 ()
hehehe isto sranje drugo pakovanje...
In kekci primerjajo intel proc z hd 2500.... sj ne da obstaja tud hd 4000...
Bomo počakali na uradne teste. Drugače pa HD 4000 je tam tam konkurenca Llano APU, kot pa Trinity.
- predlagal izbris: iloveboobz ()
x45 ::
razlike glede plošč ( ki nekatere ovirajo AMD FX cpu je ) pri enakaem čipsetu.
Naskok 16 faznega Asrocka z 990 FX je zelo velik:
http://www.tomshardware.co.uk/990fx-mot...
velik naskok ?
pri večina testov meni zgledajo rezultati v okviru napak pri merjenju, sepravi razlik skoraj ni..
iloveboobz je izjavil:
dokaz za to ?
Malo se sprehodi po Googlu. Zakaj morajo drugi tebi na pladnju nostiti informacije.
kulker jst vidim, so še vedno hd6xxx based grafike noter in piledriver jedra.
Sepravi isto kot trinity, sam višji clocki..
- spremenil: iloveboobz ()
Še malo boš moral brskati.
"Enhanced Piledriver" CPU cores
On-die Radeon HD 7000 Series (not Graphics Core Next) graphics chipset
Temperature Smart Turbo Core technology. An advancement of the existing Turbo Core technology, which allows internal software to adjust the CPU and GPU clock speed to maximise performance within the constrains of the Thermal design power of the APU.
Gpu je se vedno vliw4. Nic novega torej.
So pa enhanced, kot slike v csi XD
- spremenil: Dr_M ()
Doktorju jih poka.
P.S.
Ta premium od nvidie še zmeraj ne dela dobro, kot si ga omenjal. Sem pričakoval bolj enhanced driverje za premium ceno
P.S.
Se vedno so manj slabi, kot pri amdju. Niso pa vec tisto, kar so bili ucas, to je res. :>
Se vedno pa velja pebkac.
točno to kar sem zgoraj napisal.
Samo OC trinity in nič druga. Tista Enhanced jedra pa vsi vemo kaj to pomeni pri amd..
Kar so bili učas? Doktor sam ne mi o časih sem imel dovolj dela z njimi tudi prej aka ForceWare.
@hojnikb
Nekaj malega so spremenili napram Piledriverju 1.0., grafika so pa tudi izboljšali (Radeon cores 2.0).
mešanje sranja torej.. Raje bi izdal kaverija...
Boš moral počakati na konec leta oz. Q3 2013
hmmm le zakaj mam občutek, da amd nebo izdal nove arhitekture že po parih mescih ?
(hint: stare zaloge)
filip007 ::
Asrock 990Fx Extreme9 je za okoli 10FPS hitreješa od Gigabyte in Asus pod Far Cry 3, ni čudež samo nekaj pa je.
HP prenosnik, Xbox SX in Hisense Qled.
Spock83 ::
A se splača nabavit AMD A4 4000 BOX procesor in matično + rame za nadgradnjo že kar stare kište Athlon 3200+? Cena je smešna.
Based on the specs, the A4-4000 should perform close to A4-5300 in graphics applications, and about 10% - 12% worse in CPU intensive tasks. As a refresher, the A4-5300 was already pretty slow, matching Athlon 64 X2 5400+ performance in multi-threaded CPU tests.
Vir: CPU World
Se splača.
Vir: CPU World
Se splača.
- predlagalo izbris: klinker ()
fireX88 ::
privoščiš tašči :D
klinker ::
Vir: CPU World
Se splača.
Pa to se najcenejsi Pentium poseka
PS: Po nesreci kliknu "predlagaj izbris". Lahko bi to opcijo malo drugace postavli, ne pa zraven "citiraj"
Spock83 ::
Ma za ta low cost segment je vseeno pa dam še priložnost AMDju. :)
Načeloma lahko takoj dobim A4-5300 za enako ceno ali je bolje da počakam še 10 dni pa nabavim novejšega A4-4000?
Heh Futuremark še ni popravil anomalijo pri A6-5400K na, kar sem jih opozoril.
A4-5300
3DMark CPU Score: 3280
A6-5400K
3DMark CPU Score: 1790
A4-5300
A6-5400K
fireX88 ::
nisem mislil zato ker je amd shit varianta, ampak zato ker je tašča pa ji ne kaj v višjem rangu privoščiš, pa naj bo to AMD ali pa Intel.
Za fotra sem vzel podobno varianto, pa je zadovoljen!
Spock83 ::
Ma za facebook, email počekirat pa kakšen youtube filmček je čisto dost in samo to uporablja. Ji bom dodal še SSD ;)
fireX88 ::
:D
potem pa poročaj, če te bo imela kaj bolj rada!
Spock83 ::
Ma me še preveč rada ;)
Edit: a pri teh BOX procesorjih pride zraven hladilnik?
- spremenil: Spock83 ()
Isotropic ::
tisti 8-jedrni steamroller z 8ch ram in enim kupom shaderjev je fake.
moram reci, da mi je bilo sicer cudno, kako bi vse to spravili na en cip (4096 shaderjev se mi zdi, 7970 jih ima pa tocno polovico).
sploh ker interposer ipd. se ni pripravljen pri GF in se nekaj casa ne bo. (ce bi bil, bi verjetno slo kot multi-chip module z sirokim vodilom)
filip007 ::
Ja Demise ima na Bolhi, AMD A-Series A4-3300 in MSI A55M-P33, A55 za 95€, ni ravno 100€ PC je pa blizu. Če komu leži na okoli kak RAM, napajalnik, ohišje, disk, DVD, je to že kar to.
