AMD Bulldozer
AMD Bulldozer
JC Denton ::
Na to sem naletel učeri
2/21/2012 7:32 AM EST
LONDON - Advanced Micro Devices Inc. has achieved the first commercial implementation of resonant clock mesh technology licensed from startup company Cyclos Semiconductor Inc.
AMD's 4+ GHz x86-64 core code-named "Piledriver" employs resonant clocking to reduce clock distribution power up to 24% while maintaining the low clock-skew target required by high-performance processors. Fabricated in a 32nm CMOS process, Piledriver represents the first volume production-enabled implementation of resonant clock mesh technology. "We were able to seamlessly integrate the Cyclos IP into our existing clock mesh design process so there was no risk to our development schedule," said Samuel Naffziger, Corporate Fellow at AMD. "Silicon results met our power reduction expectations, we incurred no increase in silicon area, and we were able to use our standard manufacturing process, so the investment and risk in adopting resonant clock mesh technology was well worth it as all of our customers are clamoring for more energy efficient processor designs."
Read more here: http://www.sunherald.com/2012/02/20/...#storylink=cpy
U. :)
Mitja358 ::
Bi lahko kdo ki se bolj razume, tole nekoliko razložil? Hvala.
Po hitrem pregledu bo poudarek na manjši porabi.
PrimozR ::
Še najbolj bi pomagal delujoč link :P
Brane2 ::
V bistvu gre za to, o čemer smo se že dolgo nazaj pogovarjali, mislim da je to Thomas enkrat prnesu kot idejo- resonant computing.
No, ne v polnem pomenu ampak v začetni obliki. Namesto da bi se med premetavanjem podatkov energija zgubljala na notranjih upornostih, bi jo skladiščili v tuljavah in kondijih in med computingom pretakali med energijo magnetnega polja v tuljavah in električnega polja v kondijih.
Ideja se je v praksi izkazala za veliko težjo od prvih teorij, sedaj pa jo je nekdo uporabil na taktnem signalu, kjer je problem veliko manjši ( a seveda še vedno daleč od trivialnega, drugače bi to zgruntali že zdavnaj).
Taktni signal je po naravi strogo periodičen in v praksi njegova distribucija po čipu povzroča veliko problemov in požre veliko energije.
Sedaj so mrežo za distribucijo signala spravili v rezonanco in na ta način zmanjšali potrebno energijo v ta namen. To je v osnovi to, seveda pa je celovitost rešitve daleč od te osnove.
Aja, pa pozor:
1- vsi so polni pametnih razlag s katerimi jih futra AMDjev PR, ampak kot sem že reku, hudič je v detajlih.
2. Se spomnite pametnih razlag okrog revolucionarne zasnove BD modulov ? PAmetno bi bilo uporabiti izkušnje od prej in pred vreščanjem o revoluciji počakati na izdelke.
Ampak tako na uč ( če ne lažejo) kaže, da bo zaradi tega novi BD soegal parsto MHz višje takte. Upam,d a gre za osnovno frekvenco ( in ne turbo enega jedra)...
  • spremenil: Brane2 ()
Mitja358 ::
Hvala za pojasnilo.
gnilojabolko ::
Windows še vedno ne zna delati z moduli - kot je vidno na sliki: 4C, 8 threads
Test je bil narejen brez Turbo jajc ' torej frekvenca 3.1GHz
Še ena opazka: pri testu enega jedra v resnici Windows si ne zna interpretirati in "nabiva" na en modul in menjava izbran modul, ki naj bi procesiral. Tako da močno dvomim v Single core rezultat.
Aja se opravičujem za zapoznelo objavo...
klinker ::
Puff...Ph2 X6 ga cisto povozi tu ;((
Pa za mojga i5 750 tudi napise 2 core 4 threads, tako da je verjetno sam program kriv ne pa to da winsi ne znajo delat s cpujem.
  • spremenilo: klinker ()
Bo treba počakati na novo verzijo programa.
Ce thread "skace" po modulu, pomeni, da scheduler ne dela pravilno, tuki program nima veze.
jest10 ::
gnilojabolko je izjavil:
Fuj, sigle core je še moj Athlon 640 hitrejši
gnilojabolko ::
Hmm...glede na to da imamo tu moza z FX8 bi lahko ene par CPU testov zalavfali in primerjali razlicne arhitekture med sabo na enakih frekvencah.
Povej pa se poskuša.
Sori ma scheduler je v jedru OS-a (poglej si v opisih popravkov Microsofta, ki so jih umaknili z updatea in ti piše da Windows ne pozna schedulinga z uporabo BD modulov), to pomeni da programsko Windows ne zna uporabljati vse razpoložljive vire/funkcije procesorja.
"Microsoft Patch KB976932 optimizes the performance of AMD Bulldozer CPUs that are used by Windows 7-based PCs. Currently, the performance of AMD Bulldozer CPUs is slower than expected. This behavior occurs because the threading logic in Win 7 is not optimized to use the SMT scheduling feature. This feature was introduced in the Bulldozer family of AMD CPUs"
filip007 ::
Zero games, zero talk.
Lepo lepo. Na papirju zgleda dobro.
Machiavelli ::
Baje se ivy navije do 4.6Ghz at only 1.1V and 5Ghz at 1.17V kar je res malo voltaže lol
Nigaaazz
Link?
eieieie1 ::
Machiavelli je izjavil:
Meh, ne verjamem...
klinker ::
@X45 - MULTICORE
 Ph2 X6 3,3Ghz - 6,00pts
 FX 8120 3,1Ghz - 5,12pts
Mitja358 ::
As for the aforementioned price cuts on the FX-8120 and FX-6100 chips, they've taken a small dive from $205 to $185 and $155 to $145, respectively.
Read more: http://vr-zone.com/articles/amd-now-rol...
Fajn.
x45 ::
  • spremenilo: x45 ()
filip007 ::
Žal ne znam Nemžko...
Eden je na Youtube menjal FX 4100 nazaj na Phenom II X4, ker je bil enako hiter kot FX-4100 navit na 4GHz pa še nekaj. Samo on je imel FX-5200 OEM odklenjen na 4X, je rekel pač bolj ugodno.
Če CPU podpiram SMT, to meni nič ne pomeni če software nima pojma, kaj s tem.
x45 ::
BALAST ::
Stvar bi bila zanimiva za 120€, za 170€ pa naj kar lepo stoji na polici.
"You may fool all the people some of the time;
you can even fool some of the people all the time;
but you can't fool all of the people all the time."
fireX88 ::
x45 je izjavil:
super ugodno:
http://www.mylemon.at/artikel,nr,387151...
za taksno ceno bi bil dober nakup FX-8150.... Buldoti se bi tudi dobro prodajali ce bi bla zacetna cena "najboljsega" proca taksna kot je trenitna FX-8120! No vsaj mislim tako...
Najbolje je, da jih kar zastonj dajejo. A neb blo to super?
filip007 ::
Mah ajde kupim FX-8140 95W čez tri leta, ko bo vreden 35€ in ko bo software podpiral SMT.
x45 ::
x45 je izjavil:
super ugodno:
akor koli že tole prekosi intele v razmerju P/P povsod.
jest10 ::
x45 je izjavil:
x45 je izjavil:
super ugodno:
Ne, tole se samo približa Intelom. Kaki buldožer neki... X6, če že hočeš AMD
x45 je izjavil:
x45 je izjavil:
super ugodno:
Zakaj si ga potem ne lastiš?
Jaz imam X6 1090, pa ga ne bi zamenjal za tega ...
Brane2 ::
Po moje bi znala biti Vishera pravi trenutek za zamenjavo.
Domnevam, da AMD tiho dela na zadevi in da omenja stvar samo toliko kot mora, da se periodično pojavi v medijih.
Če bo novi Bulldo delal res na 4+GHz na vseh cilindrih in če bodo uštimali teh par snagov, potem zna postati za lastnike recimo prastare 955BE res dober korak naprej. Tudi poraba gre dol, kot vidim.
x45 ::
ja tule je poisano tole in pa izboljšave v slikici napram BD1:
http://www.techpowerup.com/159062/AMD-V...
floating point bo 16 biten, do sedaj 8 biten ? če dodamo višji clock in dva jedra zraven bo to vsaj 25 % gain.
Bomo videli. OK?
x45 ::
ja bomo videli, nekaj pa smo že in tole je super:
x45 ::
Če delam osnovno matematiko:
izboljšave ( iz slik zgoraj ) bodo dale 10% ( fpu mogoče še več ), quad ch 5%, in pa en modul zraven 25 % v multi core testih, višji clock pa 10 %.
če to vse zmnožiš dobiš 58,8% gain....
Če bo pol tega bo že super zadeva. prihaja pa v Q3 šele.
Kewl. :)
Ce bo v realnosti 15%, bo ze kar uredu.
BALAST ::
Bolje da so to realni posnetki, ker enkodiranje videa in igranje Dirt3 brez zatikanja mi deluje za lase privlečeno.
x45 je izjavil:
25% si potegnil iz riti? Smo že videli, kakšnaj e tvoja matematika (in neznanje), kar se tega tiče, zato bi prosili za vir, kje si dobil 25%.
x45 je izjavil:
Aha, kar množi se tole po novem ... v kateri jami ti živiš?
Loocas ::
ne po novem, kar po starem...
Isotropic ::
FP enota je ze zdaj 128bit, tko da check your sources
pa a ne bo tale vishera server procesor, s temu primerno ceno?
Spock83 ::
Za smešen denar dobim Opteron Barcelono 2358 in 2356. Je to kaj vredno?
Loocas ::
tolk je vredno, kakršna je cena.
Spock83 ::
Kaj misliš je 2x 23xx CPU in Supermicro H8DME-2 je vredno med 100 in 150EUR? Z 12 jedri bi znal biti odziven serverček.
Jup. Bi kar soliden serverček.
AMD goljufa in to že dolgo:
http://www.fudzilla.com/processors/item...
Nov nakup AMDja.
Ampak, tole je pa zelo smiseln nakup, čeprav firma (za zdaj) uporablja le Intel čipe.
http://www.dailytech.com/AMDs+Acquires+...
http://semiaccurate.com/2012/03/01/why-...
Čudno se mi zdi, da novica ni omembe vredna (na prvi strani). Vem, lahko bi jo spisal sam ... a sem po neuspelem poskusu, nekoč v preteklosti, opustil to idejo.
x45 ::
amd se bo podal v serverke vode tam bo mal več profita.
Še en test v igrah ( Za manj dobiš več - da to je AMD :)):
http://www.hardwareheaven.com/reviews/1...
75 / 128
