Java - problem povezave na FTP
igor0203 ::
Imam problem s povezavo na FTP server in sicer javi mi:
java.net.UnknownHostException: ftp://prenos.ajpes.si/rtr/
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:177)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:366)
at java.net.Socket.connect(Socket.java:529)
at org.apache.commons.net.SocketClient.connect(SocketClient.java:176)
at org.apache.commons.net.SocketClient.connect(SocketClient.java:268)
Rad bi se povezal na Ajpesov ftp in dol potegnil RAR datoteke. Z neta sem potegnil čisto osnovni FTP program za povezavo na FTP s pomočjo apache.commons.
Spodaj prilagam še izvorno kodo:
package javaapplication2;
import java.io.IOException;
import org.apache.commons.net.ftp.FTPClient;
import org.apache.commons.net.ftp.FTPFile;
public class DLFile {
  public static void saveZIP() throws Exception {
        FTPClient client = new FTPClient();
        try {
            client.connect("ftp://prenos.ajpes.si/rtr/");
            client.login("rtrjavni","javnidostop");
            String[] names = client.listNames();
            for (String name : names) {
                System.out.println("Name = " + name);
            FTPFile[] ftpFiles = client.listFiles();
                for (FTPFile ftpFile : ftpFiles) {
                    // Check if FTPFile is a regular file
                    if (ftpFile.getType() == FTPFile.FILE_TYPE) {
                        System.out.println("FTPFile: " + ftpFile.getName());
            client.logout();
        } catch (IOException e) {
            e.printStackTrace();
        } finally {
            try {
                client.disconnect();
kihc ::
Poskusi brez ftp://
x
igor0203 ::
Nope, ne dela.
keworkian ::
Kaj pa če bi probal z ip-jem? Napako ti javi zato ker ne prepozna host-a, verjetno ne more resolvat.
Obscenities in B-Flat
igor0203 ::
Evo sprobal z IP-jem in se je očitno povezal, vendar mi ne izpiše vsebine?
keworkian ::
Zato ker si se ti povezal na ftp://193.77.110.99/ moral bi se pa na ftp://193.77.110.99/rtr/
igor0203 ::
Maš prav, bom probal v ponedeljek. Hvala!
igor0203 ::
Živjo!
Popravil sem kodo in dodal tisti /rtr/ na konec IP-ja in mi ponovno izpiše napako:
Exception in thread "main" java.net.UnknownHostException: ftp://193.77.110.99/rtr/
Spajky ::
Kaj pa up.ime in geslo; ne pusti anonimus prijave ...
igor0203 ::
ftp://rtrjavni:javnidostop@prenos.ajpes.si/rtr/
Se pravi, user je rtrjavni, pass pa javnidostop? To pa vpisujem z client.login("rtrjavni","javnidostop"); ?
igor0203 ::
A evo je ratalo. Zadevo sem rešil tako, da sem vpisal samo IP naslov in se potem z changeWorkingDirectory premaknil v /rtr/.
Hvala!
  • spremenil: igor0203 ()
Web services - Neveljavni karakterji v XML
Oddelek: Programiranje
316325 (5437) boolsheat
[JAVA] HTTPS client
173692 (2422) peterv6i
java datapool - derby
62937 (2786) jlpktnst
tomcat in datasource
132679 (2436) infiniteLoop
Kako pošiljanje datotek v JAVI.
142243 (2114) kopernik
