Forum » Programiranje » Java - problem povezave na FTP
igor0203 ::
Imam problem s povezavo na FTP server in sicer javi mi:
Rad bi se povezal na Ajpesov ftp in dol potegnil RAR datoteke. Z neta sem potegnil čisto osnovni FTP program za povezavo na FTP s pomočjo apache.commons.
Spodaj prilagam še izvorno kodo:
java.net.UnknownHostException: ftp://prenos.ajpes.si/rtr/
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:177)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:366)
at java.net.Socket.connect(Socket.java:529)
at org.apache.commons.net.SocketClient.connect(SocketClient.java:176)
at org.apache.commons.net.SocketClient.connect(SocketClient.java:268)
package javaapplication2;
import java.io.IOException;
import org.apache.commons.net.ftp.FTPClient;
import org.apache.commons.net.ftp.FTPFile;
public class DLFile {
public static void saveZIP() throws Exception {
FTPClient client = new FTPClient();
try {
client.connect("ftp://prenos.ajpes.si/rtr/");
client.login("rtrjavni","javnidostop");
String[] names = client.listNames();
for (String name : names) {
System.out.println("Name = " + name);
FTPFile[] ftpFiles = client.listFiles();
for (FTPFile ftpFile : ftpFiles) {
// Check if FTPFile is a regular file
if (ftpFile.getType() == FTPFile.FILE_TYPE) {
System.out.println("FTPFile: " + ftpFile.getName());
client.logout();
} catch (IOException e) {
e.printStackTrace();
} finally {
try {
client.disconnect();
keworkian ::
Kaj pa če bi probal z ip-jem? Napako ti javi zato ker ne prepozna host-a, verjetno ne more resolvat.
Obscenities in B-Flat
keworkian ::
Zato ker si se ti povezal na ftp://193.77.110.99/ moral bi se pa na ftp://193.77.110.99/rtr/
- spremenil: keworkian ()
igor0203 ::
Živjo!
Popravil sem kodo in dodal tisti /rtr/ na konec IP-ja in mi ponovno izpiše napako:
Exception in thread "main" java.net.UnknownHostException: ftp://193.77.110.99/rtr/
Spajky ::
Kaj pa up.ime in geslo; ne pusti anonimus prijave ...
igor0203 ::
ftp://rtrjavni:javnidostop@prenos.ajpes.si/rtr/
Se pravi, user je rtrjavni, pass pa javnidostop? To pa vpisujem z client.login("rtrjavni","javnidostop"); ?
igor0203 ::
A evo je ratalo. Zadevo sem rešil tako, da sem vpisal samo IP naslov in se potem z changeWorkingDirectory premaknil v /rtr/.
Hvala!
Hvala!
- spremenil: igor0203 ()
| » | Web services - Neveljavni karakterji v XMLOddelek: Programiranje | 6325 (5437) | boolsheat |
| » | [JAVA] HTTPS clientOddelek: Programiranje | 3692 (2422) | peterv6i |
| » | java datapool - derbyOddelek: Programiranje | 2937 (2786) | jlpktnst |
| » | tomcat in datasourceOddelek: Programiranje | 2679 (2436) | infiniteLoop |
| » | Kako pošiljanje datotek v JAVI.Oddelek: Programiranje | 2243 (2114) | kopernik |
