Forum » Problemi človeštva » Slovenska levica
Slovenska levica
djordjevic ::
Mar te v Ameriki nočejo? Tako brezkompromisno izpričanega demokrata, kakršen si? Skorajda ne verjamem.
Karaya 52 ::
Kje so tega Hanzka pobrali? Najavi novo stranko, drugi dan ze vodi gostilnisko debato na oddaji Odkrito... Po treh stavkih je bilo jasno, da se mu ne zdi s trenutno politiko vlade nic narobe, da so krivi mediji in opozicija. Trajnostni razvoj, trajnostni nateg, pri Hanzku pa zlasti Dunning-Krugerjev effect.
Hanzek: gospodarstvo lahko resimo z vecjim zapravljanjem drzave. Imamo 20.000 ostarelih, zgradimo domove za ostarele in tam zaposlimo 10.000 ljudi.
Bravo! Res, clap clap, zdaj je uradno - v politiko lahko vstopijo najvecji analfabeti.
- spremenil: Karaya 52 ()
Double_J ::
http://www.pozareport.si/?Id=necenzurir...
Mali škratek je tako zaposlen zadnji čas, da je pooblastil kar ženo.
Dve šivanki...
- spremenil: Double_J ()
USS Liberty ::
Manca-->>Gabi-->>Štefka-->>Milan
Vse poti pri nas vodijo v Murgle
http://en.wikipedia.org/wiki/USS_Liberty_%28AGTR-5%29
V resnici me zanima, kdaj se bo v Sloveniji formirala desna stranka, ki se bo distancirala od popolnih bebcev, ki trenutno tvorijo jedro desnice s povsem komunistično agendo.
poweroff ::
Vendar pa:
After the invasion of Iran by Iraq, the United States increased sanctions against Iran. In 1984, sanctions were approved that prohibit weapons sales and all U.S. assistance to Iran. The United States also opposed all loans to Iran from international financial institutions. In 1987, the United States further prohibited the importation and exportation of any goods or services from Iran.
The term of President Rafsanjani was marked by some of the toughest sanctions against Iran. In April 1995, President Bill Clinton issued a total embargo on U.S. dealings with Iran, prohibiting all commercial and financial transactions with Iran.
https://secure.wikimedia.org/wikipedia/...
sudo poweroff
- zavarovalo slike: poweroff ()
USS Liberty ::
Matthai... Če imajo ameriški in izraelski cionisti stalne probleme z Iranom, jih mi nimamo... To kar je Slovenija prodala Iranu je v bistvu drobiž v primerjavi z drugimi državami...
Sicer je pa tale Matthaijev post čisto trolanje in poskus, da bi se še v temi o slovenski levici začeli kragati okorog Janše...
Matako ::
Jure, dokler ne boš ti vzel stvari v svoje polihistorične roke, ne bo nič.
/\/\.K.
Karaya 52 ::
Italijanska finančna skupina KB 1909 iz Gorice, za katero naj bi stal denar zamejskih Slovencev, je prek dveh podjetij Distrieste (ima v lasti 57,3 odstotka Mladine) in Transmedie (ima v lasti 3,3 odstotka Mladine) vstopila v lastništvo tednika Mladina, piše portal pozareport.si. Drugi največji lastnik KB 1909 pa naj bi bila kar druga največja slovenska banka NLB , kar je sicer znano že od oktobra 2007, ki po naših izračunih potrebuje kar 450 milijonsko finančno injekcijo.
Izbrskamo kaksno stalisce ima Mladina do odprodaje drzavnega mecena aka drzavne srebrnine aka nacionalnega interesa?
Ma dej no, Mladina je pa najbolj verodostojen medij, takoj za DELO-m, tem pa sledi 24kur in njenimi derivati.
imagodei ::
A to je tvoj argument? Najprej se sklicuješ na Mladino prav TI (mind you, nisem se skliceval jaz), ko ti pa pokažem, da [ne znaš brat / zavajaš / lažeš / ustavi ustrezno], se ti pa taisti vir ne zdi več primeren?
Kako to, da se ti je v osnovi zdel tako verodostojen, da si nam z njim mahal pod nosom?
- Hoc est qui sumus -
Malajlo ::
... pa naj bi bila druga največja slovenska banka...
A ni NLB največja, NKBM pa druga? Dej nehi brat pozareport, no, ker ti škodi...
Karaya 52 ::
Na levici se ljudem ze rola. Plut, Kosirjeva, Hanzek in ostali paleokomunisti se prebujajo mislec, da je prisel njihov cas. Celoten Zahod zmanjsuje velikost drzavnega aparat, ti loleki pa zelijo ravno obratno. Hanzek bi drzavo reseval z gradnjo domov za ostarele in vlaganjem v zdravstvo, Plut bi kar cel svet pahnil v zeleno revolucijo, Kosirjeva pa je zgleda za maskoto, cesa pametnega iz njenih ust se nisem slisal. No, tudi ostala sta ji v tem dokaj blizu.
Je pa zanimivo, da ima ta nova stranka, ki ima v imenu besedo tranjnostni, najbolj nazadnjaski aka komunisticni gospodarski program. Ti intelektualci podjetnistvo se vedno dojemajo kot nepotrebno in druzbeno skodljivo. Raje govoricijo o socialni kohezivnosti, novi paradigmi (zelen marksizem, res novo) ter njihovem vrednostnem sistemu, katerega moramo vsi hitro posvojiti.
Zakaj jih konkretno ne vprasajo, kaj bi naredili z banko, ki potrebuje pol milijarde tezko injekcijo? Hin ljudje, hin drzava.
PaX_MaN ::
Tut če bi prišli, ne bi mogli nič. NLB ma zdej čez AUKN, katere člane izvoli - državni zbor.
Matako ::
Manca in prijatelji so vzeli ime enim navdušencem na EF:
http://www.ef.unilj.si/trajnostni_razvo...
Jaz bi na njihovem mestu težil. Je pa "trajnostni" v političnem smislu lamerski izraz. Saj od klovnov Mančinega tipa kaj več itak ne moreš pričakovati.
/\/\.K.
- spremenil: Matako ()
Karaya 52> Celoten Zahod zmanjsuje velikost drzavnega aparat, ti loleki pa zelijo ravno obratno.
Danci so ravnokar izvolili "ravno obratno".
Matheeew ::
http://www.ef.uni-lj.si/trajnostni_razv...
Kr_Edn ::
" jype :: 14. sep 2011, 20:51:28
V resnici me zanima, kdaj se bo v Sloveniji formirala desna stranka, ki se bo distancirala od popolnih bebcev, ki trenutno tvorijo jedro desnice s povsem komunistično agendo."
Pa ti poizkusi.
Pa ti poizkusi.
Double_J ::
http://www.siol.net/svet/novice/2011/09...
To je torej naše "gospodarsko" sodelovanje, za katerega se je Pahor tako zavzemal...
Dve šivanki...
Double_J ::
Ameriški veleposlanik oster do Slovenije
http://24ur.com/novice/gospodarstvo/ame...
To je pa že zelo podobno ameriškem stališču do Sirije, ki še kar mrcvari ljudi. Saj to sploh ni čudno, Assad in njegova socialistična stranka Baath je ubistvu ideološki dvojček naših socialistov.
Dve šivanki...
To je torej naše "gospodarsko" sodelovanje, za katerega se je Pahor tako zavzemal..Tistega, kar linkaš, bodisi ne prebereš ali ne razumeš.
Libijski nacionalni prehodni svet podjetju obljublja odškodnino v višini do treh milijonov evrov, direktor podjetja Jože Gričnik pa že načrtuje nadaljevanje pred vojno začrtanih projektov. Projekt, ki ga je načrtoval z italijanskim partnerji, je vreden osem milijonov evrov.
O.
Kr_Edn> Pa ti poizkusi.
Nisem primeren kandidat, ker imam vedno prav, pa tudi sicer se veliko bolje odrežem pri bolj tehničnih opravilih kot je politika.
Matako ::
Pošteno! Te bomo prihranili za kako tehnično vlado, če bo kdaj treba. ;)
/\/\.K.
Limit-sky ::
Mislim, da bi tudi v trenutni vladi dobro sodeloval z njo. Sploh s Pahorjem. Tudi on misli, da ima vedno prav in se bolje spozna na tehnične stvari, kot pa politiko.
Prišlo je do nesporazuma. Nekateri, kot pravilno poudarjaš, mislijo, da imajo vedno prav. V mojem primeru ne gre za nič takšnega.
nevone ::
Za pravo (ekonomsko, ne ideološko) desnico pri nas še ni dozorel čas. Bi pa vseeno bilo lepo, če bi se pravi ekonomski desničarji pojavili kot politična stranka, če zaradi drugega ne, že zato, da se vsaj malo razširi glas o takšni opciji. Ni treba, da na volitvah zmagajo, dovolj bi že bilo, če bi jasno oblikovali stališča in jih javno predstavljali ljudem.
Razni Erjavci bodo seveda zavijali z očmi, levičarji bodo razlagali o fašizmu, ampak to jih po moje ne bi smelo ustaviti.
Njihova retorika bi morala bolj temeljiti na povdarjanju pozitivnih učinkov desne ekonomije na celotno družbo, kot kazanje s prstom na nasprotni tabor in kritika le-tega.
Slovenija ima ogromen potencial v ljudeh, le izkoristiti ga ne zna ali se ga celo boji.
Vztrajanje na tem, da je važno samo to, da smo vsi enako revni in nikakor nihče bolj bogat, nas bo potiskalo v še večjo revščino.
Seveda pa brez podpore državnih inštitucij, ki bi dejansko bile v službi vseh ljudi tudi ne bo šlo.
Dejansko bi počasi lahko postali urejena dežela.
o+ nevone
o+ nevone
nevone> Dejansko bi počasi lahko postali urejena dežela.
Urejene dežele so tudi levo usmerjene demokracije. So konkurenčnejše tako od nas kot od vzhodnoevropskih držav, v katerih so desničarsko ekonomijo dejansko preizkusili.
Jaz premika v desno sploh ne vidim kot nujno potrebnega za drastično liberalizacijo ekonomije.
Limit-sky ::
Matako ::
Saj o tem govorimo. Te države so kar lepo "desne" ekonomsko gledano, enkrat ko odšteješ pomoč domačim cunjeglavcem - cena, ki se jo plača. Vsekakor bistveno bolj, kot Slovenija.
/\/\.K.
Če misliš, da so tržno gospodarstvo ali liberalna ekonomska politika domena desnice, se motiš.
Leve (socialistične) vlade, ki so pravilno odreagirale na finančno in gospodarsko krizo zadnjih nekaj let, v evropi niso redke.
nevone ::
Evropa bo za stabilnost Evra poskrbela le tako, da bo članicam z preveliko javno porabo dalo resno vedeti, da se v imenu solidarnosti ne bodo mogli večno šlepat.
Jasno, potem gredo v luft sindikati in grozijo z "vojno".
Bomo videli, kam bomo potegnili in vlekli ta voz.
Standard še ni tako nizek, da bi se splačala vojna, a če ne bomo pravočasno rekli bobu bob se tudi to lahko zgodi.
Morda ne ravno vojna, splošen nered pa ni izključen.
Če v resnici nimamo bojše ideje, kako bi ukrepali, potem je seveda "vojna" najboljša "rešitev".
o+ nevone
o+ nevone
Karaya 52 ::
Poglejmo zadnje dogodke v Sloveniji. Namesto da bi ljudje tipa nevone ustanavljali stranke, smo prica nasprotnemu. Se vec drzave v gospodarstvu (Krizanicev sklad), se vec laznive solidarnosti in pokvarjene nedelujoce socialne drzave. Predpostavimo, da ima clovek razciscene pojme o osnovah trznega kapitalizma in da poveze 1 plus 1. Zakljucek je zelena karta za ZDA. Delam intenzivno na tem.
hamax ::
Super ideja, njihovi politiki so namrec tako sposobni, da poskusajo resiti primankljaj(in suso) kar z molitvijo.
Sploh ne vidim kako bi se to lahko ponesrecilo.
Karaya 52 ::
Bolje kot vihtenje rdecih zastav in srpov. To dokazano vodi v enakost, revscino in vsesplosno bedo. Sicer pa takole, vsakemu svoje. Amen.
djordjevic ::
Pa ti res misliš, da ni čedalje več ljudi, ki bi Semoliča in podobne najraje nabili na kak kol? In da bi mogoče prišli prav ljudje z idejami, kako spraviti voz iz te gnojne septične jame? Ljudje, ki bi celo kaj naredili, ne pa samo gobcali in opletali s krilaticami? Ne, 'odnesimo pete'. Domoljubi.
hamax ::
Mi lahko pokazes enega slovenskega politika, ki to pocne?
Al se gres slucajno tisto amerisko igrco: vse kar mi ni vsec je komunisticno!
nevone ::
Meni se pa zdi, da ekonomsko desno je več svobode in več trga, levo pa več regulacije in državnega korporativizma.
Zato je premik v desno nujen, razen če imamo različno razlago pojmov kaj je levo in desno usmerjena ekonomija.
Je pa res da sta si ideološka in ekonomska svoboda pri levih in desnih ravno nasprotujoča in potem imamo tudi ljudi, ki so mešanica levega in desnega v smislu ekonomije in ideologije hkrati.
o+ nevone
Zakljucek je zelena karta za ZDA. Delam intenzivno na tem.Prijavi se v njihovo vojsko. Najhitrejša pot do zelene karte in državljanstva.
in potem imamo tudi ljudi, ki so mešanica levega in desnega v smislu ekonomije in ideologije hkrati.In kaj je narobe s tem, da se zavzemaš za svobodno podjetništvo in pravico gejev, da posvojijo otroka?
O.
- spremenil: Okapi ()
nevone ::
Nič ni narobe, in nič takega tudi nisem trdila, da je s tem kaj narobe.
Samo opažam, da predalčkati ljudi levo in desno ni tako enostavno, ker oboji zagovarjajo neko svobodo in oboji jo na nekem področju želijo krčiti.
o+ nevone
- spremenila: nevone ()
Ja, zato sem pa trdil, da ne vidim potrebe po premikanju desno (kar je premikanje proti konzervativnejši ureditvi), bolje navzgor (proti liberalnejši).
- spremenilo: jype ()
ker oboji zagovarjajo neko svobodo in oboji jo na nekem področju želijo krčiti.V resnici eni zagovarjajo čim več dobrin in so pripravljeni za to žrtvovati nekaj svobode, drugi pa zagovarjamo čim več svobode in smo za to pripravljeni žrtvovati nekaj dobrin.
O.
thramos ::
Površno rečeno, ja.
Nekateri verjamemo, da več dobrin vodi k ekonomski blaginji, ki s sabo prinese več strpnosti in svobode.
Jinto ::
O.
A se šališ? Od koga dobrine bi ti žrtvoval za svobodo?
Že s tem kršiš ravno tisto za kar naj bi se zavzemal.
