Forum » Programiranje » C# OleDB create database
DubleG ::
Rad bi najprej preveril če baza obstaja in če ne obstaja, bi jo rad ustvaril. Torej:
Obstaja kakšna rešitev za katero jaz ne vem?
Naprimer da je connStr="Provider=SQLOLEDB.1;Integrated Security=SSPI;Persist Security Info=False;Initial Catalog=BLA;Data Source=LOCAL-PC;"
OleDbConnection OleCon = new OleDbConnection();
OleCon.ConnectionString = connStr;
try
OleCon.Open();
goto Nadaljuj;
catch
finally{
//Initial Catalog does not exist
//create it
string con = "Integrated Security=" + session.CustomActionData["Integrated Security"].ToString() + ";" + "Initial Catalog=;" + "Data Source=" + session.CustomActionData["Data Source"].ToString() + ";";
OleDbConnection OleCon2 = new OleDbConnection();
OleCon2 = new OleDbConnection(con);//tukaj brejkne
string datasource = session.CustomActionData["Data Source"].ToString();
string cad2 = session.CustomActionData["SetTargetPath"].ToString();
string sql = "CREATE DATABASE "+datasource+ " ON PRIMARY"
+ "(Name=" + datasource + ", filename = '" + cad2 + "DB Database\\" + datasource + ".mdf', size=3,"
+ "maxsize=5, filegrowth=10%)log on"
+ "(name=mydbb_log, filename='" + cad2 + "DB Database\\" + datasource + ".ldf',size=3,"
+ "maxsize=20,filegrowth=1)";
ExecuteSQLStmt(sql, con);
Nadaljuj:
OleCon.Close();
GA-P55M-UD2,i5,12GB RAM,Radeon HD 4850,Crucial SSD 64GB,
WD 320GB,WD 5000GB,RevoDrive X2 100GB
BHawk ::
Prvo finally block v try->catch->finally se bo vedno izvedel.
Kar moraš ti narediti je, da v catch uloviš napako, ter pogledaš zakaj se ne moreš konektati na bazo. Če je razlog, da initial catalog ni pravilen izvedeš sql ukaz za kreiranje nove baze.
DubleG ::
To sem v teoriji tudi sam želel, pa ne vem kako...
tomaz_sres ::
Živijo,
s tem selectom preveri, če baza obstaja:
select db_id('ImeBaze')
Lep pozdrav, Tomaž Sreš, http://www.sres.si
nuclear ::
v finnaly-u zapri bazo.. v tryu odpri in delaj, v catchu expection meči(pač napako), v finnaly pa zaključi.. nekaj v smislu:
using (SqlConnection povezava = new SqlConnection(Convert.ToString(Session["cs"])))
try
povezava.Open();
string querya = "query";
SqlCommand cmd = new SqlCommand(querya, povezava);
SqlDataReader dr = cmd.ExecuteReader();
if (dr.Read())
email = dr["Vrednost"].ToString();
dr.Close();
catch (Exception ex)
Response.Write(ex.Message);
finally
povezava.Close();
povezava.Dispose();
} Asus G14 2023 - Ryzen 7940HS - 32GB DDR5 - GeForce RTX 4080 - 990 PRO 4TB
3p ::
DubleG ::
Kako se v objektu
connection = (ADODB._Connection)dataLinks.PromptNew();
določi privzeto izbran Provider?
DubleG ::
že imam,
connection = new ADODB.ConnectionClass();
connection.ConnectionString = connStr;
//set local COM compatible data type
object oConnection = connection;
s tem da je connStr string v katerem je Provider=SQLOLEDB.1
| » | C# težavaOddelek: Programiranje | 4951 (3797) | mladec |
| » | SQL problemOddelek: Programiranje | 2147 (1765) | win64 |
| » | razložitev nekaterij elementov v visual studio 05Oddelek: Programiranje | 2607 (2412) | darkolord |
| » | OleDb in visual studio .netOddelek: Programiranje | 2680 (2459) | Kovalchuk |
| » | branje byte[] iz MS access-ove bazeOddelek: Programiranje | 2335 (2245) | BHawk |
