Forum » Loža » Katero kvalitetno ročno svetilko kupiti?
![](https://static.slo-tech.com/stili/bel_non_grata.png)
49106 ::
Nova Astroluxka
https://www.banggood.com/Astrolux-EC01X...
Astrolux EC01X SBT90.2 6800LM 3060m Flashlight Released !
Come with one removable 32000mAh 46950 Battery
Coupon Code:BGEC01X
Features:
1. The SBT90.2 LED core ensures a lifespan of up to 100,000 hours, providing consistent brightness without any flickering.
2. 6800LM Max Output with 2350000CD high intensity, wide illumination range, also ultra-wide field of view
3. 3065m Max Range with its powerful and focused beam, this flashlight enables easy navigation in dark environments and emergency signaling. The long-range capability ensures clear surroundings, enhancing safety during outdoor activities or professional use.
4. Stepless Dimming Design
5. Type-C Two-Way Quick Charge. Uses TYPE-C charging interface for fast charging, supports various charging methods, and can be charged anywhere.
6. Power indicator: Charging is Red Light and Full: Blue Light
7. Uses a removable 46950 Li-Ion battery with up to 32000mAH capacity. The moonlight mode can work for 26 days to escort your night adventure.
8. Lock-out design
9. Intelligent temperature control:
- Multiple heat dissipation, no heat when held for a long time.
- Using the step-down constant current drive method, when the temperature is higher than 52 degrees, it starts to decrease slowly at a rate of 2% per second, and the temperature is controlled at 55 degrees.
cene pa ne poglejte
Odkar si jo omenil, tuhtam, da bi naročil, ampak ne morem mimo tega, da se niti pri predstavitvenemu modelu niso potrudili. Zelena, vsaj na slikah z manj svetlobe, deluje zelo všečno (za zeleno svetilko :)).
Ima mogoče kdo informacijo o tem, ali bo Armytek izdal 21700 verziji Predatorja ali Vikinga?
49106 ::
Načeloma imajo vsa pri nas kupljena sončna očala ustrezno UV zaščito, ki ustavi zgoraj omenjene 365nm UV žarke. Tudi prozorna zaščitna očala (ne pa seveda običajna korekcijska očala za boljši vid).
Pomembno je, da imajo vaša očala zaščitni faktor UV 400, ker sončna svetloba iz fizikalnega vidika na območju valovne širine od 280 do 400 nm ni vidna, je pa škodljiva. Kakovostna sončna očala ustavijo vse UV žarke kratkovalovnega področja do cca 400 nm. Sončna očala, ki ponujajo to varnost, nosijo nalepko z oznako UV 400.
Vir: https://www.informacija.net/vseved/zdra...
Za zaščito uporabnikov so države sprejele standarde, ki so potrebni za zaščito oči pred UV- žarki. V Evropi je to certifikat CE, ki zagotavlja, da nudijo očala varno stopnjo zaščite. Evropski standard določa, da lahko očala, ki so na trgu, prepuščajo največ 5 odstotkov UV-žarkov valovne dolžine do 400 nanometrov (nm), torej UVA in UVB, avstralski standard je še strožji: očala morajo zadržati vsaj 99 odstotkov žarkov UVA in UVB. UV-žarki imajo valovno dolžino do 400 nm, zato imajo kvalitetna sončna očala oznako UV 400, kar pomeni, da preprečujejo prehod žarkov do te valovne dolžine. To lahko označuje tudi nalepka, ki je na steklih sončnih očal. Ni pa nujno, da je le ta verodostojna.
Vir: https://beautyfullblog.si/poceni-soncna...
Pri Sofirn SF16 (SST-08-UV) sem opazil opozorilo, da škoduje tudi koži (wear proper eye and skin protection). Ugibam, da ni sile, če svetim pred seboj in je ne usmerjam proti koži, sicer bi bilo potrebno zaščiti tudi obraz in ne samo oči?
![](https://static.slo-tech.com/stili/avatar_gray.gif)
gregor ::
Verjetno zato ker se lučka močno segreje. Imam veliko lučk, ki postanejo zelo vroče. V bistvu vse male lučke z malo mase...
Zmanjšaš svetilnost in temperatura pade...
Lahko pa gledaš na to tudi pozitivno.
Če se izgubiš v gozdu, lahko zakuriš suho listje... in se ogreješ.![:))](https://static.slo-tech.com/smeski/icon_lol.gif)
Matko ::
Preden prečekiram celotno temo. Katero naglavno svetilko?
HD15 ?
H25S ?
kakšno tretjo?
wasserdiht,
trpežna,
obvezno na 18650,
CRI 90
HD15 ?
H25S ?
kakšno tretjo?
wasserdiht,
trpežna,
obvezno na 18650,
CRI 90
matobeli ::
Mrbit kakšna ki je v resnic 90 stopinj ročna luča z naglavnim trakom ali bi raje ime dedicated naglavno?
Pa ne pozabit da je tudi 18650 kar težka in topla za na čelo.
Za sprehod, tek, kolesarstvo...?
gregor ::
Morda tukaj pogledaš teste, kar precej izbire...
https://zeroair.org/category/flashlight...
Skilhunt je kar močan na področju čelk...
MTB4life ::
Dokler je namerno je super. Meni je ST01 prežgala nahrbtnik
![:O](https://static.slo-tech.com/smeski/icon_surprised.gif)
Sicer še nisem razmišljal o odpravi problema, ker leži nekje v kotu brez baterije od takrat dalje - kazensko ker je bila poredna - hec
![;((](https://static.slo-tech.com/smeski/icon_mad.gif)
kumer ::
koyotee ::
A nima 4?
Rear DVD collector!
JTD power!
JTD power!
Ales ::
Če komu kaj pomaga izkušnja z dostavo: danes je prišel paket z Acebeam E75. Dostava je torej trajala od 6.10. do 18.10, 12 dni.
Njihova dostavna služba je bila YunExpress, priletelo je do Budimpešte, potem pa naprej v Slovenijo, tu je dostavil DPD. Brez kakega carinskega postopka pri nas ali kakršnih koli dodatnih stroškov, vse so zrihtali že špediterji vmes, vključeno v ceni.
No, paket je prišel, a mene ni tam, tako da je vsebina paketa domnevno Acebeam E75... ali pa majhna rabljena opeka. Še sporočim.
![:D](https://static.slo-tech.com/smeski/icon_biggrin.gif)
gregor ::
lubej1 ::
kakšna je že bila cena, sem pozabil?
kakšna je prednost te lučke v primerjavi z budget variantami, boljša kvaliteta izdelave, boljši driver (boost)?
še kaj?
še kaj?
49106 ::
75 usd (s kuponom) :)
Kaj je trenutno bestbuy med taktičnimi "thrower" svetilkami srednjega razreda (80-120 USD)? Trenutno gledam Klarus X12GT in Armytek Doberman Pro. Prve nisem našel po normmalni ceni, slednjo sem skorajda kupil v izvedbi s kovčkov, ampak sem se nekako zadržal, ker tistega kufra "ne potrebujem".
A je to dobra cena za Astrolux WP3? Ali se za to podobno ceno najde kaj boljšega?
https://www.banggood.com/Astrolux-WP3-2...
Predvidevam, da je zoom uporaben pri LEP (wp3 nima zooma) in se splača zapraviti nekaj več?
- spremenilo: 49106 ()
Ales ::
Okoli 75 USD, ja. Ujel sem 25% popust na lučko oz. na cel nakup, redna cena je pa 99,90 USD.
O tem kaka je dejansko lučka bom lahko kaj napisal čez par dni. Do takrat bi lahko le ponavljal kaj, kar so navedli v testih...
Tsunamii ::
kLARUS x12gt
https://www.aliexpress.com/i/3281835857...
gregor ::
Astrolux WP3
Ta test je bil objavljen v 2021:
https://1lumen.com/review/astrolux-wp3/
Verjetno se dobi kaj boljšega, če že hočeš imeti LEP lučko. Moraš pa vedeti, da imajo LEP lučke zelo ozek snop svetlobe.
Koliko je to uporabno, ne vem, ker nisem še imel LEP lučke...?
Veliko testov LEP lučk:
https://1lumen.com/lep-flashlight/
- spremenil: gregor ()
Ni nujno. Fora LEP je, da imajo lahko zelo ozek snop, in proizvajalci običajno to pač izkoristijo. Ker ljudje kupujejo LEP ne zaradi uporabnosti, ampak ker je imenitno videti "svetlobni meč" ozkega snopa. Ampak reflektor je lahko tudi drugačne oblike, za širši snop, oziroma je mogoče svetlobo "zumirati".
Na nekatere LEP s fiksnim ozkim snopom pa lahko daš "razpršilec", za širši snop. Ampak v vsakem primeru pa, ko svetlobo bolj razpršiš, ugotoviš, da so LEP pravzaprv šibke, tam nekje 500 lumnov največ.
Recimo tale ima v osnovi 3 stopinjski snop, zraven pa dobiš še dva razpršilca - 30 in 50 stopinjska. In še dva barvna filtra.
https://www.bigtexordnance.com/product/...
Swappable DIFFUSER windows enable user selected 3°, 30°, or 50° diffused beam “spills” for Up Close Work or Long Spot 1,200 Meter Throws.
- spremenil: Okapi ()
Matko ::
namensko zgolj za na glavo/čelado
za delo in kolo
nekaj precej boljšega od 3xAA ;)
Samael ::
Čelke ... not my thing. Ampak tisti ki pogreša cenejše ultra lahke Nitecore lučke z dodatno rdečo ledico, tole od Klarusa iz Dojčlanda (s poštnino za EUR 5,12) bi znalo biti zanimivo.
KLARUS HM2 na tri AAA baterije EUR 16,36
https://www.ebay.de/itm/225565778643
KLARUS HM1 440LM, vgrajena baterija na usb polnjenje EUR 27,63
https://www.ebay.de/itm/225162987570
Imajo tudi dražje, zmogljivejše modele, ampak tole najbolj osnovno je bilo v času Nitecora za podobno ceno kar popularno.
Samael != Samuel
Samael ::
O, na amazon.de je pa še cenejša (če napolniš košarico do zastonj poštnine).
https://www.amazon.de/dp/B08BFJ37TV? 24,95€ + 15 %-Coupon (če označiš kupon pride €21.74)
Samael != Samuel
Nimam pojma, ali je original, ampak tule je Nitecore NU25 ultralight za 25 evrov.
https://www.aliexpress.com/i/1005004838...
Kot vidim, ta nima rdeče lučke, in je skoraj 2x težja od Nitecore. Ima pa 3x zmogljivejšo baterijo, vsaj na papirju.
twom ::
Samo da vas mal spomnim, naslov teme je Kataro kvalitetno ročno svetilko kupiti... ![8-)](https://static.slo-tech.com/smeski/icon_cool.gif)
Tole k vi kupujete, je nekako v rangu Nerf pištol iz špara...
Vsekakor mi svetilka, ki jo zaradi vročine ne moreš držat v roki, ima pa milijontaužnt luxov deluje zelo profi
Tsunamii ::
Nima ne.. sam iscem naglavno lucko ki imas zadaj rdeco markirno lucko. ČE bo kdo nasel bom vesel.
Tsunamii ::
Je pa tukaj 2x naglavna za ceno 20€ z rdečo lučko če rabis. Ne poznam firme in tudi dvomim da so realni lumni ...
https://www.amazon.de/-/en/Headlamp-Rec...
Samael ::
Vsekakor mi svetilka, ki jo zaradi vročine ne moreš držat v roki, ima pa milijontaužnt luxov deluje zelo profi![]()
V bistvu komentiramo in kupujemo različne svetilke. Strinjam se, da se trend nagiba k več lumnov za ceno, pa da je to pogosto na račun termalne regulacije in da marsikatero svetilko, ki je kupim sam, ne bi svetoval svojim bližnjim, po drugi strani pa te zadeve poznamo dovolj dobro, da najdemo kar najboljše, kar je na trgu za določeno ceno, za vsakega posameznika.
Osebno še vedno največkrat posežem po lučki v 14500/AA formatu (torej recimo 400 lumnov), tu pa tam, odvisno do situacije po lučki v 18650 formatu (optimalno do recimo 800lm, seveda pa marsikatera en kratek čas zmore tudi znatno več) in zelo redkokdaj (čeprav jim imam kar nekaj) po 21700/26650 formatu z več tisoč lumni. Kakor komu ustreza.
Pač hobi, firbcamo, debatiramo, raziskujemo ... Tu pa tam pride kdo v temo ves pameten prcati in ... ostane. Jebeš dostojanstvo, če se pa lahko druži tu z nami. Pazi, da ne postaneš en teh.
Samael != Samuel
49106 ::
Poleti drugega kot 14500 ali 18350 nimaš kam pospravit. Še najraje vidim ploščate (manker F14, ravyvon angel eyes), ampak imajo ponavadi to hibo, da baterije ni moč zamenjati oz dobiti nadomestne.
V tem obdobju pa tudi mini reflektorji (21700) niso moteči
gregor ::
49106 ::
Ta "trend" bi bil problem, če lučke ne bi mogel uporabljati pri manjši jakosti. AFAIK lastnosti takšne "premočne" lučke niso zarati tega nič slabše, ko jo uporabljaš pri polovični moči. V smislu, da bi bilo bolje uporabit manj zmogljivo ledico, ali onemogočiti delovanje pri polni moči.Samo da vas mal spomnim, naslov teme je Kataro kvalitetno ročno svetilko kupiti...
Ali, drugače povedano, zakaj bi vnaprej omejil največjo moč svetilke? Kaj bi s tem pridobil? Če je uporabnik pameten, pač ne bo vklopil turbo (in se potem čudil, da je lučka prevroča, in da po nekaj deset sekundah ne sveti več tako močno). Za tiste, ki niso pametni uporabniki, pa pač termoregulacija poskrbi, da se lučka ne pokvari.
Po drugi strani pa lahko takšno lučko uporabiš tudi kot grelnik za roke pozimi, kar je čisto koristna zadeva. Lučka je malo manj učinkovita pri tem kot namenski grelniki, ampak če namenskega nimaš...
so, i have a wurkoss ts22 in my edc, and i have discovered that it makes an AMAZING little impromptu hand warmer. throw it in turbo and clutch it in both hands, beam is warm enough to start and it'll get hoy quick. turn it off when it gets too hot, back on when it's starting to get cool.
lubej1 ::
Samael ::
Zato, ker je vedno bolj pogosto nesorazmeren nesmisel, ki razen kazanju mišic na papirju ne služi prav ničemer, razen tveganju da lučko skuriš. V zadnjih letih gre tekma za lumne v skrajnost. Še pred nedavnim so se lučke določenih dimenzij (na eno baterijo) precej kurile že na 1000lm max/1400lm turbo. Danes temu ni več tako. Recimo pred časom sem se obregnil ob tole lučko:
Astrolux® EA04 4*HP50 12600LM
Torej imaš mini lučko s štirimi požrtnimi ledicami na, pazi to, ENO BATERIJO, s FET driverjem, ki jo na turbo ženeš 12600LM. Svetilnost na max je pa koliko? 1000lm? 800lm? Ja, ko bi bila vsaj ...
In če se greš tu slučaaaajno turbo bo kaj? Tekma med extremno termoregulacijo ali izpraznjeno baterijo? :)
Razumel bi nekaj v smislu low/mid/high/turbo - 100/400/800/1400 - ker pač poglej dimenzije lučke, pa ti bo takoj jasno. Tu so pa nabildali idiotskih 12600lm. Koliko je max si pa niti ugibati ne želim, ker sem povsem prepričan, da ni nekih znosnih 800lm.
Ko si rekel, da pa lučko uporabljaš na polovični moči. Ne tudi polovična moč tu je krepko v neuporabnem turbu. Tudi četrtina moči tu je še vedno krepko v neuporabnem turbu. In ja, res je, lahko si pozoren in jo vedno uporabljaš na treh procentih (?!) torej 400 ali nekaj lumnih ampak ej ... vse ostalo je vseeno en velik nesmisel.
Pač to je moj vidik s stališča same uporabnosti vs bildanju specifikacije v tekmi za več (neuporabnih) lumnov.
Samael != Samuel
- spremenilo: Samael ()
Ampak če hočeš recimo uporabljati lučko pri 500 lumnih, kaj je bolje, da je narejena tako, da teh 500 lumnov doseže pri 100% svoje moči, ali pri 10%?
Samael ::
Vem kaj želiš povedati, mislim pa da ne razumeš kaj želim povedati jaz.
Če je 500 lumnov nekakšen max in 300 lumnov nekako stabilna svetilnost, ki jo po petnajstih sekundah vzpostavi termoregulacija, lučka nima nobene uporabne vrednosti pri 5000000000000000000000000000 lumnih. Sploh pa ne v ozkem ohišju pri eni bateriji.
Ko ti rečeš, saj lahko pa lučko uporabljaš na pol manj, sem v "race for lumens" primeru zgoraj pokazal, da je ne moreš oz. tudi pri pol manj ni uporabna. Še več, tudi pri 25% svetilnosti je ne moreš, še vedno ni uporabno. Ma kaj, tista zgoraj še pri 10% ni uporabna. To naredi race for lumens. In tega je vedno več.
Argument, ki ga zastopaš je deloval mogoče še dve-tri leta nazaj, ko so iz mid 400 in max 900 napihnili turbo na 1400 (kar je samo po sebi pri nekaj sekundem gonjenje lučke omenjenih formatov na robu). Danes ga znajo napihniti pri podobnem formatu lučk na eno baterijo že na 10000lm - kar glede na termofizikalne omejitve, ter omejitve baterij res res res nima nobenega smisla.
Nedavno nazaj sem videl lučko na 14500 baterijo s turbom preko 1600lm. Ne spomnim se koliko je imela max, verjetno okoli 1000lm, pri čemer ni treba biti genij, da razumeš, da bo lučka delala na 200lm, se pri 400 lumnih že konkretno kurila, pa tudi highdrain baterija na 800 ali 900mAh pri teh 400lm ne živela prav dolgo. Ampak važno, da "doseže" neuporabnih 1000-1500lm. Tega enostavno ne moreš več enačiti s stepdownom o katerem smo s skepso govorili še tri leta nazaj. Je šlo nekaj dolgih korakov dalje.
Pa da odgovorim še na tvoje vprašanje. Če je lučka primerna za oddajanje 5000 lumnov nimam nobene težave le te uporabljati na 500lm - če tako narekujejo okoliščine. To so običajno večje, masivnejše lučke na več baterij. Ampak trend čimveč lumnov za čim manšo ceno narekuje približevanje ali preseganje meje 5000 lumnov tudi lučkam, ki nimajo prav nobene uporabne vrednosti pri teh deklariranih lumnih. In na te se obregujem.
Ko ti praviš "ta trend bi bil problem, če lučke ne bi mogel uporabljati pri manjši jakosti" ampak v resnici ne gre za to da ne bi mogel ampak prav moraš. 5000lm za ozko malo lučko na eno baterijo standardnega formata ni realna uporabna opcija. Torej je dokaj nesmisel. V vsakem primeru takšno lučko pri neki uporabi (in ne zgolj par sekudnem testu) "moraš" uporabljati na 500lm ne pa da jo lahko.
Upam, da sem povedal dosti jasno. Ampak kot pravim, to je moje mnenje - ni nobene potrebe da čutiš enako, tovrstne lučke s trenutno tehnologijo in trenutnimi omejitvami pa vseeno ne boš uporabljal na 5000lm. Niti na pol manj. :P
Samael != Samuel
Samael ::
V tekmi za lumni je razmerje tisto, kar se povečuje. Če si imel včasih za lučko, ki si jo lahko nekako normalno gnal na 600 lumnih turbo 1600, ga imaš lahko danes za podobno lučko, ki jo še vedno lahko normalno goniš zgolj na 600 lumnih turbo že na 5000 ali več.
Mogoče me tudi nisi razumel. Nimam nobenih težav, če je lučka dejansko narejena za 5000lm, pa ima turbo mogoče 8000lm (kar je sicer še vedno velik razpon) pa jo imaš opcijo gnati na 500lm. To samo po sebi ne razumem kot race for lumens. Je pač lučka zmogljivejša. Problem imam s tistimi lučkami, ki so še vedno narejene za 600lm, pa jim nabijejo nevem koliko tisoč lumnov turba - ker zakaj že? Ja, ker se prodaja med zanesenjaki, to je pa bolj kot ne vse.
Samael != Samuel
Ampak ali je zaradi tega "nabijanja" kaj slabša, če jo uporabljaš na 5% moči, kot lučka, ki ni "nabita" in mora delati na 50% ali več svoje največje moči, da doseže recimo dalj časa trajajočih 500 lumnov?
A bi bil bolj srečen, če bi popolnoma enako lučko (Astrolux(R) EA04 4*HP50 12600LM) deklarirali kot 1500 lumnov, in softwersko omejili, da močneje ne bo mogla svetit?
Samael ::
Še vedno ponavljaš isto in ti lahko odgovorim enako - da 12600LM cifra pri omenjeni lučki nima nobene uporabne vrednosti in služi zgolj prodaji zanesenjakom. V resnici je obratno, kot sprašuješ - a si bolj srečen, ker je hardversko sfejkana, da misliš, da jo lahko uporabljaš pri deklariran svetilnosti, pa čeprav je v resnici ne moreš. Nekdo, ki nima pojma bi bil lahko - ti veš pa bolje. Tudi v Katrco lahko vgradiš motor Ferarija, I guess ... pa je ne boš vozil kot Ferarija ampak z vsemi ostalimi omejitvami še vedno kot Katrco.
Lahko te pa jaz vprašam, če bi lučko, kot je EA04 4*HP50 uporabljal na 12000 lumnih, ampak vprašanje je v resnici zgolj retorično, ker oba vema, da je ne bi oz. bolje rečeno je ne moreš. Ti bi najbrž rekel, da ti pač nudi več opcij, pa čeprav ti jih v resnici ne. Skratka, vseeno je, a kot turbo piše 1500lm ali 12000lm. Svetilnost pade globoko dol povsem navpično. Uporabljal jo boš v skladu s fizikalnimi omejitvami (mala baterija, hitro pregrevanje) na 800lm pa bo še vedno vroča.
Samael != Samuel
Samael ::
aja, pa mogoče ima turbo omejitev na še vedno visokih (vse kar je turbo je zunaj cone udobja same lučke, torej visoko) 1500lm celo večji smisel in bo dlje časa svetila na 1000lm (predno bo padla na 800 ali 600lm) kot pa bi momentalno pregreta svetila 1000lm s pritiskom na 12000lm - ampak to zdaj špekuliram. Bi moral videti par grafov.
Samael != Samuel
Dri3r ::
Enkrat službeno, pozimi, noč.. smo se peljali čez Vremščico (Divača -> Pivka). Dobro staro FT03 XHP50 sem držal zunaj (čez okno na vratih) in osvetljeval cesto daleč naprej, kot to zmorejo avtomobilske luči (zaradi ovinkov). Celo pot na turbo modu. Zaradi ugodne zunanje temperature in hitrosti se lučka sploh ni segrela, opaznega step downa ni bilo. Ledica je preživela, baterija (21700 Samsung 40T) pa tudi.
dri3r
Ker ne razumeš vprašanja, ali pa nanj nočeš odgovoriti.
Moje vprašanje je, ali bi bila ta lučka pri enakem hardveru boljša, če bi jo softversko omejili na recimo 1500 lumnov? Jaz ne trdim, da je 12600 lumnov uporabnih, jaz sprašujem, ali ta možnost pomeni, da je lučka zaradi tega pri 1000 lumnih slabša, kot bi bila, če bi ji softversko omejili moč.
In drugi vprašanje, če odmislimo softversko omejevanje moči. A so te najnovejše ledice, ki jih je mogoče tako zelo naviti, slabše od starješih ledic, ki jih ni mogoče tako zelo naviti? A je pri teh navitih svetilkah elektronika slabša, hlajenje slabše? A so 5 let stare svetilke, ki jih ni mogoče tako zelo naviti, boljše?
Ker po moji logiki je takša lučka vseeno boljša, pri 1000 lumnih, kot je pri 1000 lumnih lučka, ki je ni mogoče za hip naviti na 10.000 lumnov. Ker imajo boljše hlajenje, bolj vzdržljivo elektroniko - sicer bi pri 10.000 lumnih takoj "pregorele".
Samael ::
@Dri3r, pri FT03 XHP50 4300lm turbo mode ni ekstrem. Lučka je relativno velika, masivna in turbo mode ni desekratnik ali dvajsetkratnik HIGH stopnje, kot tista novejša "race for lumens" mini lučka zgoraj, ki sem jo dal za primer.
Se pa kljub temu najbrž motiš. Stepdown je verjetno bil, kot je tudi velika verjetnost, da pri bolj postopnem stepdownu tega nisi opazil. Tudi če je človek pri miru, in strmi proti snopu svetlobe, postopen padec s 4000 lumnov na 1500 lumnov očem ni tako zelo očiten, kot bi človek mislil.
@Okapi, kako nočem? Komu pa odgovarjam, če ne tebi. Samo ker si se ti to izmislil, ne razumeš, ali pa ne dobiš odgovora s katerim se strinjaš, še ne pomeni da ga ni. A bi ti kaj pomagalo, če še enkrat citiram kaj sem ti odgovoril in odebelim ključne dele?
Najbolj hecno je pa da si v zadnjem postu tudi sam deloma napisal to, kar ti jaz že veš čas razlagam - le z drugimi besedami.
Verjetno je bolj kot ne isti drek in posledično ni nobenega uporabnega razloga, da so jo navili na 12600 lumnov momentalnega turba razen komercilanega. Ker ljudje padajo na velike cifre.
Tako pa naredijo pri 10.000 takoj kaj točno že? Po hitrem postopku počepnejo na maks. Isto, kot pri 2.000 lumnih. Spet isti drek. (no, mogoče pri 2.000 lumnih turba počepne pod 1000 lumnov celo malce počasneje).
Pa še enkrat ponavljam, ker vem da prezreš dele, ki ti ne dajo potrdtive, ki jo iščeš: Nimam nobenih težav, če je lučka dejansko narejena za 5000lm, pa ima turbo mogoče 8000lm (kar je sicer še vedno velik razpon). To samo po sebi ne razumem kot race for lumens. Je pač lučka zmogljivejša.
Problem (pa ajde, problem niti ni prava beseda, zgolj pripombo recimo) imam s tistimi lučkami, ki so še vedno že zaradi fizikalnih omejitev glede na trenutne materiale narejene za 600lm, pa jim nabijejo nevem koliko tisoč lumnov turba - ker zakaj že? Ja, ker se prodaja med zanesenjaki, to je pa bolj kot ne vse.
In pa da, če Astrolux EA04 4*HP50 ne bi bila navita (ker daj prosim poskušaj razumeti, da turbo to je - navito preko meja stabilne uporabe), da ti da za en kratek moment 12600 ampak navita, da ti da za za en kratek moment 2000 lumnov, ne bi bila nič kaj slabša. V obeh primerih turba, ta lučka ni za realno uporabo nad 1000 lumni. Pa še to bo preklemansko vroča (in v resnici padla še kaj nižje).
Pa še nekaj. V sami osnovi nimam nič proti turbu. Moje pisanje je zgolj pripomba, ko je turbo v tekmi za čim več lumni iz komercialnih razlogov navit do absurda brez kakršne koli dodatne/uporabne vrednosti. (če boš igoriral ta del, ti ga bom skopiral ponovno).
"Jaz ne trdim, da je 12600 lumnov uporabnih, jaz sprašujem, ali ta možnost pomeni, da je lučka zaradi tega pri 1000 lumnih slabša, kot bi bila, če bi ji softversko omejili moč."
"Ker po moji logiki je takša lučka vseeno boljša, pri 1000 lumnih, kot je pri 1000 lumnih lučka, ki je ni mogoče za hip naviti na 10.000 lumnov. Ker imajo boljše hlajenje, bolj vzdržljivo elektroniko - sicer bi pri 10.000 lumnih takoj "pregorele"."
Samael != Samuel
Ales ::
Marketing narekuje vse višje svetilnosti, to se mi zdi očitno. Ampak vse dokler je turbo izpeljan na temeljih kolikor toliko solidnega inženiringa, je vse ok.
Če pa bo dirka za lumni pripeljala do tega, da bomo imeli situacije: "Open nitro! Witness me!"
Čemur potem sledi sfižen blisk, eksplozija in: "Mediocre Lučkar! Mediocre!"
...pa ne bo v redu.
...pa ne bo v redu.
Dodatna vrednost je (po moji hipotezi), da to prinese boljše, zanesljivejše delovanje pri nižjih jakostih. Če hočejo lučko naviti na 12.600 lumnov, ne da bi v par sekundah pregorela, morajo čim bolj optimizirati hlajenje, elektroniko, uporabiti najzmogljivejše ledice... In zaradi tega bolje ali zanesljiveje deluje, ko jih uporabljaš pri 1000 lumnih.
Podobno kot recimo ure, ki zdržijo 600 metrov globine. Za praktično vsakogar je to povsem nepotrebna lastnost, ampak ne moreš reči, da so zaradi tega slabše od ur, ki zdržijo samo 100 m globine. Kvečjemu so boljše, ker je večja verjetnost, da bodo dovolj vodotesne za tuširanje tudi po več letih, ko bodo tesnila že malce "ostarela".
Če so zaradi tega nabijanja lumnov lučke dražje, kot bi bilo nujno potrebno (za dobro delovanje pri 100 lumnih), je to sicer slabo, ampak konkratno ta Astroluxova ni zaradi teh "dodatnih in neuporabnih" lumnov videti nič kaj dosti dražja.
