[c#] delegat, event handler
DuleKrtola ::
Živ,
ne obvladam najbol teh delegatov, spodaj je koda. Sem probal pobrisat čimveč kode, ki je irelavantna, pa je vseeno 90 vrstic.
using System;
using System.Windows.Forms;
using WiimoteLib;
namespace joyPoll
    public partial class Form1 : Form
        public delegate void UpdateWiimoteStateDelegate(WiimoteChangedEventArgs args);
        Dictionary<Guid, Form1> mWiimoteMap = new Dictionary<Guid, Form1>();
        private Wiimote mWiimote;
        WiimoteCollection mWC;
        public Form1()
            InitializeComponent();
        public Form1(Wiimote wm) : this()
            mWiimote = wm;
        private void Form1_FormClosing(object sender, FormClosingEventArgs e)
            foreach (Wiimote wm in mWC)
                wm.Disconnect();
        public void UpdateState(WiimoteChangedEventArgs args)
	    //BeginInvoke(new UpdateWiimoteStateDelegate(UpdateWiimoteChanged), args);
            if (IsHandleCreated)
            else
                CreateHandle();
        private void Form1_Load(object sender, EventArgs e)
            mWC = new WiimoteCollection();
            try
                mWC.FindAllWiimotes();
                Form1 wi = new Form1();
                mWiimoteMap[wm.ID] = wi;
                // connect it and set it up as always
                wm.WiimoteChanged += wm_WiimoteChanged;
                wm.Connect();
                if (wm.WiimoteState.ExtensionType != ExtensionType.BalanceBoard)
                    wm.SetReportType(InputReport.IRExtensionAccel, IRSensitivity.Maximum, true);
                wm.SetLEDs(true, true, false, true);
                break;
        void wm_WiimoteChanged(object sender, WiimoteChangedEventArgs e)
            Form1 wi = mWiimoteMap[((Wiimote)sender).ID];
               wi.UpdateState(e);
        private void UpdateWiimoteChanged(WiimoteChangedEventArgs args)
            WiimoteState ws = args.WiimoteState;
            lblAccel.Text = ws.AccelState.Values.ToString();
			// tukaj se updatejo labele in checkboxi v formu
        public Wiimote Wiimote
            set { mWiimote = value; }
Če odkomentiram 34. vrstico ter zakomentiram IF/ELSE, dobim runtime error v omenjeni vrstici:
System.InvalidOperationException was unhandled
Message="Invoke or BeginInvoke cannot be called on a control until the window handle has been created."
Source="System.Windows.Forms"
Če pustim tako kot je (zakomentirane vse 3), mi CreateHandle() povzroči, da se program usuje.
Bi kdo vrgel uč na tole kodo, pls?
Mitja Bonča ::
Delegati potrebujejo eno kontrolo za metodo BeginUpdate (ali katero drugo):
Tebi manjka:
Control.BeginUpdate(new UpdateWiimoteStateDelegate(UpdateWiimoteChanged), args);
poglej si čisto simple primer:
public delegate void InvokeDelegate();
private void Invoke_Click(object sender, EventArgs e)
   myTextBox.BeginInvoke(new InvokeDelegate(InvokeMethod));
public void InvokeMethod()
   myTextBox.Text = "Executed the given delegate";
c# form
Oddelek: Programiranje
132339 (1853) FuI2cY
[c#] Risanje z miško
221789 (1470) japol
[c#] event, klik tipke escape
71087 (991) japol
[c#] Vprasanje glede BackGroundWorker classa in spreminanja gui elementa
61097 (1023) Ericssony
[VB] Komunikacija s serijskimi napravami
412733 (2007) mNeRo
