Forum » Pomoč in nasveti » nestabilni XPji
nestabilni XPji
THX ::
do nedavnega je bil moj comp še kr stabilen.
mislm da se skor nikol ni sesul, 1-2x na mesec.
pred ksnim tednom pa se je zadeva začela preveč sesuvat. 3-4 krat na dan. naložu nism nč novga, nč kej posebnga nism počel.
nakar je blo men vsega dost in sm mal začel brskat po XP jih kje bi kej pisal kaj je blo narobe. v nadzorna plošča/administrative tools/component services sm pod event viewer/system našu tele error reporte:
AMLI: ACPI BIOS is attempting to write to an illegal IO port address (0xcf8), which lies in the 0xcf8 - 0xcff protected address range. This could lead to system instability. Please contact your system vendor for technical assistance.
The UDNT service failed to start due to the following error:
The system cannot find the device specified.
AMLI: ACPI BIOS is attempting to read from an illegal IO port address (0xcfc), which lies in the 0xcf8 - 0xcff protected address range. This could lead to system instability. Please contact your system vendor for technical assistance.
Error code 00000050, parameter1 fffaf6f4, parameter2 00000001, parameter3 bf805255, parameter4 00000000.
Error code 100000ea, parameter1 ff926268, parameter2 81a78100, parameter3 81b2a440, parameter4 00000001.
Error code 1000008e, parameter1 c0000005, parameter2 00000005, parameter3 f3d04c7c, parameter4 00000000.
Error code 000000d1, parameter1 0000002b, parameter2 00000002, parameter3 00000000, parameter4 f965f7f6.
a kdo mogoče ve kaj to pomen pa kako se zadeva rešuje?
al pa saj če bo kej pomagal če dam comp na servis pa jim tole pokažem?
Gh0st ::
Mam feeling da imaš spor med napravami...
Poglej spore IRQ, IO porte, DMA settingse....al pa driverje sistemskih naprav...
you might start believe in Gh0st stories. you're in one. :)
THX ::
ful je enih stvari na irq 11. a je lohk to problem?
sicer nikjer ne piše da je kje kej v sporu...
najbl me pa mot da sta dvoje od tega grafična pa zvočna. kje to popravm?
okol io portov mi ni nč jasn... kaj kje in kako?
ID kanala sta vsak na svojem irq -ju, en je dma mode 5 an pa mode 2, zgleda vse ok.
kako spravm vse une pizdarije iz irq 11?
ka tm je polek zvočne pa grafe še puno enih manjših zadev.
McHusch ::
ne mores. Win2000 ter XP uporabljajo ACPI ter sami razporedijo sredstva napravam tako, kot jim najbolj pase, tko da razen ce nimas kaksne ultra stare kartice, to ni problem.
mogoc ti pa kak RAM modul crkuje?
BigHugo ::
THX: Kaj, če bi najprej povedal nekaj osnovnih podatkov o tvojem računalniku (plata, proc, rami, ...), da ti lahko svetujemo.
LP BigHugo
THX ::
BigHugo: sory...
torej:
abit kg7
athlon xp 1600+
ram 266 DDR PC 2100 (od kjere ferme pojma nimam)
grafična gf 2 mx 400
ibm 40 GB 7200 rpm
sb live
mrežna
cd rw teac 24x/10x/40x
napajalnik 300W
aja, še neki...
nazadne ka sm bil neki pametn pa sm hotu bios fleshat je ram crknu. ne vem al je to slučajno al ma to kej veze, sam pol sm pelu comp na servis pa so menal ram pa je pol delal. od takrt fleshu jst bios ne sploh, me pa zanima če sm ram jst kako s fleshanjem zj** al je to slučaj?
sej se zdi zlo neverjetno, sam ram je točn takrt crknu
torej:
abit kg7
athlon xp 1600+
ibm 40 GB 7200 rpm
sb live
mrežna
napajalnik 300W
aja, še neki...
- spremenil: THX ()
Gh0st ::
Poglej da nimaš slučajno kakšne stare ISA mrežne kartice, ki ji moraš vrednosti IRQ nastawlat preko jumperjev. Dej neki kartic vn, mal troubleshooting se pejt ane!
THX ::
problem je v tem ker comp zmrzne mal na random, tud napake so precej random. mrežna ni isa ampak pci, stara par mesecev...
za tak troubleshooting pa rabš cajt, ka ga pa jst zdele nimam. ka bi mogu vsako kartico ksn dan testerat pa to
Gh0st ::
Jah, včasih si je treba tud vzet cajt, pa zadevo rešit...
vem jest sm preklel te compe še preveč, zato pa zdj delajo
THX ::
maš res...
bom jutr probu najprej xpje sam čez naložit, bomo vidl če bo kej pomagal. če ne pa čez vikend... troubleshooting
| » | Modri zaslon na win 7Oddelek: Pomoč in nasveti | 2197 (1898) | rsroki |
| » | prosim za pomoč- kako odpraviti tole napako...Oddelek: Pomoč in nasveti | 5070 (4579) | Mavrik |
| » | Podatki iz Memory-Dump-a?Oddelek: Pomoč in nasveti | 2580 (2134) | R33D3M33R |
| » | BSOD pri Remote Desktopu v Win 2003 Server R2 Enterprise SP2Oddelek: Pomoč in nasveti | 2338 (2165) | ender |
| » | Restartiranje računalaOddelek: Pomoč in nasveti | 1877 (1586) | THX |
