Forum » Programska oprema » C# in internetna stran
cikopero ::
Živijo,
delam aplikacijo, ki bi komunicirala z internetno stranjo COBISS. Do sedaj sem prišel do naslednjega:
Našel sem primer, kako upravljati s spletno stranjo:
Sam sem uporabljal:
Težava je, ker je posebej vodena posamezna seja - različni link. V kodi strani najdem link, kamor kaže gumb za iskanje.
Ko uporabim povezavo, na katerega kaže gumb iskanje, mi sporoči, da je potrebno narediti novo sejo - zadnji result.
Morda kaka ideja, kako se lotiti problema. Sam imam le malo izkušenj s spletnimi stranmi, ravno tako šele dobro spoznavam C#.
Hvala za ideje,
Lep pozdrav Peter
public class PostSubmitter
/// <summary>
/// determines what type of post to perform.
/// </summary>
public enum PostTypeEnum
/// <summary>
/// Does a get against the source.
/// </summary>
Get,
/// <summary>
/// Does a post against the source.
/// </summary>
Post
private string m_url=string.Empty;
private NameValueCollection m_values=new NameValueCollection();
private PostTypeEnum m_type=PostTypeEnum.Get;
/// <summary>
/// Default constructor.
/// </summary>
public PostSubmitter()
/// <summary>
/// Constructor that accepts a url as a parameter
/// </summary>
/// <param name="url">The url where the post will be submitted to.</param>
public PostSubmitter(string url):this()
m_url=url;
/// <summary>
/// Constructor allowing the setting of the url and items to post.
/// </summary>
/// <param name="url">the url for the post.</param>
/// <param name="values">The values for the post.</param>
public PostSubmitter(string url, NameValueCollection values):this(url)
m_values=values;
/// <summary>
/// Gets or sets the url to submit the post to.
/// </summary>
public string Url
get
return m_url;
set
m_url=value;
/// <summary>
/// Gets or sets the name value collection of items to post.
/// </summary>
public NameValueCollection PostItems
get
return m_values;
set
m_values=value;
/// <summary>
/// Gets or sets the type of action to perform against the url.
/// </summary>
public PostTypeEnum Type
get
return m_type;
set
m_type=value;
/// <summary>
/// Posts the supplied data to specified url.
/// </summary>
/// <returns>a string containing the result of the post.</returns>
public string Post()
StringBuilder parameters=new StringBuilder();
for (int i=0;i < m_values.Count;i++)
EncodeAndAddItem(ref parameters,m_values.GetKey(i),m_values[i]);
string result=PostData(m_url,parameters.ToString());
return result;
/// <summary>
/// </summary>
/// <param name="url">The url to post to.</param>
public string Post(string url)
m_url=url;
return this.Post();
/// <summary>
/// </summary>
/// <param name="values">The values to post.</param>
public string Post(string url, NameValueCollection values)
m_values=values;
return this.Post(url);
/// <summary>
/// Posts data to a specified url. Note that this assumes that you have already url encoded the post data.
/// </summary>
/// <param name="postData">The data to post.</param>
/// <param name="url">the url to post to.</param>
/// <returns>Returns the result of the post.</returns>
private string PostData(string url, string postData)
HttpWebRequest request=null;
if (m_type==PostTypeEnum.Post)
Uri uri = new Uri(url);
request = (HttpWebRequest) WebRequest.Create(uri);
request.Method = "POST";
request.ContentType = "application/x-www-form-urlencoded";
//request.ContentType = "text/html; charset=utf-8";
request.ContentLength = postData.Length;
using(Stream writeStream = request.GetRequestStream())
UTF8Encoding encoding = new UTF8Encoding();
byte[] bytes = encoding.GetBytes(postData);
writeStream.Write(bytes, 0, bytes.Length);
else
Uri uri = new Uri(url + "?" + postData);
request.Method = "GET";
string result=string.Empty;
using (HttpWebResponse response = (HttpWebResponse) request.GetResponse())
using (Stream responseStream = response.GetResponseStream())
using (StreamReader readStream = new StreamReader (responseStream, Encoding.UTF8))
result = readStream.ReadToEnd();
return result;
/// <summary>
/// Encodes an item and ads it to the string.
/// </summary>
/// <param name="baseRequest">The previously encoded data.</param>
/// <param name="dataItem">The data to encode.</param>
/// <returns>A string containing the old data and the previously encoded data.</returns>
private void EncodeAndAddItem(ref StringBuilder baseRequest, string key, string dataItem)
if (baseRequest==null)
baseRequest=new StringBuilder();
if (baseRequest.Length!=0)
baseRequest.Append("&");
baseRequest.Append(key);
baseRequest.Append("=");
baseRequest.Append(HttpUtility.UrlEncode(dataItem));
Sam sem uporabljal:
PostSubmitter post = new PostSubmitter();
//post.Url = "http://cobiss.izum.si/scripts/cobiss?ukaz=GETID&lani=en";
post.Url = "http://cobiss.izum.si/scripts/cobiss?ukaz=GETID&lani=si";
post.Type = PostSubmitter.PostTypeEnum.Get;
result = post.Post();
//dobimo ID seje
int iIndex = result.IndexOf("http://cobiss4.izum.si/scripts/cobiss?id=");
string newUrl = null;
if (iIndex != -1)
for (int i = 0; i < result.Length; i++)
if (result[i + iIndex] == '\"')
break;
newUrl += result[i + iIndex];
else
iIndex = result.IndexOf("http://cobiss2.izum.si/scripts/cobiss?id=");
if (iIndex != -1)
break;
//to je naslov, na katerega kaže gumb za iskanje knjižnice
result = newUrl;
if (newUrl != null)
post.Url = newUrl;
//poiskali bomo knjiznice, ki ima v imenu FE
post.PostItems.Add("bstr", "FE");
post.Type = PostSubmitter.PostTypeEnum.Post;
//DobljeniString.Text = result;
Hvala za ideje,
Lep pozdrav Peter
c00L3r ::
Ti morda to kaj pomaga? Sam se mislim v prihodnosti lotit enega podobnega projekta. Moral bom prebrat podatke iz določene spletne strani, kjer moram bit login-an. Sporoči kako je šlo.
cikopero ::
Hvala za nasvet,
Na hitro sem pogledal, vendar brez uspeha. Se bom še malo bolj poglobil v tej smeri. Če mi uspe, sporočim.
Lp,
Peter
| » | Davčne blagajne (strani: 1 2 3 4 … 24 25 26 27 )Oddelek: Programiranje | 390330 (130333) | Macketina |
| » | [PHP]Zajem slike iz direktorijaOddelek: Programiranje | 1788 (1705) | KernelPanic |
| » | [C# asp.NET web forma] Kam zgine cookie oz. zkj se izbriše?Oddelek: Programiranje | 1470 (1284) | Morenov |
| » | ASP.NET + C# vprašanjeOddelek: Programiranje | 3314 (2328) | Morenov |
| » | C#; WebClient class; problem z uploadanjemOddelek: Programiranje | 1755 (1714) | 64202 |
