C# in internetna stran
cikopero ::
Živijo,
delam aplikacijo, ki bi komunicirala z internetno stranjo COBISS. Do sedaj sem prišel do naslednjega:
Našel sem primer, kako upravljati s spletno stranjo:
        public class PostSubmitter
            /// <summary>
            /// determines what type of post to perform.
            /// </summary>
            public enum PostTypeEnum
                /// <summary>
                /// Does a get against the source.
                /// </summary>
                Get,
                /// <summary>
                /// Does a post against the source.
                /// </summary>
                Post
            private string m_url=string.Empty;
            private NameValueCollection m_values=new NameValueCollection();
            private PostTypeEnum m_type=PostTypeEnum.Get;
            /// <summary>
            /// Default constructor.
            /// </summary>
            public PostSubmitter()
            /// <summary>
            /// Constructor that accepts a url as a parameter
            /// </summary>
            /// <param name="url">The url where the post will be submitted to.</param>
            public PostSubmitter(string url):this()
                m_url=url;
            /// <summary>
            /// Constructor allowing the setting of the url and items to post.
            /// </summary>
            /// <param name="url">the url for the post.</param>
            /// <param name="values">The values for the post.</param>
            public PostSubmitter(string url, NameValueCollection values):this(url)
                m_values=values;
            /// <summary>
            /// Gets or sets the url to submit the post to.
            /// </summary>
            public string Url
                get
                    return m_url;
                set
                    m_url=value;
            /// <summary>
            /// Gets or sets the name value collection of items to post.
            /// </summary>
            public NameValueCollection PostItems
                get
                    return m_values;
                set
                    m_values=value;
            /// <summary>
            /// Gets or sets the type of action to perform against the url.
            /// </summary>
            public PostTypeEnum Type
                get
                    return m_type;
                set
                    m_type=value;
            /// <summary>
            /// Posts the supplied data to specified url.
            /// </summary>
            /// <returns>a string containing the result of the post.</returns>
            public string Post()
                StringBuilder parameters=new StringBuilder();
                for (int i=0;i < m_values.Count;i++)
                    EncodeAndAddItem(ref parameters,m_values.GetKey(i),m_values[i]);
                string result=PostData(m_url,parameters.ToString());
                return result;
            /// <summary>
            /// </summary>
            /// <param name="url">The url to post to.</param>
            public string Post(string url)
                m_url=url;
                return this.Post();
            /// <summary>
            /// </summary>
            /// <param name="values">The values to post.</param>
            public string Post(string url, NameValueCollection values)
                m_values=values;
                return this.Post(url);
            /// <summary>
            /// Posts data to a specified url. Note that this assumes that you have already url encoded the post data.
            /// </summary>
            /// <param name="postData">The data to post.</param>
            /// <param name="url">the url to post to.</param>
            /// <returns>Returns the result of the post.</returns>
            private string PostData(string url, string postData)
                HttpWebRequest request=null;
                if (m_type==PostTypeEnum.Post)
                    Uri uri = new Uri(url);
                    request = (HttpWebRequest) WebRequest.Create(uri);
                    request.Method = "POST";
                    request.ContentType = "application/x-www-form-urlencoded";
                    //request.ContentType = "text/html; charset=utf-8";
                    request.ContentLength = postData.Length;
                    using(Stream writeStream = request.GetRequestStream())
                        UTF8Encoding encoding = new UTF8Encoding();
                        byte[] bytes = encoding.GetBytes(postData);
                        writeStream.Write(bytes, 0, bytes.Length);
                else
                    Uri uri = new Uri(url + "?" + postData);
                    request.Method = "GET";
                string result=string.Empty;
                using (HttpWebResponse response = (HttpWebResponse) request.GetResponse())
                    using (Stream responseStream = response.GetResponseStream())
                        using (StreamReader readStream = new StreamReader (responseStream, Encoding.UTF8))
                            result = readStream.ReadToEnd();
                return result;
            /// <summary>
            /// Encodes an item and ads it to the string.
            /// </summary>
            /// <param name="baseRequest">The previously encoded data.</param>
            /// <param name="dataItem">The data to encode.</param>
            /// <returns>A string containing the old data and the previously encoded data.</returns>
            private void EncodeAndAddItem(ref StringBuilder baseRequest, string key, string dataItem)
                if (baseRequest==null)
                    baseRequest=new StringBuilder();
                if (baseRequest.Length!=0)
                    baseRequest.Append("&");
                baseRequest.Append(key);
                baseRequest.Append("=");
                baseRequest.Append(HttpUtility.UrlEncode(dataItem));
Sam sem uporabljal:
            PostSubmitter post = new PostSubmitter();
            //post.Url = "http://cobiss.izum.si/scripts/cobiss?ukaz=GETID&lani=en";
            post.Url = "http://cobiss.izum.si/scripts/cobiss?ukaz=GETID&lani=si";
            post.Type = PostSubmitter.PostTypeEnum.Get;
            result = post.Post();
            //dobimo ID seje
            int iIndex = result.IndexOf("http://cobiss4.izum.si/scripts/cobiss?id=");
            string newUrl = null;
            if (iIndex != -1)
                for (int i = 0; i < result.Length; i++)
                    if (result[i + iIndex] == '\"')
                        break;
                    newUrl += result[i + iIndex];
            else
                iIndex = result.IndexOf("http://cobiss2.izum.si/scripts/cobiss?id=");
                if (iIndex != -1)
                            break;
            //to je naslov, na katerega kaže gumb za iskanje knjižnice
            result = newUrl;
            if (newUrl != null)
                post.Url = newUrl;
                //poiskali bomo knjiznice, ki ima v imenu FE
                post.PostItems.Add("bstr", "FE");
                post.Type = PostSubmitter.PostTypeEnum.Post;
            //DobljeniString.Text = result;
Težava je, ker je posebej vodena posamezna seja - različni link. V kodi strani najdem link, kamor kaže gumb za iskanje.
Ko uporabim povezavo, na katerega kaže gumb iskanje, mi sporoči, da je potrebno narediti novo sejo - zadnji result.
Morda kaka ideja, kako se lotiti problema. Sam imam le malo izkušenj s spletnimi stranmi, ravno tako šele dobro spoznavam C#.
Hvala za ideje,
Lep pozdrav Peter
c00L3r ::
Ti morda to kaj pomaga? Sam se mislim v prihodnosti lotit enega podobnega projekta. Moral bom prebrat podatke iz določene spletne strani, kjer moram bit login-an. Sporoči kako je šlo.
cikopero ::
c00L3r je izjavil:
Hvala za nasvet,
Na hitro sem pogledal, vendar brez uspeha. Se bom še malo bolj poglobil v tej smeri. Če mi uspe, sporočim.
Lp,
Peter
Davčne blagajne (strani: 1 2 3 4 … 24 25 26 27 )
Oddelek: Programiranje
1344390329 (130332) Macketina
[PHP]Zajem slike iz direktorija
51788 (1705) KernelPanic
[C# asp.NET web forma] Kam zgine cookie oz. zkj se izbriše?
61470 (1284) Morenov
ASP.NET + C# vprašanje
343314 (2328) Morenov
C#; WebClient class; problem z uploadanjem
51755 (1714) 64202
