Forum » Programiranje » C++ keylogger
C++ keylogger
Hexx ::
Po Googlu sem malo brskal o keyloggerjih za linux, pa sem naletel na tole:
To zgleda da je nek log file v /var/log pa nevem kateri. Če bi tole našel, bi lahko naredil program v C++u program ki pretvori to obliko zapisa v berljivo. Kaj je tale modul evbug/evdev? Kako bi našel tole?
Samo za izobraževalne namene seveda
Hvala,
Hexx
Keylogging is very simple. It's all there in the kernel. You need to use module evbug (or evdev). If you modprobe evbug and do a dmesg you'll see something like this
Code:
[4298922.635000] evbug.c: Event. Dev: isa0060/serio0/input0, Type: 1, Code: 103, Value: 0
[4298922.635000] evbug.c: Event. Dev: isa0060/serio0/input0, Type: 0, Code: 0, Value: 0
[4298923.302000] evbug.c: Event. Dev: isa0060/serio0/input0, Type: 4, Code: 4, Value: 200
[4298923.302000] evbug.c: Event. Dev: isa0060/serio0/input0, Type: 1, Code: 103, Value: 1
[4298923.302000] evbug.c: Event. Dev: isa0060/serio0/input0, Type: 0, Code: 0, Value: 0
Hvala,
Hexx
| » | Ubuntu vprašanjaOddelek: Operacijski sistemi | 3383 (2132) | roksson |
| » | Čudno obnašanje miškeOddelek: Strojna oprema | 1956 (1542) | a13misko |
| » | Internet dela ali ne dela (lnux)Oddelek: Operacijski sistemi | 2558 (2227) | root |
| » | ATI linux gonilnliki in resolucijaOddelek: Operacijski sistemi | 2619 (2506) | roli |
| » | Predolgo nalaganje kernelaOddelek: Operacijski sistemi | 1841 (1717) | BigWhale |
