Forum » Programiranje » Java and MySQL problem
fingaz ::
Pozdravljeni :)
Imam problem pri povezavi jave in mysql. Imam nalogo pri kateri se moram preko jave povezati na bazo in izvrsiti nekaj select stavkov, vendar pa se mi zatakne pri povezavi na bazo.Ker to delam prvič, prosim za pomoč in razlago.
Hvala
package predavanja;
import java.sql.*;
public class Odbc {
* @param args
public static void main(String[] args) {
Connection conn = null;
try
String userName = "pbvaje";
String password = "pb";
String url = "jdbc:mysql://localhost/vaje";
Class.forName ("com.mysql.jdbc.Driver").newInstance ();
conn = DriverManager.getConnection (url, userName, password);
System.out.println ("Database connection established");
catch (Exception e)
System.err.println ("Cannot connect to database server");
finally
if (conn != null)
try
conn.close ();
System.out.println ("Database connection terminated");
catch (Exception e) { /* ignore close errors */ }
Hvala
FrEaKmAn ::
Malo več informacij kaj se zgodi bi bilo dobro :D samo verjetno nimaš connectorja (ugibam) - http://www.mysql.com/products/connector/
| » | [Java] Urejanje baze z JTableOddelek: Programiranje | 1441 (1225) | vonNeumann |
| » | Netbeans + AccessOddelek: Programiranje | 1037 (966) | Napoleon II |
| » | [JAVA] mysql-connector-java in povezava z MysqlOddelek: Programiranje | 2501 (2383) | Sergio |
| » | [Java] Shranjevanje podatkov in datotekOddelek: Programiranje | 1584 (1537) | Vesoljc |
| » | Kako pošiljanje datotek v JAVI.Oddelek: Programiranje | 2229 (2100) | kopernik |
