Forum » Pomoč in nasveti » Gmail in stiki
Gmail in stiki
JOKER ::
Imam problem, ki ga ne znam rešit, pa še na živce mi gre. Torej.
Vsak ki mi piše na moj gmail naslov, ga avtomatsko doda med moje stike. Zakaj!?
Kako se tega znebim?
Imam recimo oglas na netu in vsak ki mi piše je potem v mojih stikih. Potem pa imam toliko stikov brezveze. Kje se to označi, da se nehajo beležit?
Hvala za vsakršno pomoč, je bom hvaležen, ker mi to že gre na živce.
Hvala.
Hvala.
________________________________________________________
Ka te češ ....
Ka te češ ....
- polepsal: bluefish ()
JOKER ::
Kaj to pomeni, da ni rešitve?
Ampak koliko je meni znano, da tega prej včasih ni bilo.
Ka te češ ....
Ka te češ ....
bluefish ::
Sodeč po vprašanjih na Googlu enostavne rešitve ni. Tule je morda en workaround: http://www.google.com/support/forum/p/g...
Workaround, still requires you take time, but it does at least sort out the unwanted email addresses:
photogman wrote:
This works perfectly!!
Here is a simple workaround that gives us back the original "Suggested Contacts" group functionality so that we can delete and change auto-added contacts.
Just enter a blank space in the Contacts search box, (then hit return or press search) and this will produce a list of all your contacts SORTED by the group names. With the final group being Other Contacts, that is, all of the auto-added contacts that are in All Contacts but not yet in any other group.
This works brilliantly. You can use the control-key to select all the contacts you want to delete. I'm not sure why Google has not suggested this before. Believe me, I asked them several times. I just lucked out finding it today on another forum.
billy ::
Upam, da je to prava tema za moje vprašanje, da ne odpiram nove...
Stike iz google/gmaila bi rad shranil samo na huawei telefon. Da lahko potem pobrišem ta google account iz telefona. Pa nikjer na najdem te opcije? Poleg stika mi samo napiše, kje je shranjen, ni pa neke opcije "move to phone", ali podobno. Obstaja kaka rešitev?
kloko ::
Zna biti da je odvisno od verzije Androida. Sem ravno prejšnji teden to počel, tam nekje pri Contacts je opcija "Move contacts", ki vse stike premakne iz Googla na telefon ali sim kartico, kar pač izbereš.
L.p., Kloko
L.p., Kloko
| » | HSMC insolventenOddelek: Novice / Nakupi / združitve / propadi | 10039 (7887) | djabi |
| » | kraja identitete email naslovOddelek: Pomoč in nasveti | 2650 (1948) | zmaugy |
| » | Phishing ali res težava?Oddelek: Pomoč in nasveti | 1977 (1219) | ngc2392 |
| » | Computer infectedOddelek: Pomoč in nasveti | 2159 (1970) | boss-tech |
| » | Submersed CoolingOddelek: Hlajenje in modifikacije | 3325 (3001) | Tomi |
