HAMACHI
HAMACHI
cbpopaj ::
Pozdravljeni nikjer ne najdem pravega odgovora zanima me če moram pri uporabi hamachija forwardat porte na firewallu in na rutarju PA KATERI PORT JE TO.
Uporabljal bi ga kot VPN povezavo.
Lp. HVALA ZA ODGOVOR Marjan
amigo_no1 ::
fosil ::
Pri hamachiju ni treba forwardirat portov.
Tako je!
cbpopaj ::
Hvala lepa za odgovor!
cbpopaj ::
Pa še nekaj me zanima.Je obvezno da imaš statični zunanji IP.ali ne?
amigo_no1 ::
Ne.
Hamachi @ Wikipedia
Each Hamachi client is assigned an IP address from the 5.0.0.0/8 address block. This address is assigned when the client logs into the system for the first time, and is henceforth associated with the client's public crypto key. As long as the client retains its key, it can log into the system and use this 5.x.x.x IP address.
  • spremenilo: amigo_no1 ()
cbpopaj ::
Hvala zanima me zaradi kolega ki nima statičnega IP-ja.
Arduino in luči (strani: 1 2 )
9814637 (12263) FX6300B
ICS Internet Connection Sharing in IP naslov 192.168.0.1
Oddelek: Omrežja in internet
93280 (2491) MrStein
Apache - localhost JA, IP naslov NE
187246 (7105) ManDriver
Računalnike naključno izkaplja iz mreže
111814 (1674) A-L-E-N
router dela na nekih url jih samo polovično
152021 (1837) Medo_m
