Forum » Strojna oprema » 750 Gb Samsung crknil - kako do podatkov?
lopov ::
Zdravo!
Kakšno leto star disk iz Hoferja v zunanjem ohišju je nenadoma odpovedal poskušnost in v windows javlja, da ni formatiran. Gor so za lastnika pomembni podatki :)
Disk sem vzel iz ohišja, ga priklopil direkt v mašino in pognal ubuntu live CD.
Tole javi:
Fdisk nima problemov s prepoznavanjem:
Mountat se ga pa vseeno ne da ...
Smatram, da je elektronika OK. Še kakšna ideja, kako do podatkov?
Lp,
b.
Tole javi:
[ 15.492610] sd 3:0:0:0: [sda] 1465149168 512-byte hardware sectors: (750 GB/698 GiB)
[ 15.492743] sd 3:0:0:0: [sda] Write Protect is off
[ 15.492745] sd 3:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 16.452972] ata4.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 16.452977] ata4.00: BMDMA stat 0x24
[ 16.452982] ata4.00: cmd c8/00:08:3f:00:60/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 16.452983] res 51/40:00:3f:00:60/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 16.452985] ata4.00: status: { DRDY ERR }
[ 16.452987] ata4.00: error: { UNC }
[ 17.428201] ata4.00: configured for UDMA/133
[ 17.428210] ata4: EH complete
[ 18.393757] ata4.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 18.393758] ata4.00: BMDMA stat 0x24
[ 18.393762] ata4.00: cmd c8/00:08:3f:00:60/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 18.393763] res 51/40:00:3f:00:60/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 18.393765] ata4.00: status: { DRDY ERR }
[ 18.393766] ata4.00: error: { UNC }
[ 19.368200] ata4.00: configured for UDMA/133
[ 19.368204] ata4: EH complete
[ 20.334566] ata4.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 20.334567] ata4.00: BMDMA stat 0x24
[ 20.334571] ata4.00: cmd c8/00:08:3f:00:60/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 20.334571] res 51/40:00:3f:00:60/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 20.334573] ata4.00: status: { DRDY ERR }
[ 20.334575] ata4.00: error: { UNC }
[ 21.308198] ata4.00: configured for UDMA/133
[ 21.308202] ata4: EH complete
[ 22.267082] ata4.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 22.267083] ata4.00: BMDMA stat 0x24
[ 22.267087] ata4.00: cmd c8/00:08:3f:00:60/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 22.267088] res 51/40:00:3f:00:60/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 22.267090] ata4.00: status: { DRDY ERR }
[ 22.267091] ata4.00: error: { UNC }
[ 23.240201] ata4.00: configured for UDMA/133
[ 23.240205] ata4: EH complete
[ 24.199597] ata4.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 24.199599] ata4.00: BMDMA stat 0x24
[ 24.199602] ata4.00: cmd c8/00:08:3f:00:60/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 24.199603] res 51/40:00:3f:00:60/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 24.199605] ata4.00: status: { DRDY ERR }
[ 24.199606] ata4.00: error: { UNC }
[ 25.188199] ata4.00: configured for UDMA/133
[ 25.188203] ata4: EH complete
[ 26.148699] ata4.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 26.148701] ata4.00: BMDMA stat 0x24
[ 26.148704] ata4.00: cmd c8/00:08:3f:00:60/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 26.148705] res 51/40:00:3f:00:60/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 26.148707] ata4.00: status: { DRDY ERR }
[ 26.148708] ata4.00: error: { UNC }
[ 27.128203] ata4.00: configured for UDMA/133
[ 27.128224] sd 3:0:0:0: [sda] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE,SUGGEST_OK
[ 27.128228] sd 3:0:0:0: [sda] Sense Key : Medium Error [current] [descriptor]
[ 27.128231] Descriptor sense data with sense descriptors (in hex):
[ 27.128233] 72 03 11 04 00 00 00 0c 00 0a 80 00 00 00 00 00
[ 27.128238] 00 60 00 3f
[ 27.128240] sd 3:0:0:0: [sda] Add. Sense: Unrecovered read error - auto reallocate failed
[ 27.128245] end_request: I/O error, dev sda, sector 6291519
[ 27.128297] Buffer I/O error on device sda1, logical block 3145728
[ 27.128346] Buffer I/O error on device sda1, logical block 3145729
[ 27.128393] Buffer I/O error on device sda1, logical block 3145730
[ 27.128440] Buffer I/O error on device sda1, logical block 3145731
[ 27.128504] ata4: EH complete
sudo fdisk /dev/sda Disk /dev/sda: 750.1 GB, 750156374016 bytes 255 heads, 63 sectors/track, 91201 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Disk identifier: 0xbf0e91e7 Device Boot Start End Blocks Id System /dev/sda1 1 91201 732572001 7 HPFS/NTFS
sudo mount -t ntfs /dev/sda1 /mnt/disk1 Error reading $MFT: Input/output error Failed to load $MFT: Input/output error Failed to mount '/dev/sda1': Input/output error
Lp,
b.
- spremenil: lopov ()
Duhec ::
Osebno bi najprej pognal HDD Regenerator, ki je neodvisen test bad sektorjev glede na OS.
Potem pa po vrsti nek test za MBR, potem nek test iz Recovery testov za particijo, če je z njo ali njih vse ok, nato še File Recovery....
Vse imaš na Hiren's BootCD-ju.
lopov ::
Trenutno gre čez disk HDD regenerator ... Slabo kaže. Slabih sektorjev ko dreka. Sicer je dosedaj še vsakega uspešno popravil, ampak traaaaaja. Me prav zanima koliko bo uporabnega ko konča. No ne vem, ker če prav razumem uro zgoraj desno ima pri tolikšni škodi dela za več kot 6 dni ...
lopov ::
Zdravo! Program je z delom na dobri polovici, našel & popravil preko 1500 napak in naj bi končal čez dobre 4 ure (upam!). Zanima me, kako naprej z ostalimi testi. Se lahko bolj specifično pove, kateri "nek" test za MBR in "nek" test za particije s Hiren's boot CD se priporoča? Se bojim, da odkrivam področje, o katerem nimam pojma :/
bluefish ::
Ko tale program opravi do konca kar priklopi disk v nek računalnik in poskusi, če boš lahko dostopal do podatkov, šele nato se lotevaj obnavljanja particije etc.
lopov ::
Definitivno bi probal, če ne drugega da se malo poigram, a nimam nobenega tako velikega diska da bi naredil dd. Sem poslal lastniku msg če bo on kaj ukrenil v tej smeri, sam ne grem v stroške.
Hvala!
Hvala!
ender ::
Če disk crkuje, se sploh ne ukvarjaj s programi, ki naj bi ga "popravili" - disk priklopi v kišto, zraven daj enak ali večji disk, potem pa z ddrescue ali dd_rescue+dd_rhelp narediš kopijo celotnega diska (takšno kopiranje lahko traja več dni). Vse reševanje podatkov potem delaš na kopiji.
lopov ::
Zgleda bo res tako najbolje. Program je končal in popravil preko 2000 napak, delal pa dobrih 6 ur. Priklopil sem na mašino, pa ni bilo sreče, javi da strutura ni berljiva. Zdaj sem še 1x pognal HDDregenerator in mi je takoj našel & popravil slab sektor. Najbolje da res počakam, da se nabavi disk, naredim image in se igram s tem.
Hvala za nasvete in predloge.
Lp,
b.
Lp,
b.
| » | BSOD me spravlja v obupOddelek: Strojna oprema | 2347 (1819) | rsroki |
| » | Disk umiraOddelek: Strojna oprema | 2113 (1398) | Ramon dekers |
| » | Kako ustvarit kopijo diska 1:1 ???Oddelek: Strojna oprema | 3460 (2978) | s1m0n |
| » | navijanje dellaOddelek: Navijanje | 1584 (1476) | MecH |
| » | Ubuntu vprašanjaOddelek: Operacijski sistemi | 3383 (2132) | roksson |
