Windows Vista, Intel PRO/1000 MT Dual Port Server Adapter in LACP
NoName ::
Torej... omislil sem si nov switch, ki podpira LACP. Le-tega sem uspešno skonfiguriral na prvih nekaj portih
1,2 grupa 1 - linux masina
3,4 grupa 2 - windows masina
na obeh kistah je identicna mrezka. na linuxu dela vse tipi topi, kar je razvidno iz tegale
Ethernet Channel Bonding Driver: v3.4.0 (October 7, 2008)
Bonding Mode: IEEE 802.3ad Dynamic link aggregation
Transmit Hash Policy: layer2 (0)
MII Status: up
MII Polling Interval (ms): 80
Up Delay (ms): 0
Down Delay (ms): 0
802.3ad info
LACP rate: slow
Active Aggregator Info:
Aggregator ID: 1
Number of ports: 2
Actor Key: 17
Partner Key: 259
Partner Mac Address: 00:40:c7:01:23:45
Slave Interface: eth0
MII Status: up
Link Failure Count: 2
Permanent HW addr: 00:04:23:aa:bc:c0
Aggregator ID: 1
Slave Interface: eth1
MII Status: up
Permanent HW addr: 00:04:23:aa:bc:c1
Aggregator ID: 1
na visti mi pa nikakor ne uspe... wireshark pravi, da dobi LACP pakete, vendar windows ne gane...
Frame 1 (126 bytes on wire, 126 bytes captured)
Arrival Time: Oct 4, 2009 00:03:52.915005000
[Time delta from previous captured frame: 0.000000000 seconds]
[Time delta from previous displayed frame: 0.000000000 seconds]
[Time since reference or first frame: 0.000000000 seconds]
Frame Number: 1
Frame Length: 126 bytes
Capture Length: 126 bytes
[Frame is marked: False]
[Protocols in frame: eth:slow]
Ethernet II, Src: RubyTech_01:23:45 (00:40:c7:01:23:45), Dst: Slow-Protocols (01:80:c2:00:00:02)
Destination: Slow-Protocols (01:80:c2:00:00:02)
Address: Slow-Protocols (01:80:c2:00:00:02)
.... ...1 .... .... .... .... = IG bit: Group address (multicast/broadcast)
.... ..0. .... .... .... .... = LG bit: Globally unique address (factory default)
Source: RubyTech_01:23:45 (00:40:c7:01:23:45)
Address: RubyTech_01:23:45 (00:40:c7:01:23:45)
.... ...0 .... .... .... .... = IG bit: Individual address (unicast)
Type: Slow Protocols (0x8809)
Link Aggregation Control Protocol
Slow Protocols subtype: LACP (0x01)
LACP Version Number: 0x01
Actor Information: 0x01
Actor Information Length: 0x14
Actor System Priority: 32768
Actor System: RubyTech_01:23:45 (00:40:c7:01:23:45)
Actor Key: 515
Actor Port Priority: 32768
Actor Port: 3
Actor State: 0x7f (Activity, Timeout, Aggregation, Synchronization, Collecting, Distributing, Defaulted)
.... ...1 = LACP Activity: Yes
.... ..1. = LACP Timeout: Yes
.... .1.. = Aggregation: Yes
.... 1... = Synchronization: Yes
...1 .... = Collecting: Yes
..1. .... = Distributing: Yes
.1.. .... = Defaulted: Yes
0... .... = Expired: No
Reserved: 000000
Partner Information: 0x02
Partner Information Length: 0x14
Partner System Priority: 32768
Partner System: 00:00:00_00:00:00 (00:00:00:00:00:00)
Partner Key: 0
Partner Port Priority: 32768
Partner Port: 3
Partner State: 0x5a (Timeout, Synchronization, Collecting, Defaulted)
.... ...0 = LACP Activity: No
.... .0.. = Aggregation: No
..0. .... = Distributing: No
Reserved: 000000
Collector Information: 0x03
Collector Information Length: 0x10
Collector Max Delay: 0
Reserved: 000000000000000000000000
Terminator Information: 0x00
Terminator Length: 0x00
Reserved: 000000000000000000000000000000000000000000000000...
se screenshoti konfiguracije:
 network connections
network connections
 team #0 Properties
team #0 Properties
kaksna ideja, kje naj iscem napako?
I can see dumb people...They're all around us... Look, they're even on this forum!
BSOD problem
92231 (1889) Oktan
Ubuntu vprašanja
Oddelek: Operacijski sistemi
483356 (2105) roksson
wpasupplicant in SD LJ
Oddelek: Omrežja in internet
112132 (1946) r5r
LG GSA-4120B dela probleme pri pečenju DL DVD+Rjev
442172 (1981) mtosev
problemi z zvocno v linuxu
82016 (1959) BigWhale
