Forum » Programiranje » Osveževanje podatkov v comboboxu
brinovcek ::
Zanima me, kako bi dodal/osežil seznam podatkov v combobox po tem ko sem že naložil podatke v dataset, iz katerega se podatke črpa za prikaz in v bazo dodal še nekaj novih podatkov. Ni mi jasno zakaj se ne naložijo ob vsakem odiranju forma ponovno podatki iz baze v dataset in me zanima kaj bi moral v kodi spremeniti da bi se stvar osveževala oz posodabljala ob vsakem odpiranju? v Formu imam tudi en gumb ki bi mi stvari ponovno naložil vendar mi ob pristisku na gumb javi napake:
************** Exception Text **************
System.ArgumentException: This causes two bindings in the collection to bind to the same property.
Parameter name: binding
at System.Windows.Forms.ControlBindingsCollection.CheckDuplicates(Binding binding)
at System.Windows.Forms.Binding.CheckBinding()
at System.Windows.Forms.Binding.SetBindableComponent(IBindableComponent value)
at System.Windows.Forms.ControlBindingsCollection.AddCore(Binding dataBinding)
__________________________________________________________________________________________________________________________
Program:
public partial class Projekt : Form
string DN, Ime, Opis;
int ID;
//static int i = 0; //index for strArraylist
DateTime Datum;
public Projekt()
InitializeComponent();
napolniProjekt();
napolniDelavca();
private void Projekt_Load(object sender, EventArgs e)
// TODO: This line of code loads data into the 'bazaDataSet1.Storitve' table. You can move, or remove it, as needed.
this.storitveTableAdapter.Fill(this.bazaDataSet1.Storitve);
public void napolniProjekt()
DataViewManager dview = new DataViewManager();
OleDbConnection myConn = null;
OleDbDataAdapter Adapter=null;
DataSet dset=null;
DataBindings.Clear();
try
//open the connection to the database
myConn = new OleDbConnection();
myConn.ConnectionString = connection();
myConn.Open();
catch (OleDbException ex)
MessageBox.Show("Error in connection ..." + ex.Message);
string sqlStr = "SELECT ID_Projekta,Delovni_nalog,Ime,Opis,Dat_Zacetka FROM Projekt WHERE Zaprt=false";
//Instantiate a DataAdapter by passing the sqlStr and Connection.
//now data is in raw form
Adapter = new OleDbDataAdapter(sqlStr, myConn);
//Instantiate a DataSet
dset = new DataSet();
dset.Clear();
//Gets a collection that provides the master mapping
// between a source table and a DataTable
Adapter.TableMappings.Add("Table", "Projekt");
Adapter.Fill(dset);
dview = dset.DefaultViewManager;
comboBox1.DataSource = dview;
comboBox3.DataSource = dview;
this.comboBox1.DisplayMember = "Projekt.Ime";
this.comboBox3.DisplayMember = "Projekt.Delovni_nalog";
//DataBinding for the TextBox controls
this.datum.DataBindings.Add("Text", dview, "Projekt.Dat_Zacetka");
this.textBox3.DataBindings.Add("Text", dview, "Projekt.Opis");
this.textBox4.DataBindings.Add("Text", dview, "Projekt.ID_Projekta");
// Close the connection to the database.
myConn.Close();
private void button3_Click(object sender, EventArgs e)
napolniProjekt();
Prosim za pomoč, če kdo ve, kaj je treba spremenit ali padodatk da stvar dela tako kot želim.
Hvala
Program:
int ID;
DateTime Datum;
public Projekt()
napolniProjekt();
napolniDelavca();
DataSet dset=null;
try
myConn.Open();
dset.Clear();
Adapter.Fill(dset);
myConn.Close();
napolniProjekt();
Hvala
| » | C# težavaOddelek: Programiranje | 4951 (3797) | mladec |
| » | [C#,SQL]Oddelek: Programiranje | 1750 (1663) | JanOlMajti |
| » | Baza & c#Oddelek: Programiranje | 4760 (3818) | xardas |
| » | [C#] ne dodaja podatkov v bazoOddelek: Programiranje | 1896 (1745) | alesp56 |
| » | razložitev nekaterij elementov v visual studio 05Oddelek: Programiranje | 2605 (2410) | darkolord |
