[VB] brisanje polne mape
jishiri ::
zdravo
malo sem se igral in bi naredil program ki bi brisal premikal koperal datoteke in mape... sedaj se mi je ustavilo pri brisanju polne mape.. (prazne lepo brise)
Private Sub Button2_Click(ByVal sender As System.Object, _
ByVal e As System.EventArgs) Handles Button2.Click
        For Each Item As IO.FileInfo In _ Me.CheckedListBox2.CheckedItems
            Try
                If Item.Exists = True Then Item.Delete()
            Catch : End Try
        Next Item
        For Each Item As IO.DirectoryInfo In Me.CheckedListBox1.CheckedItems
            Try
            Catch : End Try
        Next Item
end sub
hvala za pomoce in nasvete...
  • spremenil: Primoz ()
AndrejS ::
Pobrisat še moreš datoteke in mape v tej mapi. Uporabiš rekurzijo
jishiri ::
aja tocno cist pozabu...:D hvala
*ziga* ::
Public Function KillFolder(ByVal FullPath As String) _
   As Boolean
'PURPOSE: DELETES A FOLDER, INCLUDING ALL SUB-
'         DIRECTORIES, FILES, REGARDLESS OF THEIR
'         ATTRIBUTES
'PARAMETER: FullPath = FullPath of Folder to Delete
'RETURNS:   True is successful, false otherwise
'REQUIRES:  'VB6
            'Reference to Microsoft Scripting Runtime
            'Caution in use for obvious reasons
'EXAMPLE:   'KillFolder("D:\MyOldFiles")
On Error Resume Next
Dim oFso As New Scripting.FileSystemObject
'deletefolder method does not like the "\"
'at end of fullpath
If Right(FullPath, 1) = "\" Then FullPath = _
    Left(FullPath, Len(FullPath) - 1)
If oFso.FolderExists(FullPath) Then
    'Setting the 2nd parameter to true
    'forces deletion of read-only files
    oFso.DeleteFolder FullPath, True
    KillFolder = Err.Number = 0 And _
      oFso.FolderExists(FullPath) = False
End If
End Function
Private Sub Form_Load()
KillFolder "C:\test"
End Sub
To bi moralo delat.Drugic poisci malo po netu.
BigWhale ::
Ja, sam glej, da ti ne bo stacka zmanjkal!!!
jishiri ::
hvala za te vrstice... sem stvar resil na podoben nacin, le malo se razlikuje, da brise v ciklih, glede na kolicino faila v sami mapi in ostalih podmapah... da ne bi prihajalo do neodzivnosti programa...
hvala za pomoc...
LP, JM
  • spremenilo: jishiri ()
Visual Basic
Oddelek: Programiranje
314229 (3255) cekr
[VB] polepšanje kode
71132 (1038) korenje3
[VB] Komunikacija s serijskimi napravami
412722 (1996) mNeRo
VB.net MDI in formi splošno
91968 (1911) strel
vkljucevanje txt datoteke v ...
131995 (1771) webblod
