Xtreamer - media player
98 / 105
RudeBw ::
novitibo je izjavil:
sm preveril - še vedno je orig X fw boljši.
No hvala, samo to sem hotel zvedet, ker se mi ravno ne da znova vsega v XT-ju nastavljat (NFS Server, xLive, movie Jukebox, in še bi se našlo. In če ni delujočega web browserja, se ne bom igral z novimi FW-ji.
dsapac ::
RudeBw je izjavil:
novi update: New line of FW - AMP (r8)
Če je kdo preizkusil, prosim za krajši review, kako se obnese na MK1.
dsapacTV Xtreamer xLive Links
Postby andy78 » Yesterday, 17:56
flash amp_r8_hd2
download putty http://www.putty.org/
Run puty, select connection type TELNET
anter IP address of your Xtreamer
Open connection. Login as root
copy and paste first command
sskin get xpro270 default
when download is finished, type
sskin change xpro270 default
Copy dsapac contect to sda1\scripts\xlive (in my case). Delete old xlive folder first
DONE
Edit
There should be run install.php script from the web browser
xtreamer_ip/media/sda1/scripts/xLive/install.php
Unfortunately web server and xtreamering section stoped responding after installation.
Here is the solution:
Replace two files in this location- scripts\xLive\www\cgi-bin
lighttpd.conf and lighttpd_local.conf
then, run install.php
I attach these files in zip
http://www.moservices.org/forum/downloa...
RudeBw ::
Hvala za tip.
John ::
ENOSTAVNO, NE DELA - EDINO, KAR NAREDI OB POSKUSU UPORABE SIOL-A JE, DA SE XTREAMER TEMELJITO OBESI, TV PA JAVI: no signal ...
dsapac je izjavil:
RudeBw je izjavil:
flash amp_r8_hd2
DONE
Edit
dsapac ::
Ja vem sem dobil feedback. Ocitno bo treba malce drugace zadevo naredit
brko20 ::
Pozdravljeni!
Sem sicer pred kratkim zasledil ta predvajalnik xtreamer, zanima me pa naslednje: kakšna je razlika predvajanja HD filma iz tega predvajalnika in iz računalnika na tv? Ali je očitna razlika v kvaliteti ali je sploh ni...
Pač karkoli bi me prepričalo v nakup slednjega, ker sem do sedaj predvajal filme na računalniku.
hvala!
uvz123 ::
Ne bi je smelo bit!
kremenko1 ::
Žena lahko sedi za rač. jaz pa gledam filme. Drugače pa ni neke razlike.
astras ::
kvecjemu je bolje, ker je verjetno tv ekran vecji ;)lp
***Ce bil bi vedez...... ne bil bi ...... revez***
biasko ::
Živjo!
Tale tema je precej obsežna in nisem našel konkretnega odgovora na moje vprašanje - dopuščam da sem spregledal.
Imam Prodigy, Linksys s tomato FWjem ter SIOL optiko.
Želel bi IPTV + INTERNET na Prodigy po enem kablu.
Mi lahko nekdo konkretno pokaže navodila za nastavitve Tomatota ter kako priključiti kable.
Najlepša vam hvala!
OLIva ::
Hi,
odkar mam na PC-jih povsod W7, mi X na mreži ne zazna nobenga PC več.
Dokler je bil kje kak z XP-ji, je to delal.
A mi zna kdo povedat, kje je fora, kaj nardit.
  • spremenil: OLIva ()
astras ::
zacetnik11 ::
Pozdravljeni
Imama eno vprašanje in sicer sem malo opustil xtreamerja, vendar sedaj želim naložit nov firmvare, vendar ne vem več katerega izbrati.
Imam xtreamer prvi ki je prišel ven SideWinder. Prosil bi če mi lahko poveste kaj vse lahko naložim, da bom imel vse posodobljeno.
Hvala za pomoc in lep pozdrav.
astras ::
2.7
dsapac ::
zacetnik11 je izjavil:
Pozdravljeni
No ja najnovejsi je 2.7.1 kateri ima vkljucen AirPlay. Mislim da ce nalozis 2.7 bo tudi v redu ce ne uporabljas te storitve. Drugace pa najdes moj
posodobljeni paket dsapacTV oziroma xLive na uradnem forumu: http://forum.xtreamer.net/topic/18778-n...
Je nekaj novosti kot xListPlay: http://forum.xtreamer.net/topic/28033-x...
  • spremenil: dsapac ()
lukc1234 ::
@dsapac
Pozdravljen,
svaka čast za razvoj toliko super funkcij za Xtreamer. Imam težavo, ki mi jo mogoče lahko pomagate rešiti:
Xtreamering se mi nikakor noče inštalirat - vsakič mi ga zloada in kao instalira, in naslednjič zopet javi, da ga ni instaliranega. Imam 2.7.1 na MK1.
Brez Xtreameringa pa mi baje xLive ne more delovati. Sem iskal po spletu in nikjer nisem našel rešitve. Ali mi je rešitev telnet in manualno kopiranje fajlov ali kaj naj storim? Kakšen nasvet?
Hvala,
rembrandtm ::
Pozdravljeni, malo sem ven iz novic o XT-ju, pa me zanima, če je zunaj že tako imenovani Music Box ali nekaj podobnega. No, rad bi preko Xt-ja fural muziko, pa da nima milijon map urejenih, kot hočem,...nekaj so omenjali, da bo ta podpora zunaj ?
alex401 ::
lukc1234 je izjavil:
@dsapac
Pozdravljen,
Hvala,
- enak problem in prav tako ne vem kako bi se ga lotil. V bistvu ko vleče dol, gre do 98 %, kjer se ustavi, gre ponovno v glavni meni in vse ponovi.
kmetek ::
Poštimal sem si ftp....ampak kaj ko hudič preko wifija gre pod 2MB/s.....se da kako tole pohitriti? Imam disk priklopljen za xtreamer.
clancy ::
Anteno priklopi na 2m dolg USB podljšek in jo pritrdi nekam vstran od televizije na bolj prosto mesto.
Meni tudi ni šlo, sedaj je hitrost 3,1MB/s, dovolj za gledanje 720p vsebin brez zatikanja;)
damjan1980 ::
imam eno vprasanje glede dekodiranja zvoka. ocitno mi digitalni signal xtreamer sam dekodira, ker mi na recieverju pise da sprejema analogni signal na 2 kanalih. ve kdo mogoce ce se da kje nastavit, da zvok samo skozi spusti (passthrough), da mi ga reciever dekodira?
telexdell ::
damjan1980 je izjavil:
kako pa imaš povezan Xtreamer in reciever? Če ju nimaš povezana preko HDMI ali optičnega kabla ne moreš dobiti kaj drugega kot mono ali stereo zvok.
Če imaš povezavo ustrezno, pa lahko v nastavitvah nastaviš, kako se obdeluje zvok Imaš na izbiro stereo, 5.1...
astras ::
a/v settings
damjan1980 ::
zvok je preko opticnega, edine opcije za nastavljanje izhoda pa sta LPCM in RAW
astras ::
kateri xtreamer imas?
damjan1980 ::
sidewinder 3
kmetek ::
kateri firmware je za mk1 zadnji, 2.70?
kmetek ::
mitko25 ::
2.71 je zadnji...
l.p.
kmetek ::
thanks
kdor ima težave z zvokom aka lip synch pri samsung tvjih + xtreamer naj naštima 50i ali 60i avdio ter 24p......sedaj dela dobro :)
finkec ::
Prodigy bi rad povezal na net preko routerja in nato šeral datoteke (NFS). Na računalniku sem nastavil vse potrebno, Xtreamer pa mi enostavno noče vzpostaviti povezave na net. DHCP išče vendar potem izpiše Fail, potem sem probal še statični IP vendar isto ne deluje. Nisem ravno poznavalec mrežnih povezav in sploh ne vem kaj je narobe.
ST-777 ::
Tudi meni se je zdel xtreamer zanimiv, ker pa sem izvedel za PocketTV, bom počakal z nakupom. PocketTV je nekoliko večji od običajnega USB pomnilniškega ključka, stane 99 $, ima gigaherčni procesor z integriranim grafičnim procesorjem (Full HD ločljivost), 512 MB RAM pomnilnika, 4 GB prostora za shranjevanje podatkov in režo za microSD kartice do 32 GB. Vse skupaj funkcionira na operacijskem sistemu Android.
PocketTV priključimo na televizor in lahko gledamo filme in še vse drugo, kar je tudi na smart telefonih. Kasneje bodo zagotovo prodajali še poceni prenosne zaslone (brez elektronike, ki je sedaj v tabličnih računalnikih), sliko pa bodo ti zasloni predvajali takrat, ko bomo nanj priključili ključek PocketTV.
PocketTV: http://www.kickstarter.com/projects/484...
Zanimiv projekt, sicer se ne bi branil HDMI 1.4 (s primerno strojno podpora seveda) namesto HDMI 1.3, ampak bi se dalo preživeti:D
  • spremenil: Gregor P ()
podtalje ::
Sicer lepo, da je omenjena alternativa. Ampak tema je Xtreamer, tako da prosim, da se dalje držite teme.
schrack ::
Imam xtreamer z Miškovo skripto 0.92, Siol IPTV, Sinope modem. Vse dela super pri meni.
Pri prijatelju sem priklopil na novi Siolov modem Oxygen. V obeh primerih priklopljen direkt v port 4, ki je nastavljen na video. Pri njem se mi enkrat poveže, ko ga ugasnem pa čakam tudi 5 minut in nikakor mi ne zalaufa IPTV.
Pod lan nastavitve imam nastavljen static IP, masko podomrežja, privzeti prehod 192.168.1.254(Oxygen modem) in dns vnešen od siola ( 193.189.160.13).
Mi lahko kdo svetuje, kako bi rešil omenjeni problem?
Hvala.
telexdell ::
Po LAN-u ti gre IPTV zato bi moral biti IP naslov v rangu 10.192... in maska 255.255.0.0
Izpolni tudi MAC naslov v skripti (izmisli si nekaj!), da ti ne bo prihajalo do blokad SIOL modema
PS- Da moraš ta ta IP vpisati v skripti pa gotovo veš?
schrack ::
Uf, to mi je nekaj novega.
Mi lahko prosim malo bolj natančno opišeš, ko imaš čas, prosim.
telexdell ::
schrack je izjavil:
Kako si pa nastavil doma?
Najprej moraš ugotoviti IP naslov SIOL komunikatorja. Ta mora bit v rangu 10.120.... in ne v rangi 169...
Nato v Miškovi skripti iptv_042 odpri datoteko "S99wlan_eth_activate". Pod ADDRESS vpiši naslov blizu naslova komunikatorja (če je naslov komunikatorja 10.120.10.10 potem vpiši npr 10.120.10.12). Pod NETMASK vpiši 255.255.0.0 pod GATEWAY pa prvi IP iz obsega (v gornjem primeru 10.120.10.1). Vpiši še MAC naslov (sam sem kar istega, katerega je predlagal Mišek), da ne bosta LAN in WLAN kartici imeli istega MAC naslova saj se bo SIOL modem v tem primeru zablokiral (utripajo vse lučke na njem).
Ko imaš spremembe vpisane instaliraj skripto na Xtreamer. Nato idi v nastavitve in nastavi Wlan povezavo za osnovno (če tega ne boš naredil, ti IPTV ne bo delala!). Nato izklopi in ponovno vklopi napravo. Če se ti je Xtreamer povezal preko WiFi in na LAN ni napisanega IP naslova si na dobri poti:)
PS- drugače pa malo prebrskaj ta forum in Xtreamer- IPTV forum. Je bilo že vse večkrat napisano.
schrack ::
telexdell je izjavil:
schrack je izjavil:
Doma imam router, Lan1 kabel iz siol modema v WAN router-ja, lan4 iz siol modema na lan routerja. Oboje kabel povezava.
Pri prijatelju sem povlekel 2 kabla, vendar enega takoj porabil za stacionarni računalnik.
Lan3(siol modem) imajo uporabljenega starši za siol box-s. On želi imeti le xtreamer na lan4.
Imam več možnosti:
1. Kupim wlan anteno za xtreamer
2. Vežem router (ali je dovolj switch?) in kabel, katerega uporablja stacionarni uporabim za iptv.
Je še kakšna možnost?
Hvala telexdell za tvojo pomoč.
lithium ::
Po dobrih dveh letih mi je odpovedal xtreamer (prva verzija).
Ko ga vključim z daljincem začne delati ventilator na polno, rdeča LED pa samo utripa. In takrat niti daljinc ne prime več.
Slike ni ne preko HDMI ne preko s-video.
Je imel kdo podobne probleme in ga je uspel oživeti?
Neuradni Telemach forum https://red-pill.eu/forum070
astras ::
rdeca utripa enakomerno?
lithium ::
Da, enakomerno. Ventilator pa ves čas na maksimum.
Imaš kakšno idejo?
astras ::
ta ventilator me malo bega, verjetno je samo kak kondenzator sel na mat... ce si pri nas kupil nam poslji pa bomo pogledali
lithium ::
Kupljen je bil septembra 2009 direktno od xtreamer.net
Aja, kondenzatorji delajo težave? Ga bom danes odprl in pregledal vezje ...
Zgleda, kot da se ustavi v fazi bootanja (sam čudno, ker ne kaže nobene slike na TV).
lithium ::
Sem odprl zadevo, kondenzatorji zgledajo OK, napajanje na vezju je 12V.
Imam občutek, da je corrupted nand flash, od koder se boota linux. Na plošči zgleda, da je tudi serijski port.
Je že kdo kaj programiral zadevo preko tega porta?
valiant ::
@lithium...meni je zadnjč prav tako "crknil" XT MK1. Pomagala je instalacija zadnjega "emegency sw" in to 2x; prvič če ni bilo ok. Obesil se je pri enem izmed filmov, ki so "čudno" ripani.
lithium ::
Sam kaj, ko ga ne morem naložiti. Slike na TV ni (tema), ko vpišem sekvenco za emergency sw pa LED dioda na USB ključku nič ne utripa (torej se nič ne dogaja).
A je tebi takrat tudi deloval ventilator na polno? Je bila vsaj slika na TV?
valiant ::
Za ventilator se ne spomnim, slike pa ni bilo. Potem sem naložil emergency fw 2.7.1 prvič...po restartu spet tema. Nato še enkrat emergency fw, potem po restartu, pa je šlo.
mambli ::
Zdravo,
mislim kupiti Xtremer Pro - sedaj je neka akcija in se ga dobiti za 125€.
Imam 100Mb povezavo in bi ga rad uporabljal, kot prostor za hrambo podatkov, gledanje filmov in poslušanje glasbe. Tudi slike bi dal tja.
imam tudi t-2, gotovo ne dela, da bi lahko gledal vse programe preko Xtremerja ?
Bi zadoščal mojim potrebam ?
lithium ::
valiant je izjavil:
Ok thanks. Bom poskusi danes še enkrat pa z drugim USB ključkom.
Kako si pa vedel, da ti nadgrajuje firmware, če ni bilo slike? Pa koliko časa je trajalo? :)
98 / 105
