Forum » Pomoč in nasveti » Matsonic ms9047c+
Matsonic ms9047c+
kalcek16 ::
Zanima me kje na internetu i lahko dobil kakšne odatke o tej plati? Predvsem me zanima katero podnožje ima in za katere procesorje je narejena, ker moram kupiti novo plato, ker se mi je ta skurla, pa nevem katero naj kupim?
AngelOfDeath ::
Vendor Matsonic
Model MS9047C+
Type motherboard
Chipset Intel 845D
Slot socket 478
Form factor ATX
Processors supported Intel Pentium IV • Willamette • 400 MHz
Intel Pentium IV • Northwood • 400 MHz
Intel Celeron • Willamette • 400 MHz
Intel Pentium IV • Northwood • 533 MHz
Bus frequency 100 MHz
133 MHz
Architecture details quad pumped system bus
RAM PC2100 DDR SDRAM
- 2 x DIMM 184-pin
- up to 2 GB
PC133 SDRAM
- 2 x DIMM 168-pin
- up to 2 GB
IO controller • Ultra ATA/100 • Intel ICH2
- 2-channel
- up to 4 device supported
• FDD • Intel ICH2
- 1-channel
- up to 2 device supported
• USB • Intel ICH2
- 2-channel
Features
Audio controller C-Media CMI9738 chipset
- 6-channel sound
supported standards:
- AC`97
Slots • 4 full size PCI
• 1 full size AGP
• 1 full size shared CNR/PCI
Internal Interfaces · 2 x Ultra ATA/100 • 40-pin IDC
· FDD • 34-pin IDC
· 2 x USB • USB pin header
· IrDA • 3-pin header
· CD input • 4-pin Molex
· Wake-on-LAN • 3-pin header
· Wake-on-ring • 3-pin header
External Interfaces · keyboard • 6-pin mini DIN
· mouse • 6-pin mini DIN
· 2 x USB • Type A
· parallel ECP/EPP • DB-25F
· 2 x serial RS-232 • DB-9M
· audio line-in • mini phone 3.5mm stereo
· audio line-out • mini phone 3.5mm stereo
· microphone • mini phone 3.5mm mono
· gameport / MIDI • DB-15F
BIOS AMI (flash)
BIOS functions PnP (v1.0a)
ACPI
DMI
APM (v1.2)
Software - drivers and tools
Technical specifications
Dimensions 30.4 x 24.4 cm
Model MS9047C+
Type motherboard
Chipset Intel 845D
Slot socket 478
Form factor ATX
133 MHz
- 2 x DIMM 184-pin
- up to 2 GB
PC133 SDRAM
- 2 x DIMM 168-pin
- up to 2 GB
- 2-channel
• FDD • Intel ICH2
- 1-channel
• USB • Intel ICH2
- 2-channel
Features
- 6-channel sound
- AC`97
• 1 full size AGP
· FDD • 34-pin IDC
· 2 x USB • Type A
BIOS AMI (flash)
ACPI
DMI
APM (v1.2)
edit: Slovnica
| » | 3-pin vs 4-pin ventOddelek: Strojna oprema | 4371 (3931) | bajsibajsi |
| » | problem z grafično kartico pri Gericom Supersonic force 16120Oddelek: Pomoč in nasveti | 1759 (1455) | Shark-357 |
| » | "Netbook" z tvoutom... a je ker?Oddelek: Kaj kupiti | 1518 (1189) | Klemenn |
| » | Ali je tale računalnik dober ali bi za takšen denar dobil kaj boljšega?Oddelek: Kaj kupiti | 1962 (1775) | IVo |
| » | Sempron 2400+ in A7S8X-MXOddelek: Navijanje | 2066 (1834) | Hardstyle |
