Forum » Omrežja in internet » CISCO Linksys WRT160n - wireless router
slitkx ::
Imam tale router...no, zadeva je taka.
ipconfig /all mi pokaže tole:
Microsoft Windows [Version 6.0.6001]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\to te nič ne briga>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Cisco
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : local.lan
Ethernet adapter Bluetooth Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
Physical Address. . . . . . . . . : 00-21-86-D1-88-5D
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Wireless Network Connection:
Connection-specific DNS Suffix . : local.lan
Description . . . . . . . . . . . : Intel® WiFi Link 5300 AGN
Physical Address. . . . . . . . . : 00-21-6A-05-CE-3E
Link-local IPv6 Address . . . . . : fe80::e8cd:bbe:1d4d:ed55%17(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.100(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : sreda, 8. april 2009 22:03:47
Lease Expires . . . . . . . . . . : četrtek, 9. april 2009 22:03:46
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 193.189.160.23
193.189.160.13
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : Intel® 82567LM Gigabit Network Connecti
on
Physical Address. . . . . . . . . : 00-22-64-6C-FE-C8
Link-local IPv6 Address . . . . . : fe80::3095:babc:a16b:b0c6%14(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.102(Preferred)
Lease Obtained. . . . . . . . . . : sreda, 8. april 2009 22:03:52
Lease Expires . . . . . . . . . . : četrtek, 9. april 2009 22:03:52
193.189.160.13
Tunnel adapter Local Area Connection* 114:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Local Area Connection* 30:
Description . . . . . . . . . . . : isatap.{5BE09471-4410-4B9B-9BAC-FC554B84E
65E}
Tunnel adapter Local Area Connection* 13:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 02-00-54-55-4E-01
Zanima me, na katerega od IPv4 moram nastaviti routing uTorrent porta, da bo mikrofrend deloval ok?
Sem sicer na optiki preko SiOL-a, zato imam v basic nastavitvah routerja izbran in nastavljen PPPoE (uporabniško ime in geslo).
V nastavitvah routerja pa trenutno zgleda takole, status:
Firmware Version: v2.0.01 build 012Aug 22, 2008
Firmware Verification: 222c328924c0e72c0d0f99b9a93f5a72
Current Time: Wed, 08 Apr 2009 22:29:05
Internet MAC Address: 00:22:6B:7B:62:03
Host Name:
Domain Name: local.lan
Internet Connection
Connection Type: PPPoE
Login Status: Connected
Internet IP Address: 208.44.175.42
Subnet Mask: 255.255.255.255
Default Gateway: 208.44.175.42
DNS1: 193.189.160.23
DNS2: 193.189.160.13
DNS3:
MTU: 1492
Pri SiOL-u imam izbran dinamični IP. Dokler sem dostopal do interneta direktno preko njihovega modema, ni bilo težav z routingom. Aja, pa naj omenim, da mi v ozadju teče ESET Smart Security z omogočenim firewallom. Bi lahko ta nagajal v router vgrajenemu firewallu?
Hvala za odgovore.
Lp.
193.189.160.13
on
193.189.160.13
65E}
Host Name:
Internet Connection
DNS3:
MTU: 1492
Hvala za odgovore.
Lp.
- spremenil: slitkx ()
| » | Težave - internetOddelek: Omrežja in internet | 2204 (1942) | megy |
| » | Zaradi mreže se mi tresejo možganiOddelek: Pomoč in nasveti | 3705 (2721) | Cervantes |
| » | Problem z internetomOddelek: Pomoč in nasveti | 3791 (3342) | RuskiSnajper |
| » | Problem router/mordemOddelek: Omrežja in internet | 3178 (2865) | gorenjc |
| » | xbox 360 & windows media playerOddelek: Konzole | 3921 (3068) | astras |
