Forum » Kaj kupiti » Nova plata
Nova plata
D3m0|is3n ::
Kupujem nov računalnik, pa se mi je malce zataknel pri pravi plati. Katero plato za Athlone bi vi priporočal pa bi jo dobil do okrog 50k SIT?
SLO-Security ::
Soyo,...
KO SE ZAVEŠ [NE]VARNOSTI HTTP://www.SLO-Security.com
NOVO: Na SLO-Security.com sedaj tudi FORUM-2! s strokovnjaki !
Malecky ::
Abit KX7!
.I must use DD's finesse and tweaking to achieve the scores I do at the Mhz I run. I'll say in great modesty...that breaking 15,000 with "just over" 2 gigs of AMD Athlon XP was to me an unthinkable goal....and to have made it is a great testament to the power of the XP once you learn how to unleash it...and the KX7-333R was instrumental in doing just that.
I will reiterate here that this board is the best performance AMD solution available...and the most stable AMD board I've ever owned..bar none.
| » | Je kriva plosca za memtest errorje/nestabilnost?Oddelek: Navijanje | 2269 (2121) | AtaStrumf |
| » | Odklep T'bred B???Oddelek: Navijanje | 2041 (1646) | igaiga |
| » | AMD XP ( posebno vprašanje)Oddelek: Navijanje | 2290 (1693) | danielka84 |
| » | Kero platoOddelek: Kaj kupiti | 1266 (1016) | reXor |
