Vb.Net BackgroundWorker
DemonDomen ::
Imam težavo v Visual Studiu 2008, kjer hočem dodati BackgroundWorker za windows mobile aplikacijo.
Težava je, da na najdem BackgroundWorkerja v Toolboxu in v System.ComponentModel.
Ko uporabim ukaz
Dim worker As System.ComponentModel.BackgroundWorker
Mi napiše
Type 'System.ComponentModel.BackgroundWorker' is not defined.
Kako ga lahko dodam v toolbox ali kakorkoli drugače v program?
Fix a computer and it'll break tomorrow.
Teach its owner to fix it and it'll break in some way you've never seen before.
C# threadanje in gui
Oddelek: Programiranje
81112 (1003) darkolord
[c#] problem pri zapiranju aplikacije
113017 (2655) KernelPanic
Vprasanje glede koncepta programa [c#]
112767 (2509) _Dormage_
[c#] Vprasanje glede BackGroundWorker classa in spreminanja gui elementa
61096 (1022) Ericssony
POMOČ: C# Spremenitev spremenljivke medtem ko teče ukaz while
91970 (1727) Ericssony
