Forum » Programiranje » C# zvok
C# zvok
Loaded ::
rad bi predvajal kratke mp3 datoteke na nek event. stvar deluje, ko se event prvič sproži, potem pa ne več.
razred zvok
[code]
using System;
using System.Runtime.InteropServices;
using System.Collections.Generic;
//using System.Linq;
using System.Text;
namespace GlobalHookDemo
class Zvok
private string _command;
private bool isOpen;
[DllImport("winmm.dll")]
private static extern long mciSendString(string strCommand, StringBuilder strReturn, int iReturnLength, IntPtr hwndCallback);
public Zvok() { }
public void Close()
_command = "close MediaFile";
mciSendString(_command, null, 0, IntPtr.Zero);
isOpen = false;
public void Open(string sFileName)
_command = "open \"" + sFileName + "\" type mpegvideo alias MediaFile";
isOpen = true;
public void Play(bool loop)
if(isOpen)
_command = "play MediaFile";
if (loop)
_command += " REPEAT";
[/code]
tu pa še kako kličem.
[code]
zvok.Open("C:/krneki.mp3");
zvok.Play(false);
[/code]
razred zvok
[code]
using System;
using System.Text;
class Zvok
public Zvok() { }
public void Close()
isOpen = false;
isOpen = true;
if(isOpen)
if (loop)
[/code]
[code]
zvok.Play(false);
[/code]
Loadeed
Loaded ::
Če dam tole
zvok.Play(false);
zvok.Close();
mi ga sploh ne predvaja... Loadeed
| » | [C#] Prehajanje na low levelOddelek: Programiranje | 1801 (1557) | krneki0001 |
| » | [C#] pixel scan z ThreadOddelek: Programiranje | 1632 (1414) | perooo25 |
| » | kako narediti program ki bere drugi programOddelek: Programiranje | 7186 (5499) | imagodei |
| » | video v c#Oddelek: Programiranje | 1864 (1404) | boss-tech |
| » | Vb6Oddelek: Programiranje | 1815 (1678) | StratOS |
