SOF2 in GTA3 cheats
SOF2 in GTA3 cheats
Soni ::
GUNSGUNSGUNS
IFIWEREARICHMAN
GESUNDHEIT
MOREPOLICEPLEASE
NOPOLICEPLEASE
GIVEUSATANK
BANGBANGBANG
ILIKEDRESSINGUP
ITSALLGOINGMAAAD
NOBODYLIKESME
WEAPONSFORALL
TIMEFLIESWHENYOU
BOOOOORING
TURTOISE
SKINCANCERFORME
ILIKESCOTLAND
ILOVESCOTLAND
PEASOUP
MADWEATHER
ANICESETOFWHEELS
CHITTYCITTYBB
CORNERSLIKEMAD
NASTYLIMBSCHEAT
1.) Change the properties of your game shortcut and add
+set sv_cheats 1 behind your EXE
Example: D:\GAMES\SOF2\SoF2.EXE +set sv_cheats 1
2.) Edit your base\myconfig.cfg and search for "toggleconsole".
Here you can define any key you want to toggle the console ingame.
Example: bind X "toggleconsole"
3.) Start the game and open the console and type one of the following
cheats:
GOD (invulnerability)
NOCLIP (you can go through walls)
GIVE ALL (gives you all the fine weapons)
NOTARGET (enemies won't hit you)
PINKSPIDER (gives you infinite power)
KILL (guess what)
BigSexy ::
eh cheati itaq sux k cel game zajebejo :)) bolš mal počakat je bl feeling...
CWIZO ::
sam neki v sof2 men kode ne delajo (sej jih nočem uporabljat sam neki sem probaval)
tistih za gta pa neštekam ?!
hancic.info
I can't uninstall it, there seems to be some kind of "Uninstall Shield"...
Soni ::
Vpiši v igri primer GUNSGUNSGUNS
CWIZO ::
Am a obstaja kšna kodo da končaš trenutno misijo (nalogo)
ker mi ne gre inu ne gre....
hancic.info
BadB0y ::
Zakaj pa pol sploh igras ??? Pol pa je tak najbolse ce te kr na konec igerce vrze :))))
CWIZO ::
ja sej zdej je kull, sem že naredil tist...
one question :
a če te policaji lovijo pa z avtom zapleeš čest tist znak k ti zbija kok te iščejo a ga pobere, al morš peš pobrat ?
hancic.info
Binji ::
pes. Drgac ne bi blo tko zanimivo>:D
Kdor ne navija ni Slovenc, hej, hej, hej!
BC3 ::
ne, samo čez zapelješ. ni treba peš.
CWIZO ::
wokey thanx
kje pa ste kej ?
hancic.info
jRk0 ::
CWIZO:ce te policaji lovijo lepo gres prespricat avto, pa je. ce pa mas eno zvezdico pa itak ni panike:))
Men pa za GTA3 ne upspe poganjati muzike z diska. Sicer na gamecopywordu , je crack , mapak deluje le igre , ki so v osnovi scrackane , in ne original?
Kako to usposobit.
Sicer goljufije pri GTA3 ne uporabljam , sm se pa malo igral , in dobiš zelo hecne rezultatae.
CWIZO ::
najbolj huda je una koda za tank.
Pizda sam res nevem kaj morš anredit da te FBIajovci pa vojska začnejo lovit.
S tankom razsujem pol mesta, vsi avti k prletijo vate eksplodirajo, gazim pešce, strelam v policisko postajo, pa mam sam 3 zvezdice...
hancic.info
_Mortal_ ::
Cwizo odvisen v kerem mestu
Is reading in the bathroom considered as multi-tasking?
CWIZO ::
ja sej zdej sem prišel v drugo mesto in tm so pa že FBIjajovci.
predvidecam da bo vojska uletela šele v trejtem mestu...
hancic.info
Matek ::
Meni pa noče sejvat špila. Nisem shranjeval med misijo, šel v uno garažo oz. vrata poleg nje, pa mije on screen ven vrglo, pa so vsi sloti bli free, sem enga zbral in pol nekaj mele pa napiše Save unsuccesful. Ma kdo kako idejo?
CWIZO ::
mogoče je una mapa v katero shranjuje (nevem kera je) kej sfukana, al pa maš kej tko anrejen da se ne da pisat va njo, al pa je sploh ni...
hancic.info
Binji ::
Zakaj pa mi, ko probam cheate v SOF2 napise "cheats are not enabled on this server"?
BC3 ::
če ne dela tole sv_cheats 1 napiši tole setrandom sv_cheats 1 (v konzolo (men je delala ta druga))
Tito ::
lol
teac ::
Kak pa prideš potem ven iz konzole? Napišem not, kaj mislim, pol pa ne morem ven..nekajkrat mi je sicer uspelo, vendat takrat ne vem, kaj sem stisnil, ker sem samo nekaj brezveze stiskal (če vpišem kodo in stisnem enter pa me ne vrže ven iz konzole).
Dj-Prah ::
Hja jest sem jo glih vceraj obrno.Dobra igra ni kaj.Aja v prvem mestu so policaji 4 zvezde max,v drugem so policaji fbijci 5 zvezd v tretjem pa 6 zvezd policaji,fbijci,vojska.Sam vojaki so glupi sami svoje rusjo pa nec ne strelajo z tankom.Pride s tankom do tebe,gre ven pa te strela z M4.:P
Drgac pa rula.
Za kode pa samo trajners.Mas 27 dodatnih fukov.Evo linka za trajner..Kod mas pa takih da te kap ne.:))
Ce nucate kej recte.
Intel Celeron 1000Mhz@1400Mhz-Vulcano 9,Hercules 3D Prophet 8500LE 128MB DDR TV/DVI,512MB SDRAM,Asus CUSL2-C Black Pearl
V-i-p ::
dj-prah: hvala, hvala, tale trainer lepo poživi igro :D . Škoda je samo, da vse funkcije ne delajo :'( sem namreč nameraval "zastonj" priti do 3jega mesta in je most podrt, vmes pa reka, pa sem hotel poleteti z avtom čez, pa hudir, ravno ta koda (TAB + a) za letenje z avtine dela... škoda... bo treba drugače čez, heh...
  • spremenil: V-i-p ()
Dj-Prah ::
V.I.P ni za kaj.Ce kej rabis rec.:)
V-i-p ::
Seveda :)) če veš, kako poleteti z avtom čez, za to kodo bi ti bil lepo hvaležen :'(
Dj-Prah ::
Ej te kode za letenje nisem probal.Ti si probal preko morja letet na drugo stran?Dej ce lahko letis probi most preletet,pel se po njem na sredini ko je razbit pa prelet.Misli da bi moglo jet.:\
Drgac pa probat ni greh,pes je tud probal pa jih je devet napravo.;)
Return to Castle Wolfenstein - kako dalje ?
Oddelek: Igre
313669 (2024) MaticKregar
Quake 3 TA
Oddelek: Igre
292168 (1663) no at
Wolfenstein - RTC (Return to Castle)
Oddelek: Igre
243153 (1768) Hooligan#1
Return to the Castle W problem
Oddelek: Igre
272262 (1855) Fresh Prince
Return To Castle Wolfenstein (strani: 1 2 )
Oddelek: Igre
586800 (5668) LunKi
