Linux problem
Linux problem
slycer ::
Imam naslednji problem. Ko hočem instalirati program MPlayer, mi izpiše nasldenje sporočilo:
[root@localhost MPlayer-0.90pre2]# make install
make[1]: Entering directory `/home/boste/progi/MPlayer-0.90pre2/libdha'
mkdir -p /usr/local/lib
install -m 755 -s -p libdha-0.1.so /usr/local/lib/libdha-0.1.so
rm -f /usr/local/lib/libdha.so
ln -sf libdha-0.1.so /usr/local/lib/libdha.so
ldconfig
make[1]: ldconfig: Command not found
make[1]: *** [install] Error 127
make[1]: Leaving directory
make[1]: Entering directory `/home/boste/progi/MPlayer-0.90pre2/vidix'
make[2]: Entering directory `/home/boste/progi/MPlayer-0.90pre2/vidix/drivers' mkdir -p /usr/local/lib/mplayer/vidix
install -m 755 -s -p *.so /usr/local/lib/mplayer/vidix
make[2]: Leaving directory `/home/boste/progi/MPlayer-0.90pre2/vidix/drivers'
make[1]: Leaving directory `/home/boste/progi/MPlayer-0.90pre2/vidix'
if test ! -d /usr/local/bin ; then mkdir -p /usr/local/bin ; fi
install -m 755 -s mplayer /usr/local/bin/mplayer
if test ! -d /usr/local/man/man1 ; then mkdir -p /usr/local/man/man1; fi
install -c -m 644 DOCS/mplayer.1 /usr/local/man/man1/mplayer.1
install -m 755 -s mencoder /usr/local/bin/mencoder
install -c -m 644 DOCS/mencoder.1 /usr/local/man/man1/mencoder.1
*** Download font at http://www.mplayerhq.hu/homepage/dload....
*** for OSD/Subtitles support and extract to /usr/local/share/mplayer/font/
install -c -m 644 etc/codecs.conf /usr/local/share/mplayer/codecs.conf
Iz sporočila je sicer razvidno, da v mojem operacijskem sistemu (Red Hat 7.2) ni ldconfiga. Ldconfig bi se gotovo dalo najti kje na internetu, vendar pa nimam pojma, kje naj ga dobim. Preiskal sem že na RPMfind in na Googlu, vendar brez uspeha. Morda kdo od vas ve, kje lahko dobim ldconfig?
l0wc4 ::
Poglej tukaj, čeprav pa bi se obvezno moral nahajati na prvem ali drugem CDju od RH7.2 prav tako v RPM obliki. :D
Gh0st ::
ldconfig je knjižnica. Preberi si fajl INSTALL in preglej katere knjižnice rabi program, poglej ča jih imaš. Tiste ki jih nimaš jih najdi kle
you might start believe in Gh0st stories. you're in one. :)
  • spremenilo: Gh0st ()
slycer ::
Eh, brez veze. Itak sem poizkušal knjižico na vsak način spraviti v sistem, pa mi je vedno javljalo neke spore med namestitvenimi paketki. Pol sem pa popenil in cel Red Hat 7.2 zmaličil do neuporabnosti (glibc je šel bye bye :'( ). No itak sem imel v planu clean install, ker mi je od upgrada iz Seawolfa na Enigmo vse skupaj nekaj zajebavalo pri črkah "č" in "ć".
Jovo na novo ... :D
Za|Bon ::
Ce mene vprasas je 7.2 razlicica REDHATA (Enigma) eno sra*** . Ko sem ga imel instaliranega sem imel vedno probleme , tako da jest ti bi predlagal kaksno drugo distribucijo . Vsaj jest nimam dobrih izkusenj z REDhatom .
Lp, Za|Bon
slycer ::
Mah, jaz mislim ostatli kar na Red Hatu, ker ima najboljšo podporo in sem ga že preveč navajen. Vendar pa bom raje počakal na Skipjacka, ker na Enigmo ne grem več. Seawolf je bil čist OK, na Enigmi je pa vse nakam sumljivo deloavalo.
Gh0st ::
Pa poskusi še kakšen SuSE ali Slackware.
dr.J ::
No. počakaj par dni, da izide RH7.3. Direktorij na njihovem ftp strežniku je že :)
Z RH7.2 dosedaj še nisem imel nobenih problemov. Moti me le, da ne dajo n.pr. KDE3.0 za upgrade, pa na nov kernel moraš čakati celo večnost.
Crosscompiling Gnuradia za RPi
Oddelek: Operacijski sistemi
142271 (2117) poweroff
OpenSUSE pomoč
111377 (1270) Redorange
compiling mplayer z mp3lame support
Oddelek: Programska oprema
91489 (1409) kriko1
Cnet "network simulator"
133454 (3336) urbecar
FreeBSD - nekaj newbie vprašanj
111599 (1461) ghaefb
