Forum » Kaj kupiti » SSD za sistemski disk
Seveda sm to cilju na paranoike. :>
Po petih letih in 5 razlicnih pogonih sem naredil tak zakljucek, da se nikakor ne sekiram za endurance.
hehe touché
Jap, paranoja okol enduranca je res odveč. Lahko ratamo paranoični, ko se bo meru v stotinah prepisov...
darkolord ::
iloveboobz je izjavil:
?SuperVeloce je izjavil:
od takrat, ko smo imeli 40nm ssd-je pa do sedanjih 1xnm so morali proizvajalci uporabiti tudi polno drugih pogruntavscin, katere se lahko sedaj uporabijo...
po pravici povedano se meni zdi cudez, da se lahko flash programira na tako visokih napetosti s tistimi parimi elektroni na celico in zdrzijo... in da lahko to kupimo za drobiz...
Jap, v TLCju pridejo bojda na celico samo 3je !!! elektroni. Imagine that.
Trije biti pa res niso trije elektroni :)
- spremenilo: darkolord ()
PrimozR ::
http://anandtech.com/show/7896/plextor-...
Traditionally cells are symmetrical. The process node refers to the size of one cell, so in the case of 20nm NAND, the cell size would be 20nm x 20nm. However, there is no rule against making an asymmetrical cell and that is in fact what Toshiba/SanDisk did with their first generation 19nm NAND. Instead of being a symmetrical 19nm x 19nm design, the cell size was 19nm x 26nm. Compared to IMFT's symmetrical 20nm design, the actual cell size is quite a bit larger (494 nm2 vs 400 nm2 ), yet in terms of marketing Toshiba's/SanDisk's "19nm" NAND was smaller and more advanced.
Se bo treba naučit _natačno_ brat
Oftentimes when cell size is discussed, it is only the actual size of the cell that is taken into account, which leaves the distance between cells out of the conclusion. However, the so called empty parts (they are not really empty as you saw in the X-ray a couple of pages back) take a part of the die area similar to the cells, meaning that they cannot be excluded. The appropriate way to measure cell size is from the inner corner of a cell to the outer corners of neighbouring cells in both X and Y axes. This is demonstrated by the black square on the above graph.
Tako da je čisto odvisno kako meriš. Če meriš samo celico, potem node size predstavlja velikost stranice celie. Če pa upoštevaš še ta "prazn" plac med celicami, je pa jasno velikost večja.
Pol pa hočem SSD brez praznega placa, samo celice!!!
Jest sumim, da pri temu "nalozenemu" nandu uporabljajo vecje kapacitete, kot uradno so, da imajo tako velik endurance. Ok, neki dobijo na racun vecjega proizvodnjega procesa, ampak mocno dvomim, da je to dovolj. Kar tako na lepe oci, samo zato, ker je "3D" pac ne gre.
Nič ni na lepe oči, 3D je ključen tukaj. Tranzistor ima pač večjo površino oz. večji volumen. Anand vse razloži, pri polprevodniških čipih se gleda samo površino, višina je zanemarljiva. Tukaj pa ti lepo gradiš v višino ;)
Dvomim, da so samo s procesom toliko pridobili. To je 3x vec, kot je bil MLC pred leti podobne proizvodnje, kar nekako ni logicno. Pomoje vec kot 15-20k niso samo s tem dobili.
Niso, 3D je ključen, kot sem že rekel.
Trije elektroni na bit-state pri 16 nm, če sem prav razumel. Pač bolano nizke cifre in rata ti jasno, zakaj zadeve lahko crkujejo :)
- spremenil: PrimozR ()
Jap. Zto je prehod na 3D pratkično nujen, ker skalirat pod 10nm že skor nemorš brez čarovnij.
The scaling introduces a variety of issues but I will start with the cell size. As the cell size is shrunk, the size of the floating gate is also shrunk, which means that the floating gate is able to hold less and less electrons every time the process node gets smaller. To put this into perspective, Toshiba's and SanDisk's 15nm NAND is stores less than 20 electrons per NAND cell. With TLC, that is less than three electrons per voltage state, so there is certainly not much headroom for escaped electrons. In other words, the cell becomes more vulnerable to the IPD and tunnel oxide wear out because even the loss of one electron can be vital to the voltage state.
Ok malo sem se narobe izrazil (ni na celico toliko elektronov, ampak na voltage state). Still, še vedno presneto malo.
- spremenil: iloveboobz ()
FlyingBee ::
no shit!
Ok, sm v sluzbi in na telefonu, tko da ne bom sel iskat, zanima pa me, za koliko je rejtan ta samsungov nand? Omenjeno je bilo 10.000, ampak je res toliko, ali je ta stevilka neznana?
FlyingBee ::
hojnikb - Tuesday, July 01, 2014 - link
Your EVO has worse endurance, lower IOPS, lower consistency and most of all lower Write speeds (495MB/s write is due to trick called turbowrite).
Sequential speeds are only a part of the story.
zakaj je že endurance sploh pomemben?
Ne gre se zato, kako pomemben je, gre se zato, da je to ena izmed razlik med tema pogonoma.
Ljudje pogledajo sekvenčne številke (ki so itk napihnjene pri EVOtu) in misljo kako stvar ni nič boljša. Čeprav temu ni tako.
Žal ni nobenga official rejtinga, vse so samo ugibanja (tudi za TLC recimo še vedno ni nobenga official rejtinga, čeprav je že neki cajta uzun). Glede na nod, ki ga uporabljajo in endurance rejting bi reku da je sam flash uradno dober vsaj za 10k prepisov. Lahko se pa seveda motim.
FlyingBee ::
Žal ni nobenga official rejting, vse so samo ugibanja. Glede na nod, ki ga uporabljajo in endurance rejting bi reku da je sam flash uradno dober vsaj za 10k prepisov. Lahko se pa seveda motim.
ni pomembno, kupiš najcenejšega pa bo za sata6 dovolj
Bold = nemogoče
- spremenil: FlyingBee ()
Če rabiš vsak drop performanca ali pač rabiš pogon za bragging rights, potem vzameš to. Ostali bomo pa počakal na 850 basic verzijo.
Ce je res samo 10.000 je to "malo". 10.000 je imel intelov 50nm, 34nm pa 5.000. Ce je res 40nm proces tako dozorel, bo imel 3d nand na 20nm mogoce 5000, ce predpostavljamo, da se bo proces se izboljsal. Se pravi, 10nm mogoce 1000 ciklov in to je to.
Glede na to, da jih ma 840ka toliko in je v testu presegel 900TB, še to nebo noben problem.
In do 10nm 3Dja bo trajal še neki cajta.
A to ciljas na 840 pro? Ker evo je poginil ze prej (700 ce se prav spomnim)
Mimogrede, za obicajen nand je ocitno ze 16nm problem, ker ga ni v mx100 128GB. Ubistvu bo vso stvar resevala velika kapaciteta, pri 10nm se bomo pogovarjali ze o vec TB ssdjih.
- spremenil: Dr_M ()
SuperVeloce ::
ne incompressible hyperx je bil takrat mrtev. 840 je ugasnu mal pred PB, brez warninga, kar lahko pomeni tudi crknjen controller. Rezerve se ni pokuril. Je pa res da je bilo nekaj hujsih errorjev pri crknjenih sektorjih pri koncu
- spremenil: SuperVeloce ()
http://techreport.com/review/26523/the-...
Ni to razlog za odsotnost pomoje. Glede na to, da pravijo, da je pri 16nm podobn endurance kot pri 20nm, se jim verjetno ne splača delat 16nm flasha z manj kot 2 die-im na package. Lahko je pa kriv tudi endurance. Vedl tak nebomo nikol.
Between 800 and 900TB of writes, the 840 Series logged 119 more uncorrectable errors, bringing the total to 295. Anvil didn't report any hash failures during that period, but we have its built-in integrity test set to run relatively infrequently--after each 1TB of writes--and on a 700MB file, that covers only a small portion of the flash. Regardless of whether the last spate of uncorrectable errors resulted in incorrect data, it's probably no coincidence the 840 Series died shortly after.
FlyingBee ::
to si pa iz riti potegnil, kar nekaj, neka ugibanja iz napol prebranih besedil z interneta
http://www.anandtech.com/show/8066/cruc...
Tudi če je samo 2000 p/e, je to še vedno dovolj za 128GB pogon, glede na to da ima 120GB EVO samo 1000
the endurance rating remains at the same 72TB despite the change in NAND. Micron wouldn't give us the exact P/E cycle rating for their 16nm NAND but I was told that the endurance is similar to their 20nm MLC NAND.
Za endurance so trdili, da je pri 20nm enak kot je bil pri 25nm, tko da skoraj tezko verjamem, da je pri 16 se kar enak. Je pa med 16 in 25nm prevelika razlika.
Očitno že uporabljajo kake trike, da jim uspeva podobn endurance (bolj prebrani primerki, bolj agresiven ECC ?)
FlyingBee ::
hehe, to je samo marketing ,logika na ravni določanja prekrškov Šačiriju
segmentacija ne dovoli tega
Pa se ena stvar, se je kdo toliko poglobil v clanek na techreport in ugotovil, kaksnega izvora so bili testirani pogoni? Kupljeni v random retail trgovini ali so jim poslali prijazni proizvajalci?
verjetno so poslani s strani proizvajalcev..
Seveda jim dovoli
Seveda jim dovoli
Ce je temu res tako, so izsledki analize se vedno verodostojni?
FlyingBee ::
Ok, sej tudi ce retail zdrzijo samo 1/3 tega, je zame se vedno good enough, ampak ima smisel si podajat take linke in jih jemat za sveto?
Ucasih je bil na xs forumu en seznam, kjer je so bili testni ssdji uporabnikov in so bile stevilke precej nizje. Res so bili pogoni vecinoma 60/64GB in 120/128GB, ampak je bil tudi nand malo bolj vzdrzljiv.
Malo sumljivo je, da se razlikuje za 3-5x.
Ce so bili testirani retail primerki iz trgovine, so stevilke vsekakor impresivne, ce so poslani od proizvajalcev, je vseeno treba malo z rezervo jemat.
Na tole niti ni vredno odgovarjat, ampak sem odgovoril, se predno sem videl ta post.
ja, grozno veeeeeeliiiiiiike razlike so, da se je že kar za sekirat ... NOT
Duhec ::
Stop ! Malo pavze !
Novica, sicer stara kak mesec pa vseeno:
New method of SSD garbage collection can boost drive performance up to 300%
http://www.extremetech.com/computing/18...
http://blackbird.si/
kuglvinkl ::
ajde otroc! hojnikb, zunaj je poletje, kristus mali.
kuglvinkl ::
Sicer pa, naslednji fokus je M.2 kar se mene tiče. Plat z m.2 je pa za na prste roke ene roke za preštet. Tko da, mogoče bodo izdal "850" za PCIe.
kuglvinkl ::
anand ma že benche, se pa ne spomnem iz glave, kje je največji hit. Do m.2 plat bomo pač uporabljal kartico za pcie.
PrimozR ::
Kugl sata express za desktop (priklopiš na 2 sata porta pa še par linkov zraven)
Glede vzdržljivosti, 3d nand je popolnoma druga žival kot 2d. Pozabite na process node, tukaj se endurance dobi zarad bistveno večje površine oz. volumna komponent v tranzistorju, ki so obenem lahko še iz drugih, bolj vzdržljivih materialov. Tudi na 20 nm bo vzdržljivost še vedno izjemna. Ne bi bil presenečen, če trenutni čipi zdržijo še bistveno več od 10k prepisov, 'uradno' (interne cifre pač, tiste, ki so okrog 3k za 25 nm nand). Garancije je 150 TB na vseh kapacitetah.
Pipi, narobe si ti tale 3d predstavljas. Endurance se poveca zaradi drugacnega "zapiranja" elektronov v celico, ne zaradi visanja tranzistorjev.
V tem primeru se gre zgolj za vecjo gostoto, ki gre v visino, endurance je pa zgolj posledica drugacnega shranjevanja elektronov in predvsem 40nm proizvodnjega procesa, ki omogoca zelo velike celice.
Sicer je v clanku na anandu vse lepo razlozeno.
Dami ::
Just gief me +8tb ssd. Pa je lahk endurance pod 1000 in na sata6 for all I care. Samo da je placa
radmannsdorf ::
radmannsdorf je izjavil:
danes bom frendu fliknu notr MX100, in to v komp ki je star 5-6let. notr ma eno hudo plato za tiste čase, pa me zanima, glede na to da seveda ima sata priklope, to tudi avtomatsko pomeni da ima v biosu AHCI možnost ane?
AHCI možnost je, morala sva pač inštalirat driverje med win inštalacijo.
plata je http://www.gigabyte.com/products/produc...
je tole ok za sata 3Gb/s ane?
SuperVeloce ::
Cifre delujejo ok. Zakaj driverje na x38? Jaz se ne spomnem, da bi moral kdaj instalirati dodatne driverje za normalno delovanje na gigabytovi P35, je pa res da starejše zadeve od win xp sp2 nisem instaliral.
radmannsdorf ::
PrimozR ::
Ja, je lepo razloženo in prav si predstavljam zadeve. Kocka ima večjo površino kot pa samo ena stranica kocke (ploščica). To je efekt tukaj. Skupaj s 40 nm procesom je pa, kot rečeno, mogoče uporabiti druge materiale.
jest10 ::
Kako so pa kaj Jmicron JMF606 kontrolerji?
Za foro sem na Ebay avkciji za 9,6$ dobil Kingfast 32GB SSD s tem kontrolerjem, pa me malo firbec kerga mačka v žaklu sem staknil![]()
Trenutno preko USB 2 ohišja. Direkt na SATA 2 pa sprobam nekoč, ko se mi bo dalo umikat grafično, da bom lahko priklopil SATA kabel, kar se lahko zavleče...
Verjetno bo nekoč zadeva fasala anvilov test vzdržljivosti, da vidim, koliko kitajčki zdržijo
http://www.legitreviews.com/samsung-850...
zakaj dokaj nizka hitrost v 4k?
Drugi reviewi dobivajo precej višje hitrosti (100MB/s+) tako da je čisto možno, da je kaka napaka pri merjenju ali pa so vklopljene kake power saving funkcije (znane po tem, da zbijajo 4k performanec).
mat xxl ::
Ker teme ne sledim že dolgo, me zanima povzetek 1 ali 2 modela, kaj kupiti, notesnik je ultra zmogljiv 1 leto star HP, velikost bi bila 500 GB lahko normalna 2,5 debelina pred vsem, se mi gre bolj, kot za noro brzino za sigurnost modela in za čim manj napak, tudi če bo hitrost samo 75% najmočnejših hitrosti.....
Samsungov V-NAND, ki je v 850pro naj bi bil dober za 6000 p/e.
http://www.anandtech.com/show/8239/upda...
ja, sam to je številka pridobljena iz WLCja... samsung še vedno lahko nastavi WLC tako, da bo stvar zgledala "slaba", čeprav v resnici ni... pač si nesmejo kanibalizirat prodaje enterprise rešitev ;)
Tezaab ::
Odprodaja diskov na Mimovrste (Kingston SSDNow v300, 60GB). Je res majhen, ampak za dober evro... Za kaksne virtualke bo ze dober :D
